Question about Saitek Eclipse II
The " T " and the " Y " require more pressure
For some reason, the t and the y started requiring more pressure to get them to type the letter. I keep having to go back and type in the T's and Y's. They work, the just require more pressure that normally used when typing.
  • Anonymous Jun 23, 2008
    All of the sudden, a set of keys in the upper left corner of my Saitek Eclipse 2 keyboard require more pressure to work. The keyboard is clean, non-damaged and this problem just started to occur. The number of keys seems to be slowly increasing. I have found many complaints on other sites of the same problem. The keys I am currently having problems with are the 1,2,3,q,w,e,a,s and d keys. The problem is intermittant, sometimes they work just fine other times not so much. Also it seems that some keys like the e key enter double sometimes. I am about to take it apart and see if there is anything I can do to fix it.
  • Rm4g3dD0v Mar 20, 2009
    I am having the same issue with the R key [which i have to ram to get it to work] and also same happens with E and T, in a lesser magnitude.
It's a design fault - I opened it up to have a look and the bottom plastic plate cracks after just a few week's use.
I suggest a) another non-Saitek keyboard or stiffening the bottom plate somehow.
Posted on Nov 21, 2008
You're not the only one to experience this problem... I too have the same problem and it's EXTREMELY annoying when typing, as I'm a fast typer as it is and I'm constantly having to go back to type in the missing letters!
I've tried popping out all the keys to wash them but to no avail. Unfortunately, it looks like a design fault or something if more than one person are experiencing it.
It's a real shame because it's an excellent keyboard!
My keyboard is approximately 6 to 8 weeks old!!
Posted on Sep 15, 2008
  • 48 Answers
What kind of keyboard are you using?? is it from a laptop or pc? if it is an external keyboard, try to detatch the y and t keys from the keyboard using anything that is thin (eg. knife, pen, etc.). clean it... and put it back by just pushing it back..
Posted on Jan 23, 2008
Have gas ,spark and compression no run
FUEL INJECTED CARS REQUIRE LOTS OF FUEL PRESSURE. THE ELEMENTS NECESSARY FOR STARTING ARE: SPARK ,COMPRESSION, FUEL, FUEL PRESSURE, TIMING AND CRANK AND CAM SENSOR SIGNALS AT THE PROPER MOMENT AND STARTER MOTOR ENGAGEMENT. FUEL PRESSURE REQUIRED IS USUALLY 30-50 LBS DEPENDING ON THE TYPE OF CAR. THE COMPUTER MUST PULSE THE INJECTORS.
May 04, 2015 | Cars & Trucks
How to fix the fuel pressure if it is the problem with my car not starting
Usually there is a check valve in in near the fuel pressure regulator on the fuel rail. There is a schrader valve you can hook up a fuel pressure guage to test on the regulator too.
Nov 02, 2014 | 1A Auto Parts 1999 Chevy S10 Blazer GM...
Have a1998 astro van that wont start until I spray starting fluid in the throttle body, then starts up and runs fine until about two hours later I go to start it back up and it wont start again.PLEASE HELP...
The first thing you need to check is fuel pressure. This type of fuel system requires a minimum fuel pressure of 56 psi to start. Anything less, even as little as 1psi. And it will not start. It starts and runs when you add the starting fluid because the poppets (the mechanical injectors located at each cylinders intake runner) require less fuel pressure to operate when the intake is under vacuum.
This is a classic symptom of low fuel pressure. A new fuel pump is the typical fix for this problem. Don't skimp on quality if you do need a new fuel pump. They are not all the same.
May 24, 2011 | 1998 Chevrolet Astro
My engine is turning over but it wont start but if we spray starting fluid in it it starts and runs fine
You may have a problem with the fuel pump or some current problemin the system of feeding the fuel pump
Mar 01, 2011 | 1995 Chevrolet Blazer
97 jimmy runs when you pour gas into throttle body, fuel pumps is putting out 55 to 56 psi. but will not pickup the gas from the injectors, fuel manifold psi is 55 to 56psi. 1997 4.3 vortec engine
If the 8th letter of the VIN # is W which i bet it is than your fuel pressure is to low.
This engine uses a CPI unit to deliver fuel to the cylinders. The CPI unit consists of a central injector that feeds fuel to the poppet valve that are right above the intake valves. The poppet valves require high fuel pressure in order to open and deliver fuel to the cylinders at start up.
The reason why it starts and runs if you add a little gas through the throttle body is that once the vehicle is running the intake is under vacuum. The poppets can open with less fuel pressure in a vacuum. This is a real common scenario with these style injection systems.
A new good quality fuel pump (a/c delco or delphi are good pumps) and your fuel pressure should be back into spec of 58 psi or more and the vehicle should fire right up. Make sure you replace the fuel filter when you replace the pump.
Oct 17, 2010 | 1997 GMC Jimmy
My Wheelwriter 5 types faded and incomplete letters. We changed to a new ribbon, but problem is still there. Seems the pressure is not hard enough.
The solenoid for the hammer is probably sticky or the pad is worn.
This requires disassembly for cleaning, lube or replacing the pad.
Jan 25, 2010 | IBM Wheelwriter 30 Typewriter
Do you have to use oil in the pump and if so type,how often.
water pumps doesn't require oil in the pump; but your engine does require. if the water pump is of "self priming" type, fill the pump casing with water before starting the machine to avoid damage to the water seals.
May 22, 2009 | Campbell Hausfeld PW1750 Electric Pressure...
Can i turn off the qnotes feature
Your messages are set to 'word' and you want it set to 'alpha'. If you have your user guide this info is on page 45. Here's how to do that. If this helps plz rate this as 'fixya'. If you need more help leave a comment & I'll be happy to help. Thank you kindly.
You can enter text into your phone using the traditional method of pressing a key several times for each character, or by pressing a key once for each letter while words likely to be the one you want are chosen from a database. You can also enter symbols and numbers into a text field. In screens that require you to enter text, you see the following icons. These icons tell you which text input mode you are using: When you access a screen that requires you to enter text, you start in the mode last used.
To choose a text input mode: 1 At a screen that requires you to enter text, press m. 2 Select the text input mode you want to use. A checkmark appears next to the current mode.
Mar 15, 2009 | Motorola Mobility i560 Cellular Phone
There is an error code comming up it is f32
The F32 error code is a pressure switch failure error code, this error could be caused by several different reasons.
More than likely the pressure switch has malfunctioned. Be sure you are using H.E.(high efficiency)detergent. Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains you will need to call for service. This type of repair will require accessing the inside of the cabinet area to make some checks. This will require a service technician to diagnose & repair.
Jan 10, 2009 | Kenmore Elite 45986 Front Load Washer
Service Code
The maintenance service indicator shows the maintenance service type (letters A-H) in the multifunction display. This service type is only to give the customer an approximate time required to perform the required maintenance ranging from approximately one hour for Service A to approximately eight hours for Service H.
To determine the actual service items required, you must call up the service item menu in the multifunction display. Refer to instruction below.
Calling up the maintenance service data information
The maintenance service indicator shows the maintenance service type (letters A-H) in the multifunction display approximately one month before the service appointment is due in miles (distance criterion) or in days (time criterion).
This maintenance service type is based on the service items to be carried out. The service items are described in the Maintenance Booklet.
The service items to be carried out under the corresponding service type can be displayed in the multifunction display example Service "D" on my 2005 E320 4MATIC at 12,000 miles.
PK112101-M.............112 LUBE MOBIL........*****
007603-014106........RING, GENERAL..........$1.58
000-180-26-09.........OIL FILTER F...............$22.71
001-986-80-71-10....WINDSHIELD W..........$3.44
M0-40...................... MOBIL-1BULK(QTY8)...$47.92
BG110.......................ADVANCED MOA..........$10.95
BG203.......................FUEL TREATMENT........$11.95
SOLV.........................W/W SOLVENT............$2.25
TOTAL PARTS $100.80
TOTAL LABOR $317.95
SHOP SUPPLIES/HAZARDOUS DISPOSAL $47.69
TAX $5.04
GRAND TOTAL $471.98
May 24, 2008 | Mercedes-Benz E320 Cars & Trucks
Saitek Eclipse II Logo
224 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
