Question about Dryers
Gas dryer i had a gas leak and the gas man turned my gas off then fixed the problem and now my dryer will not turn on { gas leak had nothing to do with dryer} i know i have to light the piolet but is there a button i have to press and the time of lighting?
    Problem Solver:
  • 29 Answers
I have the parts, if it is a 40 year old pilot light model
Posted on Dec 03, 2011
  • 240 Answers
First, let me be sure that you have a pilot light on this dryer. Most dryers (even the older ones) use an electric ignitor to ignite the gas flow. This ignitor will glow red or orange, and a flame sensor will start the flow. If you are not sure that you have a pilot light, try starting it a couple of times and let it run for about 30 minutes. These units sometimes get air in the lines (especially if they were opened for repair) and the air has to get purged from the system before it will light completely. Let me know for sure about the pilot sysem, because they are so very old, you usually cant get parts for them anymore. Thanks!!!
Posted on Jan 25, 2008
Gas valve wich way do I turn knob to install my Kenmore elite dryer
If a gate valve: Turn the valve clockwise to turn OFF the gas.
If a ball valve: Turn the valve handle perpendicular to the valve body to turn off the gas.
Install the dryer. Attach all lines.
Turn gas on.
Using a soap/water combination, spray all gas lines to check for leaks. If any bubbles form, then turn the gas off and seal all leaks.
If you do not know how to perform these functions safely, then pay a qualified technician to prevent a gas explosion.
gate-oqy5fah40apqzze5k2tsaxfy-2-0.pngGate
ball-oqy5fah40apqzze5k2tsaxfy-2-2.pngBall
Feb 05, 2018 | Kenmore Dryers
Smells like propane gas in wash room.
Turn off the gas to the dryer and then get a spray bottle with soapy water solution in it... turn the gas back on and spray all of the connections in the gas piping... when you get bubbles, you have found the leak...fix the leaks and recheck with the soapy water...
heatman101
Jan 27, 2011 | Dryers
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Hooking up my dryer
There is no pilot light on your dryer it sounds like you have a gas leak somewhere. Get a cup put alot of dish soap in it and a little bit of water and apply it to your fittings in the back. If you have a gas leak it will bubble up. If this is a used dryer you may have a damaged gas valve or another internal leak.
Jan 22, 2010 | Estate TGDS840JQ Gas Dryer
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
Tood my D52W20 to Repair man and he said not worth fixing.
The repair man doesnt know RCA 's very well. The 3 x then out power led is the classic sign of the flyback and cp150 needing to be replaced. You need the flyback # 259296 and the CP150 you can get the flyback and cp150 at the following link with free step by step instructions with pictures on how to do the repair. Its very easy. Heres the link.
http://servicemanuals.vstore.ca/
Mar 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
SMELL GAS WHEN TURNED ON
have you gas man check the level ! They have a leak meter that will tell how bad if it is a problem or not. Any other way I can help,
Dec 15, 2008 | Whirlpool LGR4634J Gas Dryer
Gas dryer
there is a little hole bottom left, turned dryer on its all dark in there, if its the igniter how much for a repair man to fix it kenmore 70 series????? please respond any thing else that could be wrong. thanks never would of looked there.
Mar 24, 2008 | Dryers
Kenmore Dryer will not start
my kenmore dryer 80 series wont start the start switch just buzzes and the drum does not turn i put a new switch today vacuum it and check all belts they seem fine dont know what else to do
Jan 08, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
196 people viewed this question
Top Dryers Experts
