The heater (Larrs lite 2) lit and heated the water for about 30 minutes. It then shut off and would not relight. The gas is on and flowing. Circuit breaker is on and water if flowing through the heater. The control system is Auqualink RS4.
Be sure your connections are secure on the heater and the aqualink. Be sure your temp is turned all the way up on the heater. And check to see what the temp is reading on the aqualink. If this is running high a popular problem is the temp sensor in the pipeing has gone bad. Other than that you may have soot build up on or around your pilot. This was a problem on some of the early lite series. Hope this helps.
