Question about Ohm L Speaker
4 ohm speakers for 8 ohm impedence on receiver (HT)
I just received an awesome receiver to replace my broken one. It is a sony STR-DE545. My speakers from my old receiver are from a htib sony from 2001. Link
They are rated 4 ohm 100w speakers but the receiver is rated at 100w and 8 ohm per channel on center and rear speakers. I do not know what i can do. I have extra speakers that i can series with the speakers to get 8 ohm but then it gets cluttered. Is there anything you guys can offer?
  • 2 more comments
  • gt50201 Jan 24, 2008
    hmm well good thing you told me that. This other site told me that it would be able to handle the 4 ohm speakers as long as i didnt turn them to theater levels.
  • hapki69 Oct 09, 2008
    I actually have the opposite problem...I have 8 ohm spkrs but my receiver calls for 4 ohm....please advise if this would hurt my new reciever.thanks.
  • vjtrek May 21, 2009
    same as before. car amplifier 4 ohm on 8 ohm speakers, just to fill up the room {on separate sound card}. i havent actually did it but i intent to...tomorow. is it worth it?
  • Anonymous Mar 29, 2014
    just want to know if they are good speakers
    Genius:
  • 1,067 Answers
Ya cant run them 4 ohm on 8 ohm sterio run super hot then fail sooner gota get sum nice 8 ohm ones ok flouece off ebay is relly good cheap 8 ohm
Posted on Jan 24, 2008
  • nick helpap
    nick helpap Jan 24, 2008
    ya see ya maby ok but after wile doble the heat and load on amps ok no good
  • nick helpap
    dont forgeto mark this as fix ya ok
Str-de545 sony not putting out sound to rear speakers
From page 46 (Troubleshooting)-
No sound or only a very low-level sound is heard from the rear speakers.
>>> Make sure the sound field function is on (press SOUND FIELD - MODE).
>>> Select a sound field containing the word "cinema" or "virtual" (see pages 28-30).
>>> Adjust the speaker volume (see page 19).
>>> Make sure the rear speaker size parameter is set to either SMALL or LARGE (see page 17).
Jan 11, 2011 | Sony STR-DE545 Receiver
Sony str de545 5.1
Make sure the subwoofer is set to On in the setup menu. Should be able to access this setting from the front panel, using the click wheel and the left/right buttons above the wheel. Push the setup button to get to the right menu. Set subwoofer to 'on' and speaker size to 'small'. This receiver has a fixed crossover, so make sure to turn the crossover setting on the subwoofer to the maximum setting (highest frequency) to ensure no signal is lost.
Oct 22, 2008 | Sony STR-DE545 Receiver
Protect keeps coming on
Hi;
I used to get this when my speaker wires were touching each other and my 3yr old cranks the volume to Max. Check your Speaker connections you might want to take it all out and redo. Hope this helps.
Apr 20, 2008 | Sony STR-DE545 Receiver
STR-DE545 Receiver -
I just turned my DVD player off when my STR-DE545 was still in DVD input mode and it came up LOCKED, maybe the input that you are using is not receiving a signal?
Feb 03, 2008 | Sony STR-DE545 Receiver
Left channel not working
Probably Broken solder connections in unit. I have seen these units have many poor broken connections throughout amp espcially around poweramp ic .IC701
I have a service manual if you are interested in it kstahl65@att.net
Jan 14, 2008 | Sony STR-DE545 Receiver
Sony STR-DE545 5.1 not working
Are you connecting from your DVD player to receiver using an optical cable or simple AV cable?
Nov 06, 2007 | Sony STR-DE545 Receiver
Problem with 'central' speaker output
took apart my reciever and found that the blue relays in back in the middle are starting to malfunction. I tapped on them and they clicked. When I tapped the right one, i got the sound back in my center speaker.
Oct 30, 2007 | Sony STR-DE545 Receiver
Sony STR-DE545 receiver
You should have access to receiver's format from remote or front panel. If the unit was moved around a lot and for a long period, the micro-processor may have locked due to ambient static electricity. Try unplugging unit for seversl hours, then re-try
Aug 19, 2007 | Sony STR-DE545 Receiver
The STR-DE545
Check for faulty speaker wiring and connections
Jul 29, 2007 | Sony STR-DE545 Receiver
Ohm L Speaker Logo
1,123 people viewed this question
Top Ohm Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ohm Audio Player and Recorder Expert? Answer questions, earn points and help others
