Question about Feiyue FS288
Feiyue FY811 I received an old Feiyue sewing machine thta I am trying to get going. The needle goes up and down and the fabric doesn't advance. We already checked the feed dog. We think that perhaps it isn't threaded correctly because we don't have a manual. Any suggestions on where we could get a manual?
  • 1388 Answers
SOURCE: Machine not sewing
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
If you are certain that all threaded correctly, did you have a fabric jam and pulled it loose ? If so, the timing may well be affected.
Post an update and we'll get this right.
Bargain Box
Posted on Feb 03, 2008
  • 41 Answers
SOURCE: bobbin thread/feed dog eating fabric
This is a very common problem with really lightweight fabric and can often be cured (if doing straight stitching) by using a straight stitch needle plate and foot. The wider needle plate and foot openings on newer machines give the machine/thread a wider area to pull the fabric into the machine. By using a straight stitch plate/foot you remove the wide opening, eliminating the majority of the problem.
Also - try using a specially coated needle (Teflon or other non-stick finish). The thread feeds more smoothly through the needle and the needle more smoothly through the fabric, causing less drag into the needle plate opening.
Hope this helps. Don't hesitate to respond to this if you have further specific questions. We're always happy to help
Happy stitching,
Kim & Linnette
Posted on Dec 03, 2008
  • 9 Answers
Make sure you are threading the machine correctly and it has the proper tension. Also check the bobbin the thread has to go thru the little lash
Posted on Jun 14, 2009
  • 152 Answers
SOURCE: Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
Posted on Oct 14, 2009
  • 96 Answers
SOURCE: stitching loose. won't thread the fabric
try to rethread the machine all the way back to the spool of thread and check the top and bottom tensions on scrap of same fabric
Posted on Dec 13, 2009
How to sew Lycra on my necchi 522? I'm using a stretch needle. It goes up and down, fabric advances, but does not pick up bobbin thread - so no stitches!
Knit fabric sometimes plays a little havoc with machines. Be sure you are using a brand new needle. Also, ballpoint/jersey needles will usually work better with knit fabrics like t-shirt fabric. For very stretchy fabric like Lycra, you might want to try a Stretch Needle.
Schmetz Needles Needle Guide
Sewing Spandex Tips
If it still will not stitch, check your machine on regular woven fabric with a universal needle. Could be your machine is slightly out of time, especially if you have recently sewn over & hit a pin.
Oct 26, 2016 | Necchi Sewing Machines
Always Check The Manual Before Opening up Your Machine To Solve Problems
The Yamata sewing machines also go under about 6 other names
There is a PDF Download of a Universal Manual for these models
It is for many models from a FY700 up to FY812 and more.
The PDF is in English & Chinese and can be downloaded FREE from here
on May 14, 2014 | Yamata FY811 Mechanical Sewing Machine
The thread keep bursting as soon as i start to sew although machine is thread properly
Check your thread tension isn't too tight, try on a piece of similar fabric that you are going to use, try sewing a line of stitches, if the thread snaps, change your tension number, then sew another line with your different tension number, try this until you can stitch without the thread snapping, it could be that your bobbin tension is too tight. Can you check your machine manual, it could even be the needle or the thread that's wrong for your fabric. But I would say, check your tension.
Hope this helps.
Apr 02, 2014 | Yamata FY811 Mechanical Sewing Machine
Yamata fy811 sewing machine
Feb 08, 2013 | Yamata FY811 Mechanical Sewing Machine
I needle comes unthreaded whenever we try to sew. We've both tried numerous times and it doesn't make a sitch. The bobbin seems to be done correctly b/c the bottom thread comes up with no problem....
first let's deal with the needle becoming unthreaded, Keeping the needle threaded is easy, always keep thread tails of 3 to 6 inches on the top thread & bobbin at all times, & make sure the thread tail are pulled behind the needle before you start to sew,, this will ensure that the thread will not come out of the needle when you start to sew.
you mention the fabric is thin,, do you have a needle that's right for the fabric your sewing?
thin fabric needs a different needle than blue jeans fabric, check your top tension & see what the setting is on, usually 3 to 5 is good.
when the needle & thread are right for the fabric then the sewing is good.
also clean under the needle plate & bobbin area for loose threads or lint
also it's a possibility that the machine could be out of time & would need to be serviced by a sewing machine repair shop-as they have the tools for the job
Sep 22, 2011 | Brother LS-2125 Mechanical Sewing Machine
I have a sewing machine-single needle model 03914, but I don't how to put the needle for delicate fabric and for thick fabric?
Use size 60 for very fine (chiffon), size 70 for light weights like voile and cotton, 80 or 90 for medium weights such as a broadcloth, size 100 for denim and size 110 for something very heavy like a thick curtain or upholstery weight fabric. If you aren't sure what size to use, try pushing a needle into the fabric you are going to sew with your fingers, if it goes in easily and the hole it leaves is not noticeable then it is okay, if it leaves a big hole, then go down a size. If you use a needle that is too small on a fabric, then it is going to go blunt quickly or break.
good info here on needle sizes.
Apr 07, 2011 | Sewing Machines
Tl98e broke a needle and now won't stop looping.
needle plate may be sanded lightly for nicks and scratches. Timing is probably off, need to see an expert repair service in your area.
May 30, 2010 | Feiyue FS288
I have broken 2 needles and now the new needle (foot) will not move up and down. i have double checked all settings and nothing has helped. any suggestions
Here are several solutions for you to try.
* Your broken needle may have been too thin for your fabric. Make sure your replacement needle
is appropriate for the weight and type of your fabric and thread. You may also need a thicker needle if you’re sewing through bulky layers of fabric. When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot to make sure it’s attached securely.
* Change your pressure foot. Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins. A needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate to make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle, right,left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
I hope this helps.
Dec 23, 2009 | Bernina Artista 180
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
Feb 19, 2008 | Yamata FY811 Mechanical Sewing Machine
Feiyue FS288 Logo
98 people viewed this question
Top Feiyue Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Feiyue Sewing Machine Expert? Answer questions, earn points and help others
