Question about Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum
Hoover steamvac m/f5881-900
Solution runs out of tank while unit is on or off
  • bill wilkinson Jan 28, 2008
    thanks for your interest. i think my problem is the valve that is operated by the trigger
    rod.i plugged the large outlet from this valve,installed a tee in the large line to connect
    it to the smaller hose thereby controlling the solution tank discharge with the
    trigger rod valve and it works fine. it discharges the solution into a distribution manifold
    above the brushes and onto the scrubbing brushes and it works great.my daughter
    cleaned her carpets last night with no apparent problems. thank you!
    President:
  • 1,673 Answers
Check to make sure that the seal is is on the reservior asm. that is what the tank sits on. With the tank off, pull the trigger and see if the reservior asm. is moving up and down, won't move very far, if not then it will need to be replaced. Check the valve at the bottom of the tank, push it in and see if it comes back, maybe it is stuck open and not closing.
Posted on Jan 24, 2008
6ya staff
SOURCE:
We have a Hoover Steamvac F7452 that is leaking water from the bottom of the machine. If we place the water tank on the machine, water immediately starts flowing through to bottom of the machine. It'
When you put the tank on it connects with the unit and opens the valve on the bottom of the tank to allow the water to flow check for debris hair etc around the connection, it is possible the seal itself is worn or bad and needs replacement but I think the trigger only lets air in the tank so the water will flow out by gravity, I'm not positive on this but mine works that way.
Oct 19, 2014 | Hoover F7452-900 SteamVac Upright Vacuum
Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Jun 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
My hoover steamvac wont **** up dirty water float
Check your filter screen insde the upper tank. if your model has a wrap around filter try to pull it down about 1/2" to maximize air flow.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Apr 15, 2010 | Hoover F7431-900 SteamVac Vacuum
I have a Hoover V2 Steam Vac widepath and the
This is a notorious problem with the Hoover V2 SteamVac's. In fact the tank design by Hoover on your SteamVac was so bad, that Hoover redesigned this tank almost immediately due to the numerous problems customers were having.
For your particular problem, you really have two options. The first option is putting a bandaid over the problem, but will still fix it. We sell the entire gasket assembly on the bottom of the detergent tank as a replacement part. Unfortunately it's sold together with the seal, spring, and valve together as an assembly;
http://www.govacuum.com/hoover-steamvac-dual-v2-tank-valve-part-43513015.html
You also may wish to fix the problem completely by replacing the entire clean water solution tank. Hoover has redesigned this tank, and the new one I don't see near the amount of problems that I do on the older style tanks. The plastic is much more sturdy, and less prone to having the gasket and valve issues that the old tanks do. It's important to point out that the new tank does not come with the handle. You'll need to remove the handle from your old tank if you buy a new tank assembly complete. Rest assured that if you do purchase any part from GoVacuum, you'll have 60 days to return it for a full refund, just in case the repair doesn't work. Not only do we not deduct restocking fees or shipping charges, but we also include a return label with every order that you may use to return any item to us, and we'll even pay for your return shipping!
Here's the Hoover SteamVac V2 Clean Water Solution Tank, Part 12002549
If you'd like us to do a repair photograph series on this repair of the valve and gasket assembly, please just request a repair clarification here on Fixya, and we'll be happy to do so. If you found this helpful, please be sure to rate the review as helpful by clicking on the 4 Thumbs Up Icons in the top right hand corner of the repair.
Thank you so much,
Chris J.
GoVacuum
Mar 23, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Hoover steamvac F5826-900 leaks from bottom wheni put tank on ple
You may need to replace the gasket.if that dont work replace the whole tank
Aug 01, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover F5858-910 doesn't spray water
Hello dc42 & osuguy101. I suggest using a cleaning solution, 50/50 vinager/water, in the fluid tank to clean the ports. #2 Unit may have a fluid pump problem. Please update me on results.
Sep 26, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steamvac Deep Cleaner
http://geeksquad.fixya.com/ThreadView.aspx?prdid=40578&thid=661545
Hoover SteamVac Deep Cleaner
Posted by Alex987 on Jun 10, 2008
I can't seem to figure out how to use it =(
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover F5807 SteamVac Wet/Dry Vacuum. Well, there are 2 tanks, one is the water solution tank that is on top and the other is the water recovery tank of which is on the bottom. You use the trigger assm to release the water and the Hoover SteamVac works the best on the pull back. You can spry the water going forward but pull it back very slowly and let the brushes do the scrubbing for you and the dirty water pickup. There is a ball in the dirty water pup tank that will rise to the top and stop the water from coming in, @ that point you need to empty and rinse out the recovery tank and re-install. If you run out of solution the top tank cap or cover is the measuring cup to determine the amount of solution – usually it is one cap full and extremely hot water, there is a switch for the carpet and the upholstery, if the handle is in the released position then the brushes down below should be moving – just look in the brushes window and see if they are moving – if the handle is in the upright position then you can remove the attachment hose and then use the attachment and the revolving brushes will stop. I hope this will help you in working with the Hoover SteamVac. If not contact the Hoover Co and get an owner’s manual and give them the model # and serial #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 10, 2008 | Hoover F5807 SteamVac Wet/Dry Vacuum
Leaking Hoover Steamvac
Either you have a crack in the tank and it is running down the indise of the handle and going out the bottom, or there is a water line off either under where the tank sits or under the top cover.
Mar 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Replacing valve on water tank on hoover steamvac
buy the whole tank not worth the time to repair the valve
Oct 08, 2007 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
119 people viewed this question
Top Hoover Vacuums Experts
Kirk Thompson
Level 1 Expert
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
