Question about Sharp AR-M205 Copier
Letters and numbers appear in the display
At the display, there is letter L blinking and then number 6 blinking. What does this display tells? Thank you. Please e-mail me your technical response to me at: thailee123@yahoo.com
Thank you.
  • deannadv Apr 09, 2008
    we have the same "L - 6" blinking... the machine was recently serviced / less than a month ago... hesitate to call repair people back when this glitch appeared. HELP
  • ah18 Jun 19, 2008
    At the display, there is letter H blinking and then number 4 blinking. What does this display tells?
    Scholar:
  • Sharp Expert
  • 120 Answers
Yes, L6 means the polygon mirror motor in the laser unit is malfunctioning. There is a test code 61-1 to check the motor. If it is not a bad wiring harness, the motor will need to be replaced.
F2 means the copier does not like your oner cartridge. Make absolutely sure you have the correct cartridge AR-202MT.
Posted on Jun 15, 2008
    Problem Solver:
  • 7 Answers
I really need to get my CD case out to make sure the code is the polygon motor, not a good sign, could need a new laser assbly.
Posted on Jan 24, 2008
F2 appears on sharp AR-M205 copier
Posted on Apr 05, 2008
2 Suggested Answers
  • 87 Answers
SOURCE: Letters and numbers appear in the display
L6 SHOWS LASER PROBLEM MOTOR MAY BI SENSOR.AND L4 DRIVE PROBLEM MAIN MOTOR OR MAY BI ANY GEAR IN DRIVE.CHECK ALL GEARS .DO NOT FORGET TO RATE SOLUTION.BY MIAN JEE
Posted on Feb 22, 2009
Very simple question - which number is the serial number? Nothing appears to be indicated clearly to be it. There is a WIP ID number appearing to either start with IN or N followed by 13 numbers and 1...
LG products usually have a 12 character serial number format, comprising mixed letters and numbers, e.g: 123ABCD45678.
If you can find a number on the manufacturers sticker consisting of, 3 numbers, then 4 letters, then another 5 numbers (as above), this will be the serial number.
Hope this helps.
Regards,
BElectric
Jan 07, 2011 | Televison & Video
Is 19 digit license key number with numbers and letters or just numbers or just letters
the product key would be numbers and letters(alphanumeric)
Thank you
Jan 06, 2011 | Computers & Internet
I have bought a new laptop Acer Aspire 5542, I have tried to do some account and letters and everytime I open it tells me to put in the 25 digit number which is located on the bottom of the laptop the...
Have a close look at the numbers and letters with a magnifing glass. It is difficult to distinguish between 6 & G, 0 & O, 8 & B etc.
The 25 digit product code you have quoted could be for the Windows installation (the label states which product it is for) and won't work for MS Office. Is there another installation product code for Microsoft Office? It may be in your documentation.
Failing that you will need to contact Microsoft for a product installation code.
Apr 04, 2010 | Acer Aspire 55421462 Notebook
I need to program are fax machine to have are fax # on documents that are being sent to other fax machine's
1. Press <function> then "Down Arrow" on the <start> button until [ENTRY MODE] appears.
2. Press "Right Arrow" on the <start> button until [OWN NUMBER SET] is displayed.
3. Press "Right Arrow" [ENTER FAX #] will display.
4. Enter your fax number with the number keys (max. 20 digits). To insert space, press <#>, to enter "+" press <*>. To clear a mistake press <speaker> button.
5. Press <start/memory> button.
6. Enter your name by pressing number keys for each letter. Will display the capital letter for each of 3-4 letters to number, then number, then the lower case letters for each press. Use "Right Arrow" to go to next letter, if using the same number key (IE: B to A uses 1, use "right arrow" to go to next space). The #1 will give a space between words. (Max. 24 Characters).
7. Press <start/memory> [DATE&TIME SET] will display.
8. Press <stop> to exit.
Mar 19, 2010 | Sharp UX-B750 Inkjet Fax
Feb 19, 2009 | Sharp AR-5320 Black and White Copier
I have a brother 4100 fax. how do I change the information on the fax transmission page? thank you
If your date and time are not set yet, press Menu, then 1, then 2 and enter the date and time, pressing Set after each entry. Enter time in 24-hour format so it will display AM or PM properly.
For other info at the top of your fax transmission page after date and time, such as your fax and phone numbers, and company name:
Press Menu, then 1, then 3 for Station ID info.
First put in your fax number and press Set.
Next put in your phone number and press Set.
Next press the buttons for your company name and press Set.
Press Stop/Exit to return to the date and time display.
Here is info on inputting text, from the manual:
Entering Text
When you are setting certain functions, such as the Station ID, you may need to type text into the machine. Most keys on the dial pad have three or four letters rinted above them. The keys for 0, # and don’t have printed letters because they are used for special characters.
By pressing the appropriate number key repeatedly you can access the character you want.
Inserting Spaces
If you want to enter a blank space, press once between numbers and twice between characters.
Making Corrections
If you entered a letter incorrectly and want to change it, press to move the cursor after the last correct letter. Then press Clear; all letters above and to the right of the cursor will be deleted. Re-enter the correct characters. Also, you can back up and type over incorrect letters.
Repeating Letters
If you need to enter a character that is assigned to the same key as the previous character, press to move the cursor to the right.
Special Characters and Symbols
Key - once - twice - three times - four times - five times
2 - A - B - C - 2 - A
3 - D - E - F- 3 - D
4 G H I 4 G
5 J K L 5 J
6 M N O 6 M
7 P Q R S 7
8 T U V 8 T
9 W X Y Z 9
Press for (space) ! “ # $ % & ’ ( ) + , - . /
Press # for : ; < = > ? @ [ ] ^ _
Press 0 for é à è ê î ç ë ö 0
Jan 11, 2009 | Brother IntelliFAX 4100 Laser Fax
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Sharp AR-M205 Copier Logo
259 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
