Question about Canon MultiPASS F80 All-In-One InkJet Printer
Copier not functioing correctly
My copier won't copy correctly. I put a page to be copied on the platen and press the start button and the copier pushes the paper through but no image. No alarm light is on. All this happened after I scanned some pictures to a folder. After this my copier doesn't work correctly anymore.
What do you think is wrong...settings?
  • 97 Answers
Try to referesh the copier, remove the USB cable then turn off it. Wait for 2 minutes turn it on and the plug the usb cable and then observe what will happen.
Posted on Feb 28, 2008
Printing Result of an A4 Master Page is Equal to A5
The problem is with the "Automatic Paper Size Sensor" / APS sensors, which are located near LENS / CCD UNIT, under the platen glass.If you can open and remove the platen glass by yourself then open it and clean the APS sensors with soft cloth damped with alcohol. If the problem is still there, then please go to the service mode of your photocopier machine.
(Press "Utility/Counter"
then
press "Check Details" > STOP > 0 > 0 > STOP > 0 > 1, for service mode)
When you are in service mode then go to "System 1" and then into "Marketing Area" , When you are in this option, select marketing area "US" and then press "OK" . Now exit from the service mode and place A4 original on platen glass and check the size showing in the display.
Do not worry whatever size is showing, you will get your complete copy.Now press start button to make copies. When you will make a copy you will get your complete print out.No print area will be missing.
Best of Luck!
Apr 08, 2014 | Konica Minolta Bizhub 500...
I need instructions for copyng from A3 size in A4 size
Place A3 Document on platen glass or document feeder. Click copy ratio button. You will get 2 options. (i) Preset:- Press minus key and select 70% (ii) Zoom:- enter 70 manually Press oik Enter no of copies, press start
May 02, 2011 | Canon iR 2020i Laser Printer
How do you enlarge on the HP309A SERIES
  1. Use the following guidelines to determine which setting to choose:
    • Copying an original to letter or A4 paper : Choose Fit to Page , or choose Full Page 91% to prevent unwanted cropping.
    • Copying a legal-size document to letter paper : Choose Legal > Ltr 72% .
    • Copying a photo to full-size paper : Choose Fill Entire Page .
    • Copying to a custom size : Choose Custom 100% , use the Up or Down arrow buttons (c01314741.gif ) to reduce or enlarge the size of the copy, and then press OK .
  2. On the LCD screen, choose Copy from the options (use the arrow buttons) and press OK .
  3. Press the Settings button (the button below the Home button) twice, to access the Copy Settings menu.
  4. Select Size and press OK to access the copy size options.
  5. In the Copy menu, use the arrow buttons to select the appropriate size settings. Press OK to continue.
  6. Press Start Copy Color or Start Copy Black .
Mar 05, 2011 | HP Photosmart Premium C309A All-In-One...
Changed the black printer cardtridge on a canon mp160 and getting errror code E19 when trying to align the heads...any idea why, and how to fix please? Thanks
This error idicates that the size of the document cannot be correctly detected or the document is too small when the Fit-to-Page copying is selected or the unit Failed to scan head alignment sheet correctly.
The remedy is
Make sure the document meets the requirements and correctly loaded on the Platen Glass. Then reload the document and press the Black or Color button.
Check that all necessary circles are filled in the Print Head Alignment Sheet, and that it is placed in the proper position and orientation on the Platen Glass. You can also perform print head alignment manually.
Sep 30, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Double side to single copy w/o paper feeder
Try this.
Set the copy for duplex.
Put the drivers license on the glass.
press the start button.
Turn drivers license over.
Press the start button.
Should copy on both sides of sheet.
If you copier has a booklet setting on it in the duplex. Page the front and back of the drivers license will appear on the same side of the page as well.
Jan 13, 2009 | Minolta DI2510 Black and White Copier
Stacking
If you have an ADF, please put the 35 originals in the ADF and just press the Start button.
You will have 35 copies in the output tray.
If you don't have an ADF, please put one original on the platen glass, close the platen cover and press the start button.
Then replace the original by the 2nd one and continue the rest of the procedure and do also for the remaining originals.
Good luck and please rate me, thanks.
Oct 31, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
Platen is open message, What is the platen?
Platen is usually referred to as the Copy glass ( Platen Glass) this is where you lift the top to put it onto the glass to make a copy.
Never heard of this message , was it serviced? usually the techs open it to clean the Optics (mirrors) inside.There should be a metal plate with 2-4 screws that hold it.
Aug 28, 2008 | Canon imageCLASS D761 Copier
HP 1210 all in one printer does not have a maintenance button to allow me to align cartridges. Prints landscape pages out of alignment; I have tried taking the cartridge out and putting it back but it...
On the printer hold down the CANCEL button then press and hold the ON/RESUME button until the CHECK PAPER and CHECK PRINT CARTRIDGE LIGHT both blink simultaneously.
When both lights are blinking press CANCEL, COPIES, PAPER TYPE, and COLOR START COPY one after the other. All this must be done in under 10 seconds for it to work. Once this sequence of buttons is completed correctly in under ten seconds an alignment page will print.
Apr 09, 2008 | HP Office Equipment & Supplies
Scanning on an mp500
First you should have installed the scanner in the computer using the cd comes with the scanner.
  1. Confirm that the printer is powered on and press the <Open> button. (The paper output tray will open.)
  2. Load paper in the auto sheet feeder or the cassette in the portrait orientation.
  3. Lift the document cover and set a document on the platen glass.
    MEMO:
    - Regardless of the document size, set it in the landscape orientation.
    - Place the copying face down on the platen glass.
    - Align the document with the alignment mark (shown as the arrow) on the lower right corner of the platen glass.
    Note: The machine cannot scan the area approximately 3 mm from the front and right edges of the platen glass.
    < 1 > Alignment Mark
  4. Close the document cover gently.
  5. Confirm that the printer is in Copy mode. If the printer is not in Copy mode, press the <COPY> button to switch into Copy mode.
  6. Check the copy settings, following the procedures below carefully.
    < 1 > Check the paper size and media type.
    < 2 > Use the up / down cursor button to specify the number of copies.
    < 3 > Use the right / left cursor button to adjust the intensity.
    Memo: Pressing the right cursor button increases the intensity. Pressing the left cursor button decreases the intensity.
  7. Press the <Color> button for color copying, or the <Black> button for black & white copying. (The printer starts copying.)
    Note: To cancel copying, press the <Stop/Reset> button.
Apr 02, 2008 | Canon Pixma MP500 All-In-One InkJet...
Copying using the Duplex function
Press on duplex button and scan your originals one by one on the platen mode (exposure glass). You cannot use the ADF for this function.
After every scan press the Start button.
After the last page please press the enter button as displaying in the display.
Then the copier itself can finish making duplex copies as you wanted.
Nov 27, 2007 | Ricoh Aficio 1515MF All-In-One Laser...
Canon MultiPASS F80 All-In-One InkJet Printer Logo
47 people viewed this question
old marine
old marine
