Question about Hitachi 50V500 50 in. HD-Ready LCD Television
Blue line There is what looks like a big blue smudge on my screen. What could this be? I have the same problem and will attempt to contact Hitachi customer relations, as suggested in a previous post. After only three years I should not have a problem like this...I purchased this system over the plasma...because my research showed that the life-span on the plasma was shorter. Now, I feel like a sucker!
  • 58 Answers
Re: blue line
Hi clay45
You have a defective light engine and if you call Hitachi's customer relations department at 800-654-7013, they will give you the names of some dealers in your area to come out and confirm the problem. Once the tech tells you it's a bad light engine, Hitachi will send a brand new light engine to the dealer to come out and install. If you're not under warranty Hitahci will cover the cost of the part (around$1500) but you will have to pay the install (runs $200-400 approx)
Hitachi has not recalled this (although they should) but they are replacing it. Don't get discouraged if when you call them the first time, they act like they have not heard of this problem. Just follow through and have the set looked at and they will replace the just pay the install. Once our light engine was replaced, the TV is like brand new. Good Luck:)
Posted on Jan 24, 2008
0 characters
3 Points
Sony kdf-e60a20 tv has blue dots and yellow smudge 0n screen how do i repair problem
Contact the authorized service centre for Sony. You can't repair this fault. It is related with its display panel. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Dec 14, 2014 | Sony Flat Panel Televisions
Can dark smudged look on screen be a pixel issue?
Might be. Contact any service technician and make it confirm.
Apr 29, 2013 | Sanyo DP46849 46 in. HDTV
My son put a huge smudge on the screen how do i clean it
they sell kits at most big box stores and they run for around the 20$ range . most other cleaners will damage your display if used to clean it as they contain ammonia based agents that result in blue hazed look to the panel
Dec 30, 2010 | Vizio VW32L 32 in. LCD HDTV
Blue spot and vertical smudge in center of screen. Problem comes after tv is running. Tv is Hitachi 50V500A Projection. Thank You
The problem is your light engine is failing. The part number for this is UX22201DR and is available for purchase with the following link. It runs $334 dollars and really is a part that needs to be replaced by a technician due to the complexity in tear down to remove it. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Lines across screen
If the lines are slightly diagonal and in red, blue and green you have a problem in the ABL circuit. if the lines are only one color you may take the front grill cover offf and remove the panel. look fro the black box 2 inches square with 6 little controls on it. 3 are for focue 3 are for screen the middle on of the screen is the green adjustment the other 2 should be labled r and b respectivly. what ever the color of the line turn the control labeled screen and r b or g for that color ever so ligtly counter clock wise.
Mar 30, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a Mitsubishi big screen,at first it plays good but then,the colors blue verticaly go's out of line
go in touch with mitsubishi costumer care and help.....u possible finf this in ur user instruction booklet
Mar 07, 2009 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
You got shafted!!!!!!!!!!!!!!!!!!!!!!
Jul 30, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Blue line
Uh Oh! blue screen of death. Your light engine has warped a little from overheating and is distorting the picture.
My suggestion to you is to get on the phone with hitachi and start complaining, then keep complaining until they agree to pay for it. You may have to get the problem diagnosed by a pro before they agree to pay for it though.
Hope ya fix it!
Jan 07, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
51 people viewed this question
Top Hitachi Flat Panel Televisions Experts
Are you a Hitachi Flat Panel Television Expert? Answer questions, earn points and help others
