Error code 20 on a sony evo9850
What can you tell me about the procedure to attack this problem. I have access to meters and scopes. Can you email me a schematic of the section I will be working on. Thanks Joe Wagner
  • 2 more comments
  • summerchase Sep 19, 2008
    same thing. Error 20 on Sony EVO 9850
  • Anonymous Sep 23, 2008
    If you find out what to do about the error 20 problem please contact us at 310-822-1100 or email at davidgrober@hotmail.com.
    Our error happend all of a sudden and will not allow any function and the tape is stuck.
  • Ron Macdonald Jun 01, 2012
    I had that problem because the drum was not turning. Leaky electrolytic capacitors all around the Drum Motor Driver IC801 on the SST board...C810,811,812,813,814,815and 825.
    Most problems encountered with this VTR are due to leaky electrolytic surface mount capacitors. Loading, capstan and drum drivers
Possibly a tape transport error from what I understand.
Posted on Jun 11, 2008
Transmitter Frequency alignment
look I'm going to tell you now. If you have no idea where to measure the voltage then you shouldn't be playing with that radio. First ,you need a scope,a frequency counter,a distortion meter,a signal generator,a watt meter,a voltmeter,a sinad meter and patience. If you have none of these then don't mess with it.
Jan 17, 2014 | Galaxy Radios Dx-949 40-channel Ssb Cb...
Sony evo 9850 error code 20
From what i've read an Error-20 on a Sony BSP deck is a tape transport problem. Someone with the same error code (on a BSP model) said the actual tape loading mechanism was bad and they had to replace the hardware inside the machine that loads and ejects the cassette.
Jan 23, 2008 | Televison & Video
Codes p0501 p0700 p1753 p1758p0706
vss dead (veh, speed sensor)
A/T 700 codes are transmission errors. so is p17xxx
706 is trans mission range switch open circuited (bad switch or wires)
the scan codes never tell you what part is bad or what to replace.
it tells you ONLY what tests fail. called Monitors.
a Service tech, does this magic,. with tools and meters and gauges and special tests.
you can look up codes here.
http://engine-codes.com/
you can go to alldata.com (or get a real honda fsm book)
in the book it covers each code and now to test it and find the truth.
for example they will show you how to find P0501.
by looking at the VSS signal if good, the wires are bad.
if the signal is bad, the sender is bad. using a scope or meter.
good luck to you.
Oct 26, 2013 | 1996 Honda Odyssey
I have a Sony lo-61hs10. The timer/stand by continues to flash. I Need help ?
It may be too old a set to repair, should be a KP=61HS10
Going if not a specific numbered error code be a case of using a scope and a meter to narrow down what the problem is with this model, since most people do not own the Scope, may own a meter and may be able to find the service manual, I would suggest maybe time to retire this set as many parts for it are no longer available, That said if you really want to fix it yourself you are going to have to have some basic skills.
Let me know, I would like to help but the age of this set is against a clean cut repair.,
Dec 18, 2012 | Televison & Video
Ps3 error 80023121
http://blog.us.playstation.com/2011/04/20/update-on-psn-service-outages-2/
Playstation network is down, and that error is a regional code error due to the network being down.
May 02, 2011 | Sony Playstation 3 (PS3) Console
Error code 80710D36
yheah the reason is because SONY ARE UNDER ATTACK from hacktivists anonymous they are doin it cos they are pissed against sony filing a lawsuit against some of there best hackers yesterday i got a ban for no reason maybe this was just the start of the errors so hopefully this will fix it as the error code shows up now instead of the ban =) who knows
Apr 06, 2011 | Sony Playstation 3 (PS3) Console
When trying to access my mails,the tab keeps being closed and an error report appears,i need to access my mails how do i do this?
start- run- Inetcpl.cpl - go to advanced tab - Uncheck-
Enable third party browser extension
Enable online migration attacks
Apr 29, 2010 | Yahoo Mail
How to reset to zero a Tasco RF3- 7X20 Scope? I am having prblems centering this scope Thank You
Making sure it is correctly fitted to the rifle, you Bore sight it. Best to put it into a vice using a thick piece of blanket to protect the rifle. Looking through the bore you line it up on an object about 10 to 20 meters away. Then you adjust the scope to fix the crosshairs on that same object. This will get you approximately on target. Depending on what a where you are going to shoot, assuming you are using a rimfire rifle, You then set up a target about 30 to 35 meters away. And adjust your scope to center on this target. That will give you dead aim at 30 meters and again at 90 meters, with only a slight variation in height in the middle.
Feb 04, 2010 | Tasco RF37X20D 3-7x20 Rimfire Riflescope -...
Fehler Code E:61-20 - was kann ich tun? need help for error code E:61-20
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
May 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
ERROR CODE E63:20
sir E63 ERR is related to lens err ur camera lens unit dislocated or gears problum. this is easyly repairable
Dec 31, 2007 | Sony Cyber-shot DSC-S600 Digital Camera
Televison & Video Logo
256 people viewed this question
Top Televison & Video Experts
