Question about Sceptre X9G-KomodoV (Black) 19 inch LCD Monitor
Getting the monitor apart
I have a scetre x9g-naga III monitor that goes off when it's on for a few minutes; shut it off and turn it back on a perfect picture for 2 seconds. itried to take it apart to look it over and i can't get the thing apart. i got all the screwws out but i assume that it is clipped some how? how do ya get the thing apart? thankyou for listening
  • gadget-hq Dec 12, 2008
    i can't get it open? removed the four screws, is there a screw under the centre label - ive felt around it feels like it, removed it and it was a plastic blank (indented) hmn anyone know if there is a screw under the plastic?
Snap it apart ,it is cliped together ,after you take out the screws, no hidden screws
Posted on Mar 05, 2009
  • 171 Answers
It is clipped on, or there is a hidden screw underneith a sticker or something.
They make these things hard to disassemble for a reason. There is very little you can do one you've got it open. There's almost nothing inside that can be serviced by any normal user.
Posted on Jan 25, 2008
I recently acquired a sceptre x9g Naga V monitor which has developed a problem. It produces a wonderful image which may last 5 min or 5 sec, then goes black. If I turn it off or unplug the monitor the...
It may have dying power supply due to bad DC filter caps like the 17" version.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for:
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 30, 2010 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
Feb 19, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
When on its shuts off by it self after a few minutes.Then comes back on after I hit the on button again.I was given this monitor,so got no softweare with it.What can I do(if anything)to fix this..thanx Ron
rons1photogr, You will need to fix thermal intermittant solder joint and /or bad electrolytic filter capacitors on printed circuit board called "switch-mode-power-supply"/"CCFL inverter supply"???? Software can't fix this problem!!! Hardware refurbistment only. READ, READ, READ, more stuff in my profile on black screen repair s and or other options open to you. 12fixlouie
Jan 04, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
I have a sceptre x9g-naga III
Not an expert, but from what Ive read, this is a cfl inverter issue. I had the same problem on my Sceptre. Good luck finding parts. My solution: get another monitor.
Feb 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
Montior Repeatedly Shuts Off/Goes Black
i have the same problem .
already know what it is .
its the cfl power inverters which are build into the power supply
easy way to see is let the computer start up hold a flashlight up to the screen you should see your desktop .if so its the inverters/powersupply .
just started looking for a replacment for mine the closest i have found is around 25 bucks plus shipping wont know if it will work till monday when i can call them to match up the one i have
Jan 27, 2009 | Sceptre X9G-NagaIV 19" LCD Monitor
X20G-Naga III screen goes blank after 1-2 secs
Device : Spectra X20WG-Naga
Problem : monitor comes on then flickers then goes off
solution: Replace Capacitor C101 (150uf, 35V) and Fets U101 and U102 (4511GM)
Comments: This is a common problem with this monitor.
Oct 02, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
May 31, 2008 | Sceptre X20g-Naga III 20.1" LCD Monitor
Sceptre X9G Komodo IV 19" Monitor
Hi dgp1952, Check with if you want a repair. Something is wrong with your backlight or the circuit supplying power to it. If your technically endowed, you may want to open the monitor case and clean the dust and lint from around the circuits using a Small paint brush to sweep away any built up dust. Dust can cause the circuitry to heat up faster and put the power supply into Clamp mode. Clamp mode will turn the supply off to certain circuits which may be the reason your display is going black after 5 minutes.
Oct 09, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
Sceptre X9G-KomodoV (Black) 19 inch LCD Monitor Logo
718 people viewed this question
Top Sceptre Computers & Internet Experts
Ricky Ostrom
Ricky Ostrom
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
