Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Refridgerator no longer colling but fans are working
Power surge back to back happened twice now refridgerator not cooling at all any suggestions
  • 447 Answers
It impossible to tell via the internet without detailed descriptions of what you have tested, checked etc...However it sounds like maybe the compressor relay has failed if you are lucky, they are only around $50. If the compressor failed, then time for a new one probably if its more than 5 years old or if its a 2006 or newer.
Posted on Jan 24, 2008
Fujitsu airon ASTA24LCC 2 flashes green and red then 5 red flashes any idea what it means
Had similar problem (ie. 2 green & red flashed followed by 5 red flashes - Fan blowing but not cooling ... I also noted that the outside unit fan wasn't going). Tried restarting several time after waiting only a minute or two after turning the mains power off but with no change. So turned the unit off at the mains power and then fired it up about 2hrs later and it was all working fine.
Jan 24, 2013 | Fujitsu 24C1 Air Conditioner
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I hear big sound from my processor of my colling fan, it happen when i start my computer
I understand that the cooling fan on the top of the processor is making a noise when you boot up the computer.
I would suggest that you immediately get a new one installed.
This is a mechanical fault and fans will last their lifetime and require a replacement then.
In case you continue using it, then the processor might get damaged.
So, I suggest that you get the cooling fan replaced at the earliest to avoid any damage to the processor.
If this doesn't work for you or in case you need any further assistance, please comment and let me know, and I will be happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this solution.
Thank you.
Jan 13, 2011 | Intel DG31PR Motherboard
2004 santa fe AC only blows cold for a minute or two, then continues to blow air, but no longer cold....tried refrigerant, but didn't solve the problem....Any ideas?
I would first make sure you didnt over fill the system, you may have to exvacuate the system and then recharge it, then watch to make sure the cooling fan is colling condensor, if fan is not working that may be the problem,next if fan is working i would check for power at clutch, this will tell you if the clutch is bad or if its loosing power to clutch,you should have gauge to watch the hi and low side preasure readings.
May 12, 2010 | 2004 Hyundai Santa Fe
Fridge not cooling
The evaporator fan needs replaced they are fairly inexpensive.
Sep 04, 2009 | LG LRTP0931 Top Freezer Refrigerator
MAYTAG REFRIDGERATOR NOT COOLING
Check to see if the evaporator fan is blowing. Sometimes removing the back panel to expose the fan and hand turning it can make it come back on. If this doesn't work then the fan is bad. Also make sure that there is good circulation to the fridge side. Food can sometimes block air flow.
Jul 01, 2009 | Maytag MSD2651 HE Side by Side...
Refridgerator not cooling
Hi, Try these settings..
  1. Check the temperature setting
  2. Assure that there is enough room for air flow in the refrigerator or freezer
  3. Check for air flow restrictions in vents
  4. Test the temperature control
  5. Clean the condensor coils
  6. Check the door seals
  7. Test the door switch
  8. Test defrost heater
  9. Test defrost timer
  10. Test evaporator fan
  11. Check for a clogged drain tube
  12. Check for refrigerant leak                                      Pls rate my suggestion..thank you
Apr 11, 2009 | GE Refrigerators
Whirlpool Refrigerator/Freezer not cooling
Unplug from wall and let unit subside 1 hour. then plug back in and check operation. Was unit tilted or moved prior??
Please rate. Thank you. jj505
Mar 28, 2009 | Jason Natural Cosmetics Jason Forma...
My ge profile side by side bottom freezer is hot to the touch
is you condenser fan runnig at all. look in the back ot the unit and if you have a cover plate hten you need to either put your hand close to the opening and feel if there is a draft or if ther is air being blown out that is warm. If not then the condenser fan may be toast.
Jul 16, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Not cooling at all
NEEDS A RELAY IN COMPRESSOR,THEY GO OUT WITH A POWER SURGE,JUST MAKE SURE RELAY IN COMPRESSOR IS HOOKED UP CORRECTLY ,REMOVE COVER FROM BACK THERE IS A SMALL BOX ATTACH TO COMPRESSOR REPALCE
Jan 03, 2008 | Kenmore 55609 / 55602 / 55604 / 55606 Side...
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
87 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
