Question about Olympus FE-130 Digital Camera
"Battery Empty" I have tried using all kind of brands of battery's but my camera when i try to Power it, just comes up "BATTERY EMPTY" why? I need my camera. I tried to erase all my photos after i saved them to a disk.But still i have this PROBLEM WHY?
  • 2 more comments
  • CASARAPEI172 Apr 03, 2008
    BATTERY EMPTY COMES ON WITH NEW BATTERIES AND WONT TURN OF HOW DO I FIX THIS WITH GETTING A NEW CAMERA
  • KJL5426 Aug 18, 2008
    Same problem - have tried several batteries. Camera will turn on but doesn't seem to be able to draw enough power to take a picture
  • stayworkers Aug 22, 2008
    When I insert recharged NiMH batteries into my Olympus FE130 camera, I can take maybe 5 pictures before the 'battery empty' notification comes up and then the camera dies : (
  • cgl514 Nov 24, 2008
    I bought newly rechargeable batteries and inserted them in my camera and still get the message battery empty. What is wrong with my camera
  • 797 Answers
The model of the digital camera would help here.
Many digital cameras have a small battery which saves the settings similar to the way a small battery in a PC or laptop saves the bios settings.
If your camera has such a battery, then have the battery tested, unless you have a tester. Such a tester to test button batteries can be found at stores like Radio Shack.
You could also go to a store like Target or Walmart, and these stores usually will have the button battery needed.
If the camera has such a battery and it is good, then other problems are present.
Posted on Jun 21, 2008
Does a one+ 18 volt lithium battery have a fuse
No but will have a deep discharge protection that will come up when the battery is coming below a specific power level.
Sometimes people think on the old batteries to training the cells for capacity but thats wrong , the best is always to switch the batteries do not made a battery inactive for a reserve , have the batteries as soon as you lose some power its the best to leave them on the charger because if the battery is below its deep discharge protection it will not charge anymore when its coming on the charger , then you must load another battery full and connect the full battery with the too low level discharged battery with 2 wires + to the + and the - to the - of the empty battery and wait for 2 minutes in first step and try to connect the almost empty battery to the charger Do not use battery chargers for a car be shure to be safe because of some brands of batteries can have problems with not done experiments.
Mar 02, 2018 | Drills
Nikon D80 showing empty battery
Are you using the same charger for all of the batteries? If so, you might want to try another charger. I had a charger for my batteries (I have a D7000) that turned out to be bad. It would show it charging and then having charged them, but they were still dead.
If that's not the case, check the contacts inside the camera, that they are clean and free of debris. Those little gold contacts needs to match up nice and solidly.
If it's still a no-go, call 1-800-NIKON US (1-800-645-6687) 9AM-8PM EST, Monday through Friday.
Mar 16, 2014 | Nikon D Cameras
New battery is considered Empty
Some cameras, even the expensive Nikon professional cameras have the same problem. Sometimes turning it on and off fixes it, sometimes removing and reinserting the battery works. Sometimes, going into the menu and finding "reset" works.
Feb 11, 2010 | Olympus SP-310 Digital Camera
Compatible Battery problem
Try clean contacts of the battery. If problem persists, note what is on the LCD when it turns off. Only symbol of an empty battery, or is there any text? If there is written "For InfoLithium/compatible battery only", it does not mean that the camera thinks the battery is empty, but that the battery do not communicate with the camera. If other batteries are OK, you should replace the bad one.
Sep 03, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Loosing power randomly
how old are the batteries and how many times they were charged without being fully drained can cause a short life for the battery. Try a new battery-fully charging it properly, but dont charge it again till it goes off by itself completely. If you have a wall charger, plug your phone in. If it stays on that way, check your 'power save' settings. That can also make your camera shut off. Try these steps first and see if it changes the 'battery' from being empty to full and stays on. hope this helps
Aug 24, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
Brand new D60: This battery cannot be used.
yep ...look in the menu ...of the camera ..and select the type of battery u are using ..there are 2 kinds of batteries ...one of them are alkaline ...and the other I'm not sure ..probably nickel or lithium ..or something like that ...anyway there are choices there ..and you just have to try 'am one by one ...
it will also accept only high quality non chargeable ones ...so ..even if they work in other device ..in this kinda cameras it will see 'em as empty if they arent great in quality and amperage ...
Jul 25, 2009 | Nikon D60 Digital Camera
"battery empty" on screen after I disconnected camera from compu
Hi, have olympus fe-280 camera. Battery on screen shows full but shows empty (an inch strip) in middle. I have charged it. Even bought a new battery. Can anyone help. Thank you. ...... I want thinking I may have two faulty batteries and just need to buy another one?!
Jan 25, 2009 | Olympus FE-280 Digital Camera
Hi, I have a Nikon D300. First problem - The battery started showing empty / full / then empty again. Bought a new battery, worked first time, then the same problem empty / full / empty. Change the...
A capaciter in your camera is not working properly and is discharging your battery even when the camera is turned off (this is a cheap problem to fix but must be sent back to NIkon for repair
Dec 06, 2008 | Cameras
Battery empty message
Put brand new batteries in. The battery empty message means there is no "juice" or power left in the batteries. If they are recharagable batteries, "re-juice" them (charge them).
Nov 24, 2008 | Olympus FE-230 Digital Camera
"Battery Empty" sign with camera shut off
You may try to set in setup the kind of batteries you are using. Many digital cameras allow you to set the kind of batteries being used. Whether or not this will solve the problem, is yet to be seen.
Dec 09, 2007 | Olympus FE-130 Digital Camera
Olympus FE-130 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
