Wireless mouse I cant open the shell on the top...
    Genius:
  • 1,067 Answers
Is ther screws on bottem small ones under rubber pads or slide it back off of it
Posted on Jan 24, 2008
How to set up a tomtop mini wireless mouse
Just had the same problem, the battery compartment is in the top, back part of the mouse, it was a pain to get it open, but once I did everything seemed to work just fine
Feb 02, 2012 | Computers & Internet
I need to change the batteries in my wireless mouse and cant figure it out
press the eject button on the top of the mouse the back will come off there is a compartment on each side for aaa batteries
May 20, 2010 | Dynex Wireless Optical Mouse
I have a wireless optical mini mouse model #98792. i cant figure out how to open to install new batteries.
these usually have a button on bottom with a picture of a mouse push that it will open the top where the batterys are.
Jan 13, 2010 | Computers & Internet
How do I open to replace the battery on my microsoft wireless optical mouse 3000
There is a release button on the mouse that allows you to slide the top back of the mouse off. The button will be on the bottom and labeled "OPEN". Press this as you slide the top cover off. From there you can replace the batteries.
Nov 17, 2009 | Microsoft Wireless Notebook Optical Mouse...
Changing the batteries in a hp optical wireless mouse
From pictures, it looks like the top part of that mouse slide down.
Try holding it with the buttons facing toward you, and pushing with your thumbs on the top silver piece of the mouse away from you.
May 18, 2009 | HP Wireless Optical Mouse
Open mouse to replace batteries for giga ware mouse
Press the small buttton on the lower palm side of the top of the mouse and pull the round side of the mouse off. you tube video here http://www.youtube.com/watch?v=A3fYOjdAE1g
Feb 07, 2009 | Gigabyte Wireless Optical USB Mouse GMW7C
Where's the battery????
If you consider the button and wheel side to be the front -
There is a silver oval button at the back of the mouse. Press it and the top of the mouse just behind the mouse buttons will pop open.
It takes 1 AA battery with the negative side going to the front.
Jan 12, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a logitech wireless mouse model CE0560 and figure out how to change the battery.  ????
The battery is either in the botom of the mice or on the top
If its under the top, press the shell, that one u have under your hand, backwards to open it
If its under thi mice you should see a smal lid, same thing on that , press it to open
Good luck
Dec 09, 2008 | Logitech Cordless Mouse
Microsoft Wireless Optical mouse 2.0 Sticky central wheel
I just took mine apart to fix same problem, works much better but not sure for how long.
Quite simple to dismantle the unit.
Take the battery cover off, remove batteries.
There is a small screw in the middle of the battery cavity, you will need a very small Phillips head screwdriver.
Gently ease the base (holding circuit board) from the top shell
The wheel unit can be gently eased out of its cradle, use the small screwdriver to pop it out, watch out for the small spring between base and wheel unit, don't lose it
You can disconnect the wheel unit from the circuit board by unhooking the small plug connector
Now defluff, then clean the wheel - I used a tiny amount of turps on a cloth, anything similar should work. If you look closely the reason the wheel won't roll smoothly is that the gel ring on the wheel is too close and rubs at the front and back of the cradle. Once grime builds up, this problem makes the wheel unusable. Roll the wheel back and forth along a clean surface once cleaned, should start rolling freely again.
I also unscrewed the top shell from the mouse buttons (all one piece, pinch the plastic pegs in the centre of the shell together to release) and cleaned the whole unit up before putting it back together
Don't forget the spring when putting the wheel unit back. When screwing the base to the top shell make sure there is no play between the two parts before you put the batteries back in, mine was a bit tricky to get tight again but worked fine second attempt
Sep 07, 2008 | Microsoft Standard Wireless Optical Mouse
CANT GET WIRELESS MOUSE TO WORK
Try changing with a new set of batteries. also try to reset the connection of the wireless mouse and keyboard. you can locate a connect button on both the reciever and wireless keyboard. press both of them together and release them. this would reset the connection. try doing the same for reciever and wireless mouse connect buttons. this should work. also check for any possible alignment issues.
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
