posted by emjeng63 on Jan 23, 2008
How do I use Jensen SC-570 Remote on my Emerson DVD player tv. I do not have the code.
Best Solution
posted on Apr 04, 2008
Try the auto code scan:
The Auto Code Scan feature allows you to set up your components without having to enter in code numbers. The Jensen will do the work for you! (It may take a few minutes to find your code using this method.)
Turn on the component that you want to set up.
Hold the component key down until the light comes on. The green light should come on after approximately 3 seconds.
Release the component key.
If you are programming the DVD or CD device press the "action" key. The red indicator light will come on.
Press "0" - "9" The green light will blink as codes are sent.
As soon as the remote turns your component off, press the "action" key. (You have 1 second in which to press the "action" key to save the code.) The component key lights will blink with an upward motion when a code has been successfully entered. The component is now programmed. To find that code, proceed to Code Readback.
If none of the codes turn your component off, return to step 2 and start over.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Jensen SC-570 Remote Control
Email this problem
Email this problem
Can you Help with these Remote Controls problems?
Remote Controls
remote control for sylvania tvk...
new batteries have been placed.... Answer This...
what the code for coolsat 6000
what the code for coolsat 6000 Answer This...
Repair Service
Find Remote Control Repairman Near You:
