Question about Panasonic KV-S2046C Pass-Through Scanner
Scanner When powering up my scanner the ready light blinks green then settles on Red. Sofware says to remove paper in scanner. There is no paper in the scanner all the sensors are clean as well. Doesnt everyday, somethimes I can fix it by messing with it for about an hour but sometimes not. Please help b4 i through it off a cliff!
  • po-pell Mar 29, 2008
    EXACTLY THE SAME PROBLEM.
    the ready light blinks green then settles on Red. Software says to remove paper in scanner. There is no paper in the scanner all the sensors are clean as well. Doesnt everyday, somethimes I can fix it by messing with it for about an hour but sometimes not.
    Problem Solver:
  • 8 Answers
Check and clean the exit sensor.
You will find then in the middle behind the exit roller in the paper exit area.
Normaly it is unimpossible to see this sensor because the roller axle is in front of them.
It is the same sensor type like the other sensors with an sender/receiver an a reflector foil.
Helpfull to clean will be a q-tips or a small brush.
Posted on Jul 15, 2008
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Both green and red lights are blinking
It is indicating a failure of some kind. Remove all paper, check for jams, unplug it from power and then plug it back in. Put paper in and try to print again.
Nov 08, 2010 | Epson Stylus Multifunction Inkjet Printer/...
After turning on the printer both red lights blink and the paper and ink seem ok
Take the scrap paper with the pads on to your sink, turn on the hot tap and hold .... And the printer is not Ready and the two red lights are blinking Please Give ... C46an isn't off but both green and red lights are flashing (new ink was put in .... Nothing seems to happen, except for the printer going through its ...
www.hm2k.com/.../parts-inside-your-printer-are-at-the-end-of-their-service-life
Dec 03, 2009 | Office Equipment & Supplies
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
CANON I960 BLINKING RED LIGHT 2TIMES
is the piece of paper removed? or there parts of the paper w/c was nt removed? if the whole paper was removed already, try to use this steps..step 1. remove the power cord of the printer. step 2. press the power on/off of the printer while plugging the power cord. and wait for 10 seconds before releasing the on/off button..then put on your printer. but if some pieces of broken paper inside the printer try to clear it first then try printing.
Jan 02, 2009 | Canon I960 InkJet Photo Printer
UMAX 2100XL IS CONNECTED, 2 G LIGHTS FLASHING WITH NO PRINTS
OUR SCANNER IS CONNECTED BUT DOES NOT WORKING. DOES NOT POWER ON THE "SCANNING LAMB" NOW THE TWO GREEN LIGHTS ARE FLASHING ( POWER AND READY ) BUT THE SCANNER DOES NOT WORK OR SCAN.
Dec 09, 2008 | Umax PowerLook 2100XL Flatbed Scanner
TV not working
Check the lamp door assembly, if the lights are alternating red then green, then this might mean that the metal pin that looks like a roofing nail is not making contact with the metal clip. Remove screws, reset panel in place and turn on, the red power button should be the only light on.
Good Luck!!!
Aug 07, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Ready/Error Light
IT have just been down to look at our scanner & cleaned the sensor which is in between the rollers just where the paper flits out at the bottom - we now have a green light! So look for that sensor.
Apr 18, 2007 | Panasonic KV-S2046C Pass-Through Scanner
Panasonic KV-S2046C Pass-Through Scanner Logo
440 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
