Question about Hotpoint HSS25GFP Side by Side Refrigerator
Kenmore Elite Refrierator
At our ice maker we seem to have a drip in side the freezer. The Water comes out just fine. Yet after aome time we have ice build up along the back wall of the freezer and have to defrost it and remove ice chunks. How do locate where the leak is coming from. The frig is only a couple years old and has been a royal pain.
  • luped Jan 24, 2008
    I will give this a try. Although with the way the ice forms and the location, I wonder. Thank you, we will certainly try this out. Luped
  • 833 Answers
I'm not thinking of the icemaker, I'm thinking you have an ice buildup because of excess humidity in the box or, perhaps a deeper problem. First, defrost the unit completely. This may be done by leaving the unit unplugged and open for a day or two. This will allow water to melt off the coils and around the fans. Removing just the frost off the back walls won't do it. Next, check gaskets for good sealing/dirt. When restarting, make sure that you are not leaving open liquids inside, 'window shopping' and the like. Set your internal temps to 0-5 F in the freezer, 38-42 in the fridge, not colder. Use a digital thermometer and leave it in for at least 2 hours without opening the door to verify. If this doesn't do it, you have issues with your defrost timer or heater.
Posted on Jan 24, 2008
Ice maker stop taking water Kenmore
check plastic tube that runs from rear of the freezer. See if it is pluged with ice. If you find it is change the fill valve at the back of freezer behind the compressor cover. It could be a double valve, as one part.
Oct 13, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water freezing in tube to icemaker
Change the water control valve because it is not shutting off once the ice maker is full. The valve is sticking open slightly once power is off to water valve. What is the model number of your Kenmore Elite Model numbers for Kenmore most times look like this example=> 321.456789 Sea Breeze
Kenmore Model Numbers
Apr 01, 2013 | Kenmore 26.5 cu. ft. Side-by-Side...
Hi, I have a Kenmore Elite Refrigerator model #596.76253702 that leaks water from the bottom every time the ice maker refills. The problem keeps getting worse since I purchased this product 2 years ago.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Ice maker water not stopping
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Aug 24, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker seems to be dripping water onto ice in ice container
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Kenmore elite side by side has water that pools in the freezer.
you need to clean out the freezer drain at the back of the freezer,use a hair dryer and a hanger or maybe a shop vac can **** it out-mike
Mar 16, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
There is water leaking from the bottom of the fridge
Hi!!! It seems that your drain line in the freezer section is plugged remove the bottom tray and check for ice or water if you do the unplugg your drain line with a hair dryer..good luck..
Jan 02, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Hello margrek
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
7• Discard stale ice.
Please remember to leave a rating!
Oct 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
I have a kenmore coldspot side by side model # 106.53662300.
The ice maker red light is blinking and it has made very little ice in the last 24 hours. What do you think the problem is?
Jan 23, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
70 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
