Question about Philips CCB092AT 9 in. TV/VCR Combo
Plays tape approx.10 seconds and then shut off power completely
I purchased this unit about 7 years ago and used it for about 1 year and worked great and then did not use it for about 3 years and then I wanted to use it again and now when I try to play a tape it plays the tape with excellent picture quality for about 10 seconds and then shuts off the power completely and then after turning on power to the unit again it ejects the tape and it says reject on the upper right corner of the screen.What is the problem?I have tried cleaning the head and oiling some of the mechanisms.Any ideas or solutions would be great....Thanks very much!!!
  • Anonymous Feb 09, 2008
    I have the same problem with a Philips DVD/VCR combo
2 Suggested Answers
SOURCE: Philips DVP 3150V
Product is Philips model DVDR3435V DVD/VCR combo.
VCR movie plays for 16 seconds then disconnects/powers off. Same for every VCR tape played.
MarkK
Posted on Aug 10, 2008
Fryer wont power up
I HAVE A DEEP FRYER EURO # F 1068 WHICH HAS BEEN USED VERY SPARINGLY SINCE PURCHASED APPROX. 2 YEARS AGO. YESTERDAY I PLUGGED SAME IN AND THE ENTIRE HEATING UNIT FAILED COMPLETELY, DEADER THAN A DOORNAIL, DON'T UNDERSTAND WHY ?? CAN THIS UNIT BE REPLACED IF SO WHERE AND HOW DO I GET REPLACEMENT.
AM VERY DISCOURAGED OVER THIS MALFUNCTION.
JOE SCHMIDT (jschmidt@oakton.edu)
Dec 03, 2013 | Euro-Pro F1066 Deep Fryer
I have an hp laptop that a purchased under a year ago its an x2 turion entertainment 14'.....it cant be turned on....at first it would start to turn on for 10 seconds you would hear the fan and it would...
Yes you can set up an RMA "return merchandice authorization" with the manufacture for 1 year date of purchase. Best Buy can pull up your purchase and print you a new receipt.
Aug 14, 2010 | Computers & Internet
Philips DVP 3150V
saida horizontal com deficiencia faz com que a fonte aciona circuito de proteção.
Feb 09, 2008 | Philips CCB092AT 9 in. TV/VCR Combo
Goldstar KMV-9012 (year 1990) TV/VCR Combo
This is the problem with these combo units. When the VCR has trouble (this sounds like a mechanical one) it inhibits the TV from working as well cause they share the same power supply. It needs a VCR expert to fix ya up.
I tell people all the time not to buy these combo units unless they really need the conveinience cause you get to throw away the TV when the VCR goes bad.
Nov 17, 2007 | Goldstar GVR-DD1 VHS VCR
While rewinding, the DVD player just stopped working
Jeff/360Powner,
Tony/sonydvdvcr here,
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my sony dvd vcr slv360p unit now works and the dvd plays great. Still working on the tape part. Good Luck!
A few days ago when I was searching online for a solution to my own problem, I came across fixya. After posting the exact same problem as yourself, I began to remove the tape from the unit. Thinking I would have to cut the tape, I attempted to remove the video cassette without cutting it. I was successful. Here are the steps I took:
1. Remove the outer casing.
2. Remove the approx. 8" bar (2 screws) across the VHS entry area. (You can do with or without removing face of player. Be careful if done without)
3. Remove 4 or 5 screws in base holding the entire video assembly to floor.
4. Next, is the tricky part. First determine if the tape is one you want to salvage. If so, slide the tape film out of the roller areas where it is strewd out while it was being rewound so it is free, otherwise cut it. You will then have to pry the VHS up in the front through the entry door and push from the rear. Might have to try a few times, walk away, then try some more. But it will come free. Tension can be eased by simultaneously prying on the sidetabs holding the cassette in the player. Careful not to break tabs.
5. Once tape is free, you may be done, but I kept on in uncertainty.
6. Next I removed the entire video tape assembly by raising it off the tall pointed posts enough to clear them but not too much where you put excessive strain on the several computer bands that are attached.(I did not disconnect those, just be careful)
7. Raise the assembly off of the floor and then replace. There is a slim narrow plug style deal that is fixed to the floor that the assembly rests in. I believe this is significant to allow the player to reset.
8. Check power now before you replace everything. You should see the tape assembly physically reset and disengage from the rewind position.
9. Replace assembly and bar and face accordingly.
I hope this helps. I have been unsuccessful in getting this to fix the tape player, but my unit now works and the dvd plays great. Still working on the tape part. Good Luck!
Sep 23, 2007 | Sony SLV-D360P DVD Player/VCR
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
VHS problem, any help?
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
Dec 30, 2006 | Sylvania SSC719C 19 in. TV/VCR/DVD Combo
Philips CCB092AT 9 in. TV/VCR Combo Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
