Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Dryer controls diagram and or manuals
The wires came loose i need a diagram to put them back
  • 878 Answers
Bodolo, here's your link man, enter your model number and click on the tech sheet/wiring diagrams. It will come up as a pdf file. Catriver
Posted on Jan 24, 2008
Clothes dryer does not work when power turned on at wall. Sounder goes continuously, no lights on panel and panel buttons do nothing
If it didn't do that before removing the capacitor & wires then I would assume it is something you have done wrong. Maybe put a wire back in wrong place. There is a wiring diagram on back of dryer. Motor not starting could be the capacitor, you really need to test it with a capacitor tester. It may also be the motor bearings seizing up. If motor is tight to turn when belt is off then it will be time for a new dryer. Too expensive to replace the motor on such an old dryer.
Jan 03, 2016 | Fisher and Paykel Dryers
Kenmore 90 series dryer runs fine until I put clothes in it then it shuts off after I let go of start button
If you are lucky, it is just a heater relay.
You can actually use the motor relay to test if the heater relay is bad, by switching them around. They are interchangeable!
Below is a parts layout for reference.
  1. Unplug power
  2. Then pry the left end cap loose
  3. Remove the philips screw holding the control panel
  4. Remove the back panel plate to inspect, see below diagram:
25997497-lbinchh11fp0u2viv5ufwbp2-3-2.jpg Unplug the wire harnesses of both relays and plug the heater wires into the motor, motor wires into the heater.
If the dryer stays running when you push "start", you must replace the heater relay!
Note: Do not run your dryer until you have all returned the wires to their proper relays...
Dec 07, 2015 | Kenmore Dryers
You'll need at LEAST a model number of your dryer to post for help. Even then, your available resource people may or may not have the information you need for that. Good Luck, and Lesson Learned . . you can NEVER write down too much info when you're repairing something you're not totally familiar with. . .
Jul 20, 2014 | Hotpoint Dryers
De 407 maytag dryer how do i find a wiring diagram
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Jul 03, 2014 | Frigidaire GLER341A Electric Dryer
I replaced the heating element in my dryer (GE model#DPSB620EC4WW) and am putting it back together. I am uncertain where the wires go on the control panel. There is one gey, one purple, and 2 black that...
There should be a tech envelope in the console labeled "tech data" that has the wiring diagram on it. Dig thru that envelope and you should have the termation points you need. If not I am still looking for the wiring diagram and will respond with it when located. Be patient because I may have to download a service manual.
Aug 21, 2011 | Dryers
I pulled the top of my dryer off and some wire came loose i'm looking for a wiring diagram to fix it
wire diagrams are usually on paper inside the header. thats where the timer and knobs are. sometimes it is on the back of the machine in a plastic pouch glued to the back
Nov 13, 2010 | Frigidaire GLER331A Electric Dryer
I need a wiring diagram for a Kenmore 110.86872100. replacing the thermostat and the heater element, don't want to cross wires. Can you help?
If you remove the cover from the back of the dryer control panel there will probably be a wiring diagram for your dryer folded up and taped to the back. Something to try if you can't find it otherwise.
May 23, 2010 | Kenmore Dryers
Kenmore dryer not heating during cycle, what do I do?
You'll need to check the thermostats and heating element. The dryer has like two or three thermostats: two that operate the heating element, and one that burns out like a fuse if it gets too hot. Pick up a electric multimeter. I got mine at wal-mart for $5. Put it on the resistance (greek letter omega or upside down horseshoe symbol). 1X or 10X or anything doesn't matter. When you touch the probes together the needle should jump, indicating that there's very low resistance there because the probes don't resist electricity flowing them. You can use this to test the components. Unplug the dryer for God's sake, and then try to take off the back panel. If you don't see a way you can probably "pop" the top of the dryer by prying it up with a putty knife in the seam between the sides and top of the dryer. Now remove the back, and find the heating element assembly, probably on the lower right. There will be two or three wires connected to the element assembly. Two 220v wires(probably red) will supply power to the element and one control wire(probably yellow) send feedback to the controller. Check the resistance of the heating element and each of the thermostats by putting the probes on the wires on each "side" of it and check the resistance. If something has a very high resistance on the high voltage wires, it's probably defunct and needs to be replaced. The yellow or control wire might have a resistor on it that your meter would read as bad, but you're only concerned with the high voltage supply wires. Note that the wiring diagram will probably be hidden somewhere inside the dryer when you open it up. If all the parts in the element assembly check out ok follow the wire connected from the element to the motor and check the resistance of the resistors and stuff on the diagram. Note that is a resistor have a value like 10k(10,000 ohms) you may have your meter set too low for the needle to actually read it. That's what the 1X, 10X multiplier settings are for if your meter has them. Other problems could be a loose wire, dirty moisture sensor inside the drum, defective controller, or defective switches.
Oct 23, 2009 | Kenmore Dryers
Kemore Dryer / Model # 63742
I'm not familiar with this specific Dryer, but in most of them you can find their wiring diagram glued under the upper panel or the rear panel. Good luck !
May 16, 2006 | Kenmore 64742 Electric Dryer
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
298 people viewed this question
Dan Webster
Dan Webster
Sal De
