Monitor will not function properly
I can not get my samsung monitor to perform properly. I reciently experienced a problem which destroid all drivers,and software for my samsung syncmaster753df. I have no boot or start disc.
  • 48 Answers
Well that sucks.. i suggest you should acquire a boot disk.. you can create by yourself using another person's computer like your friends or office colleague.. then you can boot up on your pc and reinstall your operating system...
Posted on Jan 24, 2008
Samsung syncmaster t190
I would try another monitor to see if your system is functioning properly. I think your monitor is going bad on you. If the other monitor that you barrow is working fine on your system then I'll be looking for another monitor.
Mar 30, 2012 | Samsung Computers & Internet
Monitor screen shows side to side display instead of up and down. How do I return to up and down display
Dear,
To rectify your problem, Perfrom these steps.
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove both Digital (white connector) and the Analog(blue connector) cables from the back of the computer.
  3. Turn on the monitor.
Mar 13, 2012 | Dell E228WFP Monitor
If i select source to pc display will become blank and power indicator blinking.
• You can check if the product is working properly using the Self-Diagnosis function.
• If a blank screen is displayed and the Power LED blinks even if the product and the PC are properly connected, perform
the self-diagnosis function according to the procedures below.
1. Turn the product and the PC off.
2. Separate the signal cable from the product .
3. Turn the product on.
4. If the product is working properly, the message appears.
In this case, if a blank screen is displayed again, make sure that there is no problem with the PC and the connection. The
product is working properly.
Is a blank screen displayed and does the power LED blink at
a 1 second interval?
1. This occurs when the power saving function is running.
If you click the mouse or press any key, the screen will be
turned on.
2. This occurs when two monitors are connected,
is and Magictune is running. In this
case, characters on the Magictune OSD may appear
corrupted. To run the Magictune, the must
be set to . Please restart your PC, set the
to and run the Magictune.
Jul 07, 2011 | Samsung BX2231 21 inch Monitor
My monitor is hooked up properly but for some reason it won't display
The function keys across the top when the computer is "firing up" will trip the very base level of the computer operating system. Suspect the correct driver is missing, thus if you can reset it here, you will be able to see enough to get on the web. On the web search for drivers, or go straight to Samsung and download and install the proper driver, than reboot.
Aug 19, 2010 | Samsung SyncMaster T200 LCD Monitor
My samsung 940N acts like a florescent tube, tries to start and doesn't
Use the self test feature.. follow the steps..
1. Turn off both your computer and the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or
damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly.
Warning
The Power supply inside the monitor can be hazardous and donot open the monitor while power on.
Donot work with the monitor when it is open and the power supply is on.
If there is something wrong with the input signal, a message appears on the screen or the
screen goes blank although the power indicator LED is still on. The message may indicate
that the monitor is out of scan range or that you need to check the signal cable.
Feb 13, 2010 | Samsung SyncMaster 940N 19 inch LCD...
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
I’m happy to assist further over the phone at https://www.6ya.com/expert/marnin_498840f315fe3361
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung 403T 40'' monitor has no power. (CK40PSNB)
FYI, I have found the real solution for this issue with Samsung 403T. It is a design flaw which leads to this problem after a while. Luckily, it can be easily corrected, but it requires medium soldering/electronics skills.
Anybody interested in how to fix it feel free to email me and I'll provide you with the solution. Please make sure that the symptoms of your monitor are exactly the same with the ones described above.
Mar 25, 2009 | Samsung 403T 40" LCD Monitor
Samsung 794mg --- problem in monitor screen --- uneven colour mix
sounds like the monitor experienced being close to a magnetic field.
if the monitor doesn't have a auto degaussing (demagnatise) function on start up, then try using the degaussing function on the monitor (in the menu somewhere).
if no good, then you can try moving/waving a magnet near the affected area. b careful! slowly wave the magnet from a distance 1st, until you have improvements. too close and it will change the colours further!
Feb 13, 2009 | Samsung 793DF 17" CRT Monitor
Dell172fpb 17" monitor
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Is it my monitor or my video card
1.there might be a problem with your signal cable. if one of the pin in the signal cable is open. it might also happens
2.adjust signal cable.
3.Check VGA video card is working properly. unplug the VGA card and Re-plug to its slot. if your mother borad has inbuilt video card. this process cannot be performed
4.Even problem with operating system might also happen.. problem with Video Ram memory
5.if you want to check whether your monitor is ok. just get Cpu Box alone frm friends for a while for a testing.
6. if your monitor have problem then contact service centre.
Oct 15, 2007 | Samsung SyncMaster 551 15" CRT Monitor
Computers & Internet Logo
42 people viewed this question
Alun Cox
David Payne
David Payne
