Samsung Speaker vibration on my Samsung LCD TV. Occurs on all volumes but only with certain sounds/voices.
  • 8,617 Answers
Sounds like your speaker is blown . Is it a stereo? If so you can try switching the balance to the other speaker to see if its only in the one speaker. You can also switch it to mono to see if tat makes a difference. Let me know what you discover and I can help you further.
Posted on Jan 23, 2008
The speakers are making a crackling noise that is not effected by the volume
Check the speakers first. If the voice coil of the speaker has any fault, the speaker should be replaced. Connect an other speaker in place of present one, and see whether the crackling sound occurs with it too. If yes, the audio output board to your TV have the fault, and it should be replaced.
Oct 17, 2012 | Mitsubishi LT-46153 LCD TV
Right speaker perfect. Left speaker sounds like someone is talking through a kazoo.
Hello
Just check the left side speaker for its voice coil trouble. If voice coil has got damaged, this kind of fault will occure. If so replace the speaker with an identical one, both in size and impedence [ie resistsnce in Oms]. Connect an other good speaker of any type to the left speaker wire, and check whether the sound though it is perfect or not. If it is perfect, there is no doubt that the speaker inside the TV is damged. If the connected outside speaker also gives disorted sound, the Audio Output IC inside the Tv is faulty. Have to replace it with same type and number.
Before doing all these, go to the sound control section through your TVs menu options, and be sure that the balance control is set to mid position.
Ok.
Jan 19, 2011 | Samsung LN32A330 32 in. LCD TV
Speaker volume like small baby
To fix the volume control re-install the drivers of the laptop and in the right lower corner you will see a speaker like symbol where you can control the volume. Increse the volume from there.
Thanks
Jimmy
Apr 29, 2010 | Samsung NC10-14G Notebook
Audio hum or vibration
spkr problem you can replace that for a new one.
Apr 05, 2010 | LG 42LG50 42 in. LCD HDTV
Why does my lg tv vibrate as i turn the volume up? to hear the tv it gets turned up to 40 and above on the volume control, it just vibrates when it's that high. there's no vibration at 20 or under, but you...
This is a inherent problem in the LG 7 series LCD. It is because of poor padding in between the speaker and the bezel along with a very thing back that causes the TV to vibrate at certain frequencies and volumes. LG is aware of this issue and has new speaker brackets and spaces that will fix the issue. You can contact them and explain your situation if they can send a service center out to fix the issue under warranty as it is less than a year old. If you cannot get it covered, it should still be a cheap repair as the parts should only cost around $20 and take less than one hour of labor for a technician familiar with the issue.
Oct 08, 2009 | LG 37LC7D 37 in. LCD HDTV
Housing Vibration During Certain Frequencies (At Normal Volumes)
Sir
The problem very well could be with the DVD player because the disc is spinning very very fast and it might be causing the vibration thru out the chassis. Is this only with DVD ? You mention mainly DVD so I would like to know can you notice what type of scenes are causing it with TV ? Maeaning bright scenes or dark or something else?
Hope this is of some help. If you still can request that they come again as the problem isn't fixed. They might replace instead of coming again.
Apr 01, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
Mar 20, 2009 | Samsung 46 in. Flat-Panel LCD HDTV
Sound vibrates
Test it by moving the bass and treble up and down. If the buzzing seems disappear at lower volumes with little bass and appears from one side only, it is probably a blown speaker on that side.
If the buzzing is apparent even at very low volumes or from both sides, it is probably an audio board issue. I am not certain if your model has a separate audio board or that functionality resides on the main board.
Dec 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Dell no sound
I also have Dell W2600 TV and have sound problems
Dec 14, 2008 | Dell W2600 26 in. LCD Television
Me again. I removed the rear plastic housing of my TV a few weeks ago on a hunch that the resonance frequency of the two speakers were matching that of the plastic rear housing. Yep. Once I removed the plastic housing (about 8 screws), all speaker vibrations ceased. It's been fine ever since. However, I don't particularly care to have the back off of it, although I see no high voltage parts like a yoke, etc. sticking out or within reach. It's also not mounted to a wall and is in a position where folks can't easily get there hands into the back. I'd still write to the CEO of Samsung since this is a wider problem that they should address without charging a tech fee.
Jul 30, 2008 | Samsung LN-S4051D 40 in. LCD Television
Televison & Video Logo
379 people viewed this question
Top Televison & Video Experts
