Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Maytag Frenchdoor w/freezer drawer - drawer sticks
The freezer drawer sticks when we try to slide it open. We've emptied the drawer, cleaned the slides, but it still sticks. We need to solve the problem before the handle gets damagaed.
  • 770 Answers
You will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
Posted on Jan 24, 2008
Cant put drawer back in beko freezer
Drawers usually have stops to prevent them from being removed completely in normal use. You may have to experiment with the empty drawer to find a way to slide it over the stops into the closed position, then slide it open to load it.
Jun 03, 2016 | Beko Refrigerators
My bottom freezer not closing properly
Pull both drawers completely out of their locations, clean off the slides that they each normally rest on. Clean off the surfaces beneath where they sit. Now, if they are both the same width and height, switch them and see if the problem is solved. If not, check the actual drawers to see if their sliding surfaces are cracked or covered with any kind of junk. You should be able to get everything to fit with these procedures.
Jan 12, 2013 | Maytag MFD2560HES Bottom Freezer French...
Freezer drawer slides
you have to keep the white wheels on the rod even or the draw won't close correctly,pull the racks out fully open and even on both sides,you might have to adjust the wheels so both sides are even,i use a marker and mark the wheels,now when you hook the door assy on.you have to make sure the wheels stay in place or when you close the whole unit one side of the door won't close all the wa,it's a little tricky if you never tried to line them up before but if you mark the wheels part numbers 12002497 so both sides stay lined up it will close correctly. http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2560HES/3048/0161000/M0412077/00009?blt=06&prst=0&shdMod=MFD2560HES this is the sears site and will show you a picture of all the parts.hope this helps
Dec 01, 2011 | Maytag MFD2560HES Bottom Freezer French...
How do you remove the sliding freezer drawers?
1 Open drawer to the fully out position.
2 Remove upper and lower baskets.
3 Remove screws one in each rail marked on side of rail.
4 Lift the front of the drawer up to remove the drawer.
5 Set the drawer on a soft surface to prevent scratching the
finish. If you have other questions please ask, Thanks Sea Breeze
Dec 14, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Our bottom freezer, frenchdoor whirpoolgold 2008 refrigerator stopped cooling the refrigerator last night. The freezer works fine. What do I need to do. I emptied the refrigerator, vacumnned off the...
It has a motor mounted above the evaporator that pushes air up into the fresh food compartment. That fan motor might not be working. To get to it you need to remove the bottom door and get the food out. Remove the ice maker and shelves and then the rear access panel can be removed. Before going through all that though you can check the continuity of that fan at the control board located behind the ice box. I have a repair manual HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 19, 2010 | Refrigerators
Freezer door won't open all the way
Sorry to see your post so late. I believe your drawer slide guides or the rollers that help balance the drawer are broken and in need of repair. I will give you a link and hope maybe I can be helpful. Thank You,Sea Breeze
Oct 09, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag Refrigerator
Pull out your WIDE-N-FRESH Deli Drawer at the bottom, and when the lid automatically raises look to the right: you'll find a sliding temperature controller that most likely is all the way up. Slide it down towards the bottom and this will cut back on the cool. Worked for ours!
Jun 04, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
GDS20SBSBSS FREEZER DRAWER WON'T OPEN
ice will most likely form again.you have a defrost problem.most likely it is your defrost heater.their are a few things that control your defrost cycle.defrost timer,thermostat and defrost heater.most of your newer ref. will also have a control board on the back of ref. or under ref in a usually grey box.but check your heaters first.you will need to take the back panel off in freezer.you will see heater at the bottom of coils.if you have a set of meters you can check for continuity to heater.also your drain below heater sounds clogged.i usually steam out drain but you can use hot water.water should go down drainwhen unclogged.that will prevent the drawer from sticking.
Jan 26, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
788 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
