Question about Mitsubishi WS48511 48" Rear Projection Television
Mitsubishi WS48511 TV will not power on completely.
TV initializes properly when plugged in. Press power and the TV will start to turn on, but shuts down after a couple of seconds. Don't see any blown caps on DM board or anywhere else. Power LED self diagnosis test returns 1-2 No Error. Anybody have any advice?
  • 3 more comments
  • clmblue Jan 23, 2008
    Can you suggest a good way of testing out caps other than visual inspection, that doesn't require removing them from the board?
  • Anonymous Apr 15, 2008
    Was watching TV (Mitsubishi WS-48511) when it suddenly went off. Tried to turn back on and Green LED stays on for 2-3 seconds then the TV goes off. Have pressed reset button and also unplugged from power for more the 15 mins. Nothing. There was no symptoms of things being wrong or starting to go wrong. Just suddenly shut off and can not be powered back on.
    HELP!!!!!!!!!!!!!
  • Anonymous Aug 30, 2008
    you hear every sound but theres no picture
  • dcsavendor Sep 13, 2008
    TV was working fine on Thur evening, 9/11/08.  Turned off TV for the night. The next evening turned on TV and it would not come on.  The green LED power light comes on like normal, then after a couple of seconds clicks off. Unplugged TV; pressed the reset button; pushed in the menu button for 8 seconds.  Nothing fixed the problem.   Any idea on what the problem is?  How much is it going to cost to have the problem repaired?
  • ykchu Oct 30, 2008
    My Mitsubishi WS-48511 was working fine last night. This morning, when
    I turn it on, the green LED is on, but it turn off by itself after a
    couple of seconds. I tried many times but TV just turn of after a
    couple of seconds. Any solutions?
    Some people suggest to disable the circuit protection. How to do this?
I am having the same sort of probblem
TV stays on for awhile and then powers itself off and won't come back on for awhile then will work ok again.
any ideas
Posted on May 21, 2008
  • Mitsubishi Master
  • 8,617 Answers
Have you checked the pico fuses on the bottom side of the PC board? They are small ceramic fuses soldered directly to the runners.They have been known to blow and your set will not power up. Hope this helps, if you need anything further let me know. Also sometimes the 1000uf caps don't show any signs of swelling but can still be bad.
Posted on Jan 23, 2008
  • Sonny Berry
    Sonny Berry Jan 23, 2008
    The only way to test capacitors in circuit is with an ESR meter these meters will spot a weak capacitor really fast. Most electronic supply companies should have one or be able to order one for you.
I also have a dead WS-48511 that turns on for a few seconds and then turns itself off. It was purchased January 2003, It did this the first time in March 2007. The convergence IC and fuse had to be replaced, under warranty. It did it again June 2008. This time it isn't covered by a warranty. I'm replacing the TV. It takes a soldering gun to remove/replace the convergence IC. Last time I check circuit boards don't do well removing the same part multiple times.
I talked to the repairmen and he said on some WS-... TVs there is a convergence chip for each channel. On the 48511 there is one chip for all three channels, I.E. a bad design.
I was excepted a $2500 TV to last more than 5.5 years.
The repair cost would have been around $450 the first time, two trips.
Posted on Jul 21, 2008
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Mitsubishi TV, WD 60735; TV shuts off shortly after powering up.
It could be but a couple of other possible reasons---they had problems with this set and its brothers with caps in the main power supply puffing up and causing this "hard to turn on" issue.
A second reason is dust/dirt inside the unit.
All air is coming in via the front of the set and exits the rear--enough dust gets inside and the fans slow down or the lamp gets too hot and set shuts down---don't try this in the house: we take them with back cover off outside the building (on a ramp) and with air clean them out completely--try not to blow it inside the screen. It looks like a dust storm in most cases but can cause exactly the problem you have.
Apr 23, 2012 | Mitsubishi WD-60735 Projection Television
I have a Mitsubishi TV model WS-48511 it was working fine, I shut it off came back a few hours later & when I turn it on the green light will come on for about 3 seconds but turns back off. What can I...
Unplug it from the wall for about 5 minutes.
with it unplugged, Press and hold the power button for around 30 seconds.
This should discharge the unit and allow it to come back on.
Jul 02, 2011 | Mitsubishi WS48511 48" Rear Projection...
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
Jan 16, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
The green light on our mitsubishi tv WE-48511 turns green and turns on for about a second and then immediately turns off. The unit will not power up at all. any ideas?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device”(or input) and “menu” buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
if this information has helped you rate this solution as I do this here for free.
SD TECH
Nov 27, 2009 | Mitsubishi WS48511 48" Rear Projection...
Green flash of doom!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} . (LED does not stop blinking after plug in) On the DM PCB (part # 934C116001) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them regardless if they look good or check ok
Sep 01, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS 48511 Blinking Green Power Light
Your model will have two picos mounted on the same board with the 7 capacitors they will look like resistors without the color bands they will be F9B01 and F9B00 check them for continuity.
Jul 27, 2008 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS-48511 Device Screen Will Not Go Away
David,
Let's start with unplugging the set from the wall power for 15 minutes. This will hard reset the micro... While that's unplugged inspect the buttons on the front panel of the Tv to see that none are stuck in a pushed-in condition. Plug the unit back in, power it up and if all works okay you're back in business... If not, let try a keyboard unlock. Press and hold the "menu" button on the front panel for 10 seconds. You won't see any on-screen changes but then try to select an input from the buttons on the front of the Tv.
After you've done these drop me a note and if we haven't solved it will try some other things..
Bill
Dec 02, 2007 | Mitsubishi WS48511 48" Rear Projection...
When powering on the tv, it sounds like it starts the process (green led turns on, can hear relay switching), then it just turns back off again.
I am not familiar with the chasiss of that tv visit the web site of www.samsphotofact.com and see if they can help you with a schematic for your tv or www.repairworld.good luck.
Apr 13, 2007 | Mitsubishi WS48511 48" Rear Projection...
Mitsubishi WS48511 48" Rear Projection Television Logo
396 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
