Question about Kenwood KDC-MP2035 CD Player
Playing an Ipod
After plugging in the Ipod to the frony 3.5mm hole in the Kenwood faceplate , how do I get the Ipod to play ? Is there a button or setting I must use?
Ya press src until it gets to standby then hold the menu button until it says menu. then press the toggle button down until you see aux and press the toggle to the right to turn it on and be sure to press menu again to set it.
Posted on Jul 17, 2008
  • arturorivera May 28, 2011
    all i can said is: ................................thank you guys for your help !!
    Scholar:
  • 75 Answers
You should have to hit your SOURCE button and that should change your head unit between CD,FM,AM, and AUX. You will need it on the AUX setting for it to play.
Posted on Jan 24, 2008
Kenwood/iPod problem
I expect that this is controlled by your ipod, not the Kenwood. I suspect that when you did the upgrade, it has reset the player to default settings and start from the beginning each time. Go through the setting on your ipod and see if you can find it.
Jan 07, 2018 | Kenwood Car Audio & Video
How do I unlock my Kenwood KDC-MP528 car stereo
To reset the code do the following:
1) Turn on the car.2) The faceplate rotates out and the CODE - - - - prompt appears.3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
For further assistance please let me know.
Feb 17, 2012 | Kenwood Car Audio & Video
I drive a Freightliner Argosy prime mover with a kenwood tuner. Don't know what model. Can't get my ipod to work although I believe it is supported. How do I get the "AUX" function?
Press and hold B.BOOST button for at least one second. This gets you into the settings menu. Use the rotary control to go up and down until you reach the setting for AUX On/OFF and toggle to on. Now whenever you press the source button AUX should be one of the options displayed. The ipod plugs in using a 3.5mm to 3.5mm stereo cable and the input is on the bottom right of the faceplate. Cheers, Dan
Apr 28, 2011 | Kenwood KDC-138 FM / AM Receiver
How do you get it in auxilary mode
if you have a device (iPod etc) plugged into the front aux hole, and playing, you hit the SRC button until you get to the auxilary function.
Apr 10, 2010 | Kenwood KDC-135 CD Player
Playing ipod on kenwood
This happened to me. What worked was turning off the ipod (not stand by mode). Turn it back on and plug it in, it should work.
Mar 06, 2010 | Kenwood KDC-MP235 CD Player
Unable to remove faceplate or eject cd on kenwood
remove the to of the unit, then the two in the actual cd player, pull out cd player, there will be two more screws,these hold the faceplate assembly in place, remove them. This will allow you to pull a small plastic hook down to let the face plate slide out. then remove the face plate from it's holder, slide it out. Remove the four screws on the back of the faceplate inside the there is a very small piece of plastic that has a hole at one end and squared at the other. This is the problem causing piece. I suggest super gluing this piece where it attaches to the inside of the faceplate. This should fix the problem.
Jan 17, 2010 | Kenwood KDC-516S CD Player
How do i play my ipod? i have the plug and i plug it in and it dosent do anything.
ARE YOU USING THE USB OR JUST THE HEADPHONE SOCKET?
IF YOU PRESS THE SOURCE BUTTON IT WLL SEE THE UNIT ATTACHED UNLESS ITS THE USB PORT BEING USED, IN THAT CASE THE SOFTWARE IN THE KENWOOD IS NOT COMPATABLE WITH YOUR GENERATION IPOD
Dec 24, 2009 | Kenwood KDC-MP335 CD Player
My kenwood KDC-MP342U stopped reading my ipod i just got it within the past two weeks and it was working fine and the all of a sudden when i pluggedd my ipod in all it says is reading. i have tried to use...
I had the same problem with my first gen ipod touch. The reset button is on the front panel, between the Fast Forward button and the "1" button. Push it with a pen or something with the unit turned on. It will go dark then come back. You'll have to set up your preamp and other stuff again. I also now push the eject button before removing my ipod or USB thumb drives. The display will flash "remove". I guess this does some handshaking that cleans things up before removal.
Oct 18, 2009 | Kenwood KDC-MP342U Car CD Player
Get no sound from rear speakers WITH ipod
I have exactly the same problem - don't work with CDs either, just radio. Just installed the deck yesterday. Help would be appreciated. Have been through the manual front-to-back.
Aug 09, 2008 | Kenwood 50W x 4 Apple iPod -Ready MOSFET...
Kenwood KDC-MP2035 security code
yo tengo un reproductor kenwood kdc-mp2035cr pero este no me reproduce nada solo me sale un mensaje que dice protect y no me deja hacer nada ni colocarle nada por el auxiliar
Jun 05, 2008 | Kenwood KDC-MP2035 CD Player
Kenwood KDC-MP2035 CD Player Logo
122 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
