Your 4 wire cord has red...black...white...and green wires.
On the dryer terminal block,put the white wire on the center terminal.
The green wire goes outside the terminal cover to the nearest screw for grounding.
The black and red wires go to the outside terminals on the terminal block. It does not matter which is right or left.
Black to black lug white to white lug red to red lug green to ground(any bolt that is attached to body of dryer)
SOURCE: Neptune power cord
hi. thanks for the question. the red to red black to black white to white green to the frame of dryer to ground. thanks the appliance doc please rate this answer
SOURCE: changing electrical cord from 3 prong to 4 prong
Here's an answer that I used personally and my machine works fine: . http://wiki.answers.com/Q/Is_it_possible_to_put_a_4-prong_plug_on_a_dryer_that_uses_a_3-prong_plug_and_how_would_you_do_this . Good luck.
Here
is a tip that will help you with changing your dryer plug.
Dryer
Cord
and Wiring Dryer 3 Wire or 4 Wire
heatman101
