Question about Jura Capresso Impressa F9 Espresso Machine
Missing tray error
It says tray is missing, but I cannot insert the tray as a flap has been lowered in the back of the tray section. How do I have the flap moved automatically back up?
  • 3 more comments
  • shoneill Jun 11, 2008
    when we cleaned the ground tub it would not slide in as usual. the tray with out the tub would slide in. So clearly something is in the way that has not been there for our 2 years of ownership.
    We tipped the tub at an angle to slide the tray back successfully - yeah. However, there is still a problem.
    When we press the 'brew coffee' buttons, we can hear the grounds drop to the grinder and grind, but the water comes out clear, it is not making contact with the new grounds.
    please help.
    Sharon
    408-807-6567
    thank you
  • weaselbear Mar 21, 2009
    Turned machine (F9) on this morning. "Tray Missing" message appeared. I took the tray out and emptied grounds bucket but could not put the tray back in. The tamping mechanisim has lowered preventing the tray (with bucket on) from being correctly positioned. Sticks out about 1cm.
    Firts time this has happened. Machine approx 2yrs. Have triedd turning off at mains etc to reset. No go!
  • Deanie Nov 25, 2012
    Thanks you very much!
  • David J May 12, 2013
    Putting the tray back in without the grounds container doesn't get my "missing drawer" message to go away. Any other suggestions?
    Puttint the drawer back in without the grounds container doesn't remove my "drawer missing" message, so I cannot proceed. Any other suggestions?
Insert the tray-all of it except the grounds container.  The message disappears and you can wait until the machine continues it's cycle and then asks to empty the tray.  Empty the tray and place the grounds container back inside.  Whew, I've done this a few times over the years when I am rushing but it fixes it every time.
Posted on Jun 18, 2009
    Thanks so much!
Put the tray back without the grounds container (b/c it is higher; that's what can't get past the flap).  Make a cup of coffee, letting the grounds fall into the tray.  Normally, after you do that, the machine will stop in the correct position.  You  can remove and clean the tray, and put the full assembly back in.
I've had to do this a couple of times and it has always worked.
Posted on Mar 21, 2009
I tried to turn it off and on, reach in and flip the do-thingy, etc. The only thing that solved it for me was following allmannerofw's suggestion above. Thanks you for posting!
Posted on Oct 23, 2012
  • Anonymous Feb 29, 2016
    Thanks so much...worked like a charm
I think you can fix this by turning the machine off....see if flap goes back up/
Posted on Feb 18, 2008
    Problem Solver:
  • 7 Answers
Move it gently up. That's what I did on a similar model.
Posted on Mar 02, 2008
How to print #10 envelopes on a Xerox 3610 printer?
Solution : Print on Envelopes You can print envelopes from the Bypass Tray only.
Guidelines for Printing Envelopes
  • Print quality depends on the quality and construction of the envelopes. Try another envelope brand if you do not get desired results.
  • Maintain constant temperatures and relative humidity.
  • Store unused envelopes in their packaging to avoid excess moisture and dryness which can affect print quality and cause wrinkling. Excessive moisture can cause the envelopes to seal before or during printing.
  • Remove air bubbles from the envelopes before loading them into the tray by setting a heavy book on top of them.
  • In the print driver software, select Envelope as the paper type.
  • Do not use padded envelopes. Use envelopes that lie flat on a surface.
  • Do not use envelopes with heat activated glue.
  • Do not use envelopes with press and seal flaps.
  • Use only paper envelopes.
  • Do not use envelopes with windows or metal clasps.
To Load Envelopes in the Bypass Tray:
  1. Open the Bypass Tray.
  3. Move the width guides to the edges of the tray.
    NOTE: If you do not load envelopes in the Bypass Tray right after they have been removed from the packaging, they can bulge. Flatten them to avoid jams.
  4. To load envelopes, select an option:
    • For Number 10 envelopes, load the envelopes with the short edge going into the printer, flaps down, and flaps to the right.
    • For C5 envelopes, do one of the following. If the envelopes wrinkle, try another option.
      • Insert envelopes with the print side up, flaps closed and down, and flaps going into the printer.
    • NOTE: When loading Monarch or DL envelopes, remove the Multipurpose Tray.
  5. On the printer Control Panel, press the Menu button.
    NOTE: To navigate through the menu, use the Up or Down arrow buttons.
  6. Navigate to Tray Settings, then press OK.
  7. Navigate to the Bypass Tray, then press OK.
  8. Navigate to Tray Mode, then press OK.
  9. Navigate to Panel Specified, then press OK.
  10. To return to the previous menu, press the Left arrow button.
  11. Navigate to Paper Type, then press OK.
  12. Navigate to Envelope, then press OK.
  13. To return to the previous menu, press the Left arrow button.
  14. Navigate to Paper Size, then press OK.
  15. Navigate to the required envelope size, then press OK.
Phaser 3610 Support Drivers
Apr 09, 2014 | Xerox Office Equipment & Supplies
How to change ink cart. in hp psc 2210 all in one printer
  1. Turn on the unit, then open the print cartridge access door. The print carriage moves to the center of the unit. Never attempt to move the carriage by hand.
  2. Press down lightly on the top of the ink cartridge latch and pull the lower section of the latch out to release the cartridge.
  3. Pull the cartridge out of its holder.
  4. Carefully remove the protective tape from the new cartridge.
  5. Reinsert the new cartridge into the carriage at a slight angle. When the cartridge is fully inserted into the carriage, rock it upright.
  6. Hold the hinged flap of the latch out while lowering the latch.
  7. When the latch is fully lowered release the hinged flap. It should catch under the tabs on carriage.
  8. Close the cartridge access door.
  9. The LCD display may indicate the cartridges need to be aligned. Load paper and press "Enter" on the front panel.Discard the alignment pages that print.
Feb 01, 2011 | Office Equipment & Supplies
I have filled the paper tray with paper and will not print
Try to flip down the back cover and lower the flap that covers the rollers. On the inside of that flap, right in the middle of it, you will see a small, one inch long lever that helps keep the paper up against the roller. This lever was moved to the left a bit to far, so I nudged it to the right. As soon as you do this, the light should stop blinking and the printer should work.
Jan 19, 2010 | Brother HL-2040 Laser Printer
I cannot open the #2 paper drawer
Look at the back of the printer.
There is a plastic flap that covers the rear of the paper tray. Lift the flap up, reach in and push the tray down. Now push it forward at the same time. The tray should come out. Normally, when you pull the tray out, the plate at the bottom lowers itself and allows the tray to come forward.
Jan 11, 2010 | HP LaserJet P3005n Printer
Fuel tank neck missing a flap
it is just stuck as long as you have a gas cap on there is not going to be any problem the cap is just there so when you fill your tank there are no fumes coming up from it
Nov 02, 2009 | 2003 Lexus SC 430
Error code 8 appeared and now cannot get basket
The machine did not complete its cycle, either while finishing a brewing cycle or a cleaning cycle. This is caused because the motor is not strong enough and overheated. I think it is a design problem, but there is a "work-around" solution.
First, to put basket back, look inside opening. You will see a flap at the back of the opening. This flap is down and is what is preventing insertion of basket. Take only the grounds basket. Tilt the grounds basket and insert it so the back end of basket goes under the flap. Then level out the basket. Note the flap is now inside the back end of the grounds basket. Holding the basket up and level, re-insert the drip tray and the basket holder underneath the basket. These should now slip into place.
The "work-around" solution is to let the motor cool down. Unplug the machine for at least 30 minutes, then turn unit back on, and the cycle should complete because the motor is now cool.
I notice this error 8 happens mainly when the voltage from the Hydro Utility is low. This happens during peak electricity usage hours. So, to clean your machine, do it on the week-end during the daytime either mid-morning or mid-afternoon.
Good luck
Sep 27, 2009 | Jura Capresso Coffee Makers & Espresso...
Tray will not insert properly, a flap seems to be lowered
Start up the machine, take insert everything but the used grounds container. The machine will reposition the brew unit. When the machine says "heating", take out the tray and now you can insert everthing with the used grounds container. You can of course run a Rinse cycle if the machine doesn`t start positioning right away.
Aug 30, 2009 | Jura Capresso Impressa F9 Espresso Machine
How to print an envelop
nstructions Use the following steps to ensure that you are ready to print envelopes. Your printer can have either a single envelope or multiple envelopes loaded and ready for printing.
  • If you are printing a single envelope, you can use the single envelope slot and leave your paper in the lower (IN) tray. This allows you to print the envelope and then a letter.
  • If you are printing a stack of envelopes, use the lower (IN) tray for loading the stack of envelopes.
To Load a Single Envelope
  1. Do not remove the paper from the lower (IN) tray. Be sure the card guide is in the down position, before using the single envelope slot.
  2. Remove a single envelope from its packaging.
  3. Slide the envelope evenly into the single envelope slot. The single envelope slot is located on the right side of the upper (OUT) tray. The envelope should be loaded with the address side down (flap side up).
  4. Make sure the creased flap edge of the envelope aligns with the right side of the single envelope slot.
  5. Slide the envelope through the slot until it stops. Make sure the envelope is not bent and is straight in the envelope slot.
    NOTE: To minimize print skew, use envelopes with rectangular flaps rather than triangular flaps.
To Load Multiple Envelopes
  1. Slide the paper width adjuster to its leftmost position.
  2. Pull out the paper length adjuster and remove any paper from the IN tray.
  3. Remove up to 20 envelopes from their packing and tap the short edge of the envelopes on a flat surface to even the stack.
  4. Slide the envelopes evenly into the IN tray, address side down (flap side up).
  5. Slide the paper width adjuster to the right until it gently touches the left edge of the envelope stack.
  6. For size Invitation A2 and C6 Envelopes, press the inside of the paper length adjuster handle to release and lower it.
  7. For all sizes of envelopes, push the paper length adjuster in toward the envelopes until it stops. Make sure the envelopes are flat in the lower tray and not bent.
Set up the Printer Properties
  1. Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  2. Select the Paper or Setup tab depending on the version of the printer driver software.
  3. In the Paper Options section, select the desired envelope size from the Paper Size drop-down box.
  4. Click OK.
Print Print the envelope from your chosen program. From most applications, just select the File menu, then choose Print. After Printing the Envelopes Reset the printer and the printer properties for the kind of printing you will be doing next.
  1. Remove any remaining envelopes from the lower (IN) tray.
  2. Slide the paper width adjuster to its leftmost position.
  3. Load the desired paper into the lower (IN) tray.
  4. On the computer, Select Start on the taskbar. Choose Settings, then Printers. Right-click the printer. Select Properties from the pop-up menu.
  5. Select the Paper or Setup tab depending on the version of the printer driver software.
  6. In the Paper Options section, select the desired paper size from the Paper Size drop-down box.
  7. Click OK.
Jan 19, 2009 | HP LaserJet 1600 Printer
How to change a cartridge on c4345
Installing new cartridge:
If you are putting in a new cartridge, make sure to remove the tape.
Turn on the unit, then open the print carriage access door. The print carriage moves to the center of the unit.
Fit the cartridge into the proper carriage.
The carriage with the gray latch is for the black ink cartridge (HP 56), or the optional photo cartridge (HP 58).
The carriage with the blue latch is for the tri-color cartridge (HP 57).
Slide the cartridge into the carriage at a slight angle, as shown in the illustration above. When the cartridge is fully inserted into the carriage, rock it upright.
When the latch is fully lowered, release the hinged flap. It should catch under the tabs on the carriage, as shown in the illustration.
The LCD display may indicate that the cartridges need to be aligned. Press Enter on the front panel. You may discard the alignment page that prints.
Remove cartridges:
Press down lightly on the top of each ink cartridge latch and pull the lower section of the latch out to release the cartridge.
Pull the cartridge out of the print carriage and relatch the empty print carriage. The print carriage may move to the right automatically, and if the latch is up, it could be damaged.
Nov 26, 2008 | HP Office Equipment & Supplies
Mfc-420cn paper tray
Your paper tray is complete. The lifting section doesn't look as if it fits properly, but it's only there to keep finished prints from getting pulled back in with plain paper.
Mar 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Jura Capresso Impressa F9 Espresso Machine Logo
2,606 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
