Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Timing belt allignment for a 92 ford escort 1.9 litre............ HELP ME!!!!!!!!!!
    New Friend:
  • 101 Answers
Timing for the 1.9 is simple. With #1 on compression stroke, just line up the dots on the cam, oil pump, and crank.
If done correctly, the crank sensor should be in line with the 9th tooth from the gap in the crankshaft sprocket. rating please
Posted on Jan 27, 2008
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 29, 2008
    did i help you ? if so rating please.
Need diagram for replacement of serpentine belt for ford escort 1998 4litre engine double overhead cam. also need belt size or number
must be a special ,never seen a fords escort with a engine bigger than 1.6 litre on a petrol or 1.8 diesel
Nov 25, 2010 | Ford Escort Cars & Trucks
2 litre ford timing belt diagram 2000 escort zx2 (dohc) .is belt failure always catastrophic
This is a non-interference engine. Anyone saying anything different is using an old book. Some Ford dealers might even tell you it is interference. There are reliefs cut into the top of the pistons to clear the valves if the belt breaks. There is a how-to posted here and on Team ZX2 .com
Aug 14, 2010 | 2001 Ford Escort ZX2
How to change timing belt on a 1987 ford ranger 2.0L 4C 5speed
You need to get a manual. Try the Haynes manual for your car. Try autozone; generally available for around $20. This is not the type of thing that can be covered here in enough detail to do you any good.
Buy new timing belt. Disconnect negative battery cable. Remove timing belt cover. make sure cylined #1 is set at TDC. making sure all componets are properly alligned and losen tensioner to remove old timing belt. Install new timing belt. Tension belt, ensure all components are alligned properly, replace timing belt covers and reconnect battery.
Feb 21, 2010 | 1987 Ford Ranger
Serpentine belt routing diagram for 2000 ford taurus 3.0 litre vulcan
My apologies for the delayed response. I am going back to answer unanswered questions.
CLICK
on the following LINK. It has the Serpentine Belt Diagrams you will need.
If you would: Before Clicking let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my sincerest apologies...
Thanks!
http://www.2carpros.com/car_repair_information/year/1999/make/ford/model/escort/1999_ford_escort_drive_belt_routing_diagram.htm
Feb 01, 2010 | 1999 Ford Escort
What is the capacity for a crankcase (with oil filter) for a 98 ford escort se?
normally it should take not more than 4 litres of oil,first put in 3.5 litres,run you engine and check the dip stick,if still low,put in another 1/2 a litre,then it should be right
Oct 20, 2009 | 1998 Ford Escort
Power steering pulley on ford escort van 92 has
you will need power steering pully puller you can rent them at most of your local part house or you can buy them there you will need to pull of belts then the pully hope this helps
Sep 28, 2009 | 1992 Ford Escort 4 Door
Timing Belt Replacement+Diagram
How to replace engine belt 1999 ford escort
Oct 29, 2008 | 1999 Ford Escort
Car Audio & Video Logo
207 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Marvin
Marvin
RegWorts
Level 1 Expert
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
