Question about AOpen MX46-533V (91.89U10.061) Motherboard
Aopen help i have a aopen pc i removed the dvd drive and installed a dvd burner the pc would not boot ot windows the xp logo would appear the start booting all over i removed the new drive and installed the old drive still won't boot to windows tried to contact aopen no luck! help
  • 2,351 Answers
It's very possible that while you were swapping out the dvd-rom you in bumped other data cables & power cables to other devices, just enough to cause the bios not to see them. Re-check all connectors & power cables. Start the system. Still no windows? Enter the bios make sure your devices are showing up. Like your hard drive floppy & dvd-rom. If you have to pull the cables off & reconnect them.
Posted on Jan 24, 2008
I installed windows 7 and i want downgrade to windows xp ,i put xp cd in th drive and restating its not showing any thing
In order to run xp, load in cd/dvd drive and shut computer down, now press power, when logo pops up press F12 and select boot order using the arrows on the keyboard scroll up or down and highlight cd/dvd drive and press enter, that will start the cd installation process. Note! you may have a different F key number assigned for boot selection, when logo pops up look down bottom right for the correct F key number.
Apr 20, 2012 | ASUS 7 Wide 800X480 Tft,intel Uma,intel...
After installing AOpen are Drivers FREE?
The drivers should install automatically once the optical drive is installed. (Assuming good power and data cable connections) This optical drive may have come with a CD/DVD burning program when new. If you have the original CD, you may be able to use that program depending on your OS.
Otherwise, there are several free DVD burning programs but your OS and willingness to deal with "extras" may limit your choices. Nero Lite is free if you accept the Nero Ask Toolbar: . This should work with all versions of Windows. Ashampoo Burning Studio is well liked by many: . This is for XP, Vista and Win7.
Basic drag and drop burning of data to an optical disc is included in Windows from XP up.
I hope that this helps.
Apr 09, 2010 | AOpen Chameleon DVD+/-R/RW 16x16 dual...
How do i uninstall windows vista and making a clean dard drive
You would need a operating sytem cd/dvd (windows xp\windows 7) and a windows COA key. Select your bios to boot from cd\dvd player. Insert the new cd of a different operating system into the drive and restart the computer. It should say press any key to start from cd. Press any key and proceed. You will get to an option to format and install. Format the drive Probably marked C:. This will wipe out the drive and install a fresh copy of whatever OS cd you booted from. Good Luck.
Nov 24, 2009 | Microsoft Windows Vista Ultimate Edition
CPU upgrade problem
Hi there
what are your pc specs , like ram ect. So we can find out what is wrong. please check your cpu settings and reset the pc bios to see if that hasnt solved the problem
Nov 12, 2008 | AOpen AK77-8XN Motherboard
My DVD burner is not recognising blank DVD
i had that problem and turned out ot be defective drive. if u cant boot a known good cd like (extract them burn .iso image with
Jun 16, 2008 | Pioneer DVR-110D DVD RW Dual Layer Burner
Drive light gets stuck on at reboot
Try swapping the Jumper block ( Small plastic pin connector ) on The Back Of the DVD Drive. If using both Hard-Drive And DVD Drive on the Same IDE Cable. The DVD Should be set as Master And Hard-Drive As Slave, Or Vice versa.
Failing This, put The Hard Drive On Primary IDE Channel, And DVD On Secondary Channel.
These suggestions, have been made as it appears from your problem listed, that the 2 drives Are Conflicting with each Other.
Finally, is to try a different 4 pin ( Molex ) power cable to either device/Drive. if you have a single rail Power supply unit. the 2 units sharing a joint power cable, may be draining the PSU.
Hope this helps.
Mike @ compurepair.
May 11, 2008 | AOpen DUW1616/ARR DVD RW Dual Layer Burner
bro just one good thing you should do... if you got no important files in the hard disk just clean format the drive and reinstall a good tested OS probably windows xp pro... make sure you low level format your drive before installing the OS... also you may try updating your BIOS.
rank me if this help ok...
Jan 19, 2008 | IBM NetVista PC Desktop
2 burners on win2000
window 2000 could be a probable cauuse.You could try the following. Update windows by installing the latest hot fixes this would most probably solve the problem if the problem is in windows. if the drives show up in device manager. boot you PC in safe mode and uninstall the drivers of both DVD drives.and reboot normally. If this doesnt work let me know your DVD drive make and model.
Jun 06, 2007 | AOpen DVD1648L (750519138717) DVD Drive
Hang with dvd writer
try to use normal ide cdrom drive
Mar 25, 2007 | Intel D915GLVG Motherboard
Aopen DUW1608/ARR Problem
Right click on my computer>properties>device manager>hardware and look for line saying cd/dvd drives and highlight your dvd burner. Right click it and click uninstal. Restart your pc and Windows will automatically re install it. See if this works, if not either needs a lazer clean disc or you need to replace it they are cheap these days.
Nov 02, 2006 | AOpen DUW1608/ARR (914ID37204) Burner
AOpen MX46-533V (91.89U10.061) Motherboard Logo
54 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
