Hi, Pioneer CLD-V860 is an old model laser disc player and you need to have service manual copy to get error code details as we do not have related service manual copy. Required service manual copy can be downloaded from HERE for small fee and service manual has all technical info about this unit, schematics, troubleshooting chart, part numbers etc. Hope this info will help you. Thanks.
that error points to your laser unit. chances are 99% that its bit the dust. a tech will have to service it and replace laser unit. thats the only option other than just buying a new fax.
These SC errors are related to the Hard disk.
Re - enter SP mode: Clear, 107 and press and hold Stop button for 3 secs.
Enter SP 5832-008 and press #,(Mail Tx data) to initialize the HDD. Then switch off and on the machine.
If still with error, replace the HDD.
Attention not to change any others SP modes - very sensitive settings!
SYSTEM NEED TO BE RESET, CARTRIDGE MAYBE DEFECTICE, THE SWITCH MAYBE A PROBLEM, GO ONE LINE AND SEE IF ANYONE ELSE SEEN THESE TYPES OF PROBLEMS, GO ONLINE AND TYPE:
XEROX PHASER 5500N LASER PRINTER CARTRIDGE ERROR 11ER00670
ENTER
IF THAT WAS THE ERROR NUMBER YOU HAD
OR
XEROX PHASER 5500N LAZER PRINTER CARTRIDGE ERRORS
ENTER
OR
XEROX FOREM GROUP
ENTER
OR
MANUFACTURE NAME,MAKE,MODEL, DRIVERS AND SERVICE MANUAL
ENTER
Hi there below is what is states in the service manual.
326 C 2nd laser synchronization error The 2nd laser synchronization signal cannot be detected by the main scan synchronization detector board even if the laser diodes are activated. • Poor connection between the laser synchronization detector board and the LD unit. • Laser synchronization detector board out of position • Laser synchronization detector board defective • LD unit defective
error 61 on the nsm is a cd read error nothing to do with the amp, clean laser lens with a cotton bud and spit not spirits etc just saliva, then make a blank selection and see if the laser emits red beam, if not then the laser is faulty, check connections etc, if it picks up the disc but does not spin it its the decoder at fault, places like act marketing london, jukebox showroom, capital coin, herondata sales or anyone operator within the amusement industry will gladly sell you an exchange unit, or just try the coinslot industy magazine online or order via wh smiths
