Question about Haier HTF20R21 20" TV
Haier HTF20R21 20" flat screen
The word FACTORY in red letters is in the middle of the screen and is on every channel
Factori on my tv haier
Posted on Mar 17, 2009
In google search, type in the words "the word "factory on my tv", and it comes up with solution..it worked first time for me!.. Bill
Posted on Sep 03, 2008
Haier L32A2120 flat panel Keeps channeling and does not stop when using remote
Sounds like main system control memory IC is faulty. Anyway, do a reset to this set and check. It it too do not help, replace the memory IC
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Aug 23, 2014 | Haier L32d1120 32" 720p Lcd Tv - Hdtv Usb...
My brand new flat screen haier tv 39'' is flashing white then red green then blue and black screens how do i fix
Try to disconnect the set and a box if being used from power for a while and then power both back as either could cause this problem.
Dec 15, 2012 | Haier Televison & Video
Black box in middle of screen/picture
Closed Caption function to that channel you select is ON. Make it OFF, when you are in that channel which displays this black box. It will be best to reset the TV to its factory settings first, and then re-tune it. for more details, refer its user manual.
Jul 10, 2012 | RCA L32WD26D HDTV/DVD Combo
Where is the auto convergence button
Hello
From it menu option, suf through and come to automatic convergence display option and press Ok button on the remote control.
The List & Labels part of the setup lets you edit your channel list and choose or create a
personal six-character label for each channel.
Note: Changing List and Labels can be time consuming. You can change these at a later time by accessing the
Setup menu.
1. Press the left or right arrow to scroll through the available channels and choose the
channel you want to edit.
2. Press the down arrow to highlight the In channel list option. Press the left or right arrow
button to add (the box is checked) or remove (the box is unchecked) the channel from the
list.
3. Press the down arrow to highlight the Channel label option. Press the left or right arrow
button to scroll through the available list of 25 most common labels. The last option in
the list allows you to create your own six-character label for the channel (the first letter of
the label is highlighted).
4. Press the 1 or 2 number button to change the first letter of the label.
5. Press the right arrow to highlight the second letter, then press the 1 or 2 number button
to change the second letter, etc...
6. When you are finished creating your label, press OK. For model D34W20, your TV tunes to
the last channel available in your channel list. For models D40W20 and D52W20 only, the
Auto Convergence menu appears next.
Auto Convergence (for models D40W20 and D52W20 only)
Your TV's picture tubes might have been disturbed during delivery or after you moved the TV,
causing the color in your TV to be out of alignment. The colors adjust by starting auto
convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu appears. The
cross in the middle of the screen should be yellow. If it is not, use the arrow buttons to
move the red cross to overlap the green cross. Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle of the screen. If
it is not, use the arrow buttons to move the blue cross to overlap the green cross. Press OK
(the TV tunes to the last available channel in the channel list).
Ok
Mar 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I retune my Samsung DNLE DV3 tv for freeview?
I have a Samsung DV3 and appear to have solved the problem more by luck than judgement! I turned on, pressed the button marked D.Menu (red lettering around the middle of my remote control). I then moved down one slot to the picture of the sat dish on the screen then across to auto store and across again. I then pressed ok to start and it WORKED!!!
Good luck it worked for me!!!
Jul 17, 2009 | Televison & Video
HTF27R11 factory on screen
Have a look at link below perhaps your manual helps to reset it
http://www.retrevo.com/samples/Haier-TV-manuals.html
Jul 29, 2008 | Haier HTF27R11 27" TV
Sound no picture
If you have the 3 RCA jack cables connected to the input jacks on the TV press input on the remote until the picture appears.
Apr 13, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Haier HTF20R21 20" TV Logo
255 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
