Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Power supply connection for rca
Hi good evening am replacing the power supply board for my rca tv. i just get the part but there is no instruction. there are 2 wires left off and orange and a black. can u please tell me where they go.. thanks a lot
  • RCA Master
  • 8,617 Answers
The wires should have a number or letter stamped on the connector that corresponds to the socket on the PC board. Look the plug over real good for a letter or what not stamped on its plug. Hope this helps.
Posted on Jan 23, 2008
How do I replace control board?
RCA/Westinghouse HV320WXC1007061 T-Con Boards ...
? 4:35
https://www.youtube.com/watch?v=5jO_TZfplR0
Jan 21, 2013 - Uploaded by ShopJimmy.com
RCA TV Repair Westinghouse TV Repair T Con Board Tutorial & No Picture ... Top Common LCD TV problems for bad TimingControl T-Con Boards: .... VR-3215 with no picture no sound but the power LED is solid green, any ...
RCA 276046 Power Supply Unit (PSU) Boards ... - YouTube
Nov 24, 2015 | RCA P52927 52" Rear Projection TV
How do i fix my rca tv that is not powering on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 30, 2015 | RCA E13320 13" TV
TURNS OFF ITSELF
Good day!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 24, 2012 | RCA HD52W59 HDTV Projection Television
No power to rca rear projection tv
Good day!!!!
Jun 19, 2012 | Televison & Video
We have 52
Good day!!!!
Jun 05, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Why does my tv turns off after a few mins
Good day!!!! That problem is usually cause of faulty capacitors on the power supply board.. Just follow this instruction to fix your TV.. 1. Open the back cover of your TV. 2. Look at the power supply board..Its normally connected to the power cord.. 3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors.. 4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value.. 5. Some of the capacitors not bulged so its better if have a capacitance meter
Sep 18, 2011 | RCA Televison & Video
After 30 minutes or so the tv just shuts off but then in a little bit it you can turn it on and comes back on
Good day!!!!
Sep 04, 2011 | RCA Televison & Video
Tv will not come on yellow light comes on
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Good luck in solving the problem.....
Jun 23, 2011 | RCA L32HD31 32 in. LCD HDTV
TV Problem
The first thing is to check to see if the fuse is blown,if so replace with a 5 amp fuse,fuse is located near were the power cord connects to the board,make sure set is disconnected from power.
Feb 28, 2008 | RCA F32672SB 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
