Question about Lands Phones
Olympia conference phone - wireless
No dialtone...cannot call out. Tried other jacks...same problem. Tried other house....same problem. I think the phone is made by wave industries...any advice
This sounds like its a digital phone that is used with a PBX or key system and not for use as a home phone.
Posted on Jan 24, 2008
6ya staff
SOURCE:
Olympia ap 1000 manual
You may download a copy of the manual here.
Feb 03, 2013 | Olympia CDP 24201 Cordless Phone
I have a Wireless Conference Phone 2.4GHZ manufactured by Olympia. The Manual says that the battery must be charged for 15 Hours. Once the battery is charged can I leave in the Battery Charger for Constant...
It is always safe to remove once it is done. You have cut off circuit in your device but over exposure may weaken the circuit. Please rate me if you lik this!!
Aug 17, 2009 | Wave Industries OLY-OL3000 Globe Phone
It only light up when i pickup the receiver
Just went through the service manual for your product & you have an LCD display unit, this won't go bad overnite this is definately a faulty product... You will have to return/replace the phone .. there is a service tag number at the flip side of your phone ... i am sure you will get the warrenty back with it.
Olympia OL2112 Single-Line Speakerphone:
· Corded Phone
· Single-Line Operation
· 6 Programmable Buttons
· 400 Name/Number Directory
· Digital Full-duplex Speakerphone
· Large 4'' x 2'' Backlit LCD Display.
· Modular Direct Connect Headset Jack
· Message Waiting Indicator
· Conference Calling
· Caller ID
· Mute
· Part #: OL2112
FAME !!
Jun 29, 2009 | Olympia OL2112 Corded Phone
MITEL 5303 Conf Ph
These are analog only phones using a POTs line if you've connected everything properly and all the cables are in fine condition no broken conductors or anything it should work. If the keypad lights up you only need to hit the very buttom button and you should get a dialtone. To make a call you may need to dial a 9 or 909 (depending on the phone system programming) to get an outside line if this connected on an anolog line through a PBX. Probably first test it using a working faxline. If you do not get a dialtone and all cabling looks good it maybe that keypad got dropped. I have one that has been knocked off of a table - someone tripped over the cord - noone will admit it but through testing I've discovered it's in the keypad end, symptons being no dialtone.
Jan 28, 2009 | Mitel 5303 Conference (50001905)
No dialtone
If you use Dsl as a internet provider make sure you have the filters on each phone. If you use cablevision and have a wireless connection make sure you chage the phone to a 5.2ghz because you might have the wireless router with the same ghz causing a coflict. This will also create loss. of internet connections then you use the phone
Jan 19, 2009 | Panasonic GigaRange KX-TG2432 Cordless...
My house phone is not working
Unplug all phones in your house- all of them. Wait 5 minutes then plug a phone in a try it again. You probably have TIP n Ring reversed ( Red and Green wires) or your hookswitch on the phone is bad. If you do get dialtone after you wait 5 minutes and can hang up and get dialtone back get a new jack and try that ok
Nov 13, 2008 | Motorola Lands Phones
Phone calls drop after an hour
try in radio shack -take it and go there and ask for a new compitable one(it does not matter if more in amp)-same voltage-same dimenshion are important
Jul 22, 2008 | Olympia OL6010 (olyol6010) Audio...
No dial tone
please go to line outlet of phone in wall and connect any phone if you get duial tone-check you cable to machine-and then repeat your setup.
Apr 01, 2008 | Olympia OL6010 (olyol6010) Audio...
Please Wait....
push 1.4.and 9 all same time . i read this post some where and it worked great
Jan 08, 2008 | Polycom SoundStation 2W (2200-07800-001)...
No long distance
hi i dont think the problem are in the phones call your phone supplier and ask about it good luck
Nov 07, 2005 | Vtech EV2653 Cordless Phone (73507800685)
Lands Phones Logo
91 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
