Question about Dishwashers
Indesit D63 dishwasher dishes not getting clean
Doing program but dishes not getting clean
  • 4 more comments
  • Anonymous Mar 11, 2008
    dishwasher runs thru cycle but dishes not clean
  • Anonymous Oct 31, 2008
    Bottom rack fine, top rack gritty
  • sjhuhua Dec 19, 2008
    Film of muck left on everything after cycle finished. Always worked ok before, now it doesn't look like it's washed! There is plenty of salt and it appears to be using it. I have checked filters and cold water inlet filter. Also tried liquid cleaner, there are no blockages in the spinning water jets. Baffled!
  • gemmm43 Jan 03, 2009
    lower rack get clean but upper left still pretty dirty and filmy all arms are moving and seem to be working in cycle as when I open while running they come to a stop not sure of how to remove upper arm to check for any clogs
  • Anonymous Jan 04, 2009
    We paid top dollar for this dishwasher. The dishes, especially the glasses on the top and silverware are not clean. I suspected the new Smart detergent dispenser is flawed, but it may be the spray arms.
  • Anonymous Jan 25, 2009
    dishes or not clean
    Scholar:
  • 93 Answers
Check the rinse aid dispenser is set properly to release a small amount of rinse aid not full and not off but the first click should be fine,then under the bottom rack there are filters remove then and clean them regular,also remember to wash the dishes the same night that you use them ,leaving them over nite will result in the food going hard and you will need a hammer and chizel to remove some dried food,last please remember this is a dishwasher not a food disposal unit you need to rinse the dishes and scrap off loose food before washing
Posted on Dec 28, 2009
Dishwasher seems to cycle through but dishes are still dirty, like there is no water being sprayed?
Posted on May 04, 2009
My dishwasher wont go through a cycle i can hear water going in it then jams and makes noises
the revolving shower washer must be getting blocked by some dishes or cutlery. check for interference and proper seating of stuff loaded in washer.
Feb 01, 2012 | Indesit 24 in. D63 Free-standing...
My Indesit D63 dishwasher is not cleaning things in the upper tray. There are no blockages in the spray arm but the rubber seal at the water inlet to the spray arm seems to be damaged. What should I do?
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34fes
Aug 19, 2010 | Indesit 24 in. D63 Free-standing...
check that the arms top and bottom turn freely and are not blocked.also if you use tablets,then you do not need to use rinse aid in the door,the coating could be due to over rinse aid as the tablets have this in,if these are ok you may benifit from putting a good quality cleaner through if
May 05, 2009 | Indesit 24 in. D63 Free-standing...
Replacing a DoOr Seal
as i remember it, you will have to take off the door front panel and slot in the seal from inside of the lower door. if im thinking of the wrong model and the advise is wrong i will get back to ya.
Mar 16, 2009 | Indesit 24 in. D63 Free-standing...
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
D63
Reverse the polarity of the dilithium crystals, et voila!!!!
Jan 10, 2008 | Indesit 24 in. D63 Free-standing...
Leaking Indesit D63 dishwasher
Bad designed and filled with mistakes, I cant lie to you and even reccomend a cure /fix for this.Sorry.
Nov 01, 2006 | Indesit 24 in. D63 Free-standing...
Indesit D63
It sound that the problem is cause the water level switch (stuck in the "full" water position). The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with this specific machine, but if you will open the rear panel you will find it easily. Clear first any obstruction in the tube,In case it doesn't help, disconnect the wires from the unit (you should disconnect first machine's power cable !!!!!) and measure with a multi-meter on its tugs for continuity and disconnection while you are inhale and blow to its tube. In case it doesn't react, you should replace it. Good luck !
May 28, 2006 | Indesit 24 in. D63 Free-standing...
Dishwashers Logo
744 people viewed this question
Top Dishwashers Experts
