Question about Kodak Carousel 4600 Slide Projector
Projector drops slides okay, but after it gets warm, it doesn't drop slides.
The projector appears to mechanically drop slides fine at first. After some time, it apparently heats up and quits dropping the slides. I noticed when looking through the rear of unit that there is what appears to be some small fragmentation pieces on the bottom of unit. These fragmented pieces look as if they may be breaking off of an item that looks like a larger resistor or varistor. I am wondering if there is a cooling issue or air flow problem. If not, then maybe this item that is fragmenting may need to be replaced. Please assist me with any information to resolve this problem.
  • Anonymous Dec 08, 2008
    after advancing 10 or 12 slides, unit buzzes and will not advance any more slide.blower is working. this occures on both manul and remote controls.
    Scholar:
  • 33 Answers
Don't know if you have this figured out or not but I think this is what's going on. The debris in the bottom, I'm assuming is either white or if a very old unit, brown. It's insulating ceramic from the surface of the lamp dimming resistor and should pose no particular electrical threat. The sole exception to that would be is it's an old unit (600/700/800 series of Carousel or E2/E2 Ektagraphics-there were a few specialised models in that style too) AND the metal lower body was damaged so it would allow the metal to touch the outside of the resistor which is mounted on the fan housing. If no damage, no worry.
As for the not dropping slides, the most likely cause is dirt and/ or dried up lubrication on the lifter ass'y. The lifter is the arm that rises up and holds the slide up until the tray moves it forward and then the lifter falls down after the subsequent slide is in place. If you are lucky, you can use a few Q-tips wetted (not soaked) with rubbing alcohol. Carefully observe , with the lamp turned off, every surface you can see that the lifter rubs against on its travel up and down inside the gate (the opening the slides fall into). Clean those surfaces, as well as the lifter, where it makes contact. There may or may not be a white plastic strip inside the gate that the lifter rubs against. Clean that in particular.
If this doesn't do the trick, and you feel you can do this part, remove the lower body. This is easier with the older models newer ones may require a special Torx type driver. Mark their locations- those at the handle (newer style) are shorter.
Locate the pivot point of the lifter and clean it with the alcohol or a bit of WD-40. If you have access to a very light grease put just a little on the pivot point wherever it makes contact.
While you are in there, and IF this is a newer model , you can avoid another similar problem. ONLY IF you are are OK with operating the projector with power applied, have it turned upside down and, with a remote control preferably (so you don't jostle the projector, activate the advance. Observe a small grey metal "trigger" that moves for a split second, releasing the thick white gear below it.The trigger will stay in motion a bit longer if using the Reverse . Now disconnect the power and look at the pivot point of that trigger. Drop 2 -4 drops of alcohol on the pivot and gently rock the trigger back and forth. This cleans out old oil. Apply one or two drops (no more) of the lightest oil you can find.("Sewing machine" oil may be OK or very light oil you sometimes get with hair clippers or electric razors) It's almost better to have no oil at this point, than a heavy one. The symptom you get when this trigger starts to stick is that it will advance 2 or 3 slides at a time before stopping.
Reassemble the bottom being careful to fit any wiring inside and not pinch it in any way.
Posted on Feb 06, 2008
  • 3 Answers
Derek's answer worked great for me! I added a little "insurance" to the solution by glueing a nut to the arm that lowers the slide, to work with gravity to help it make it to the bottom of it's travel should it start to get hung up again. Please watch my youtube video that illustrates the problem, and the solution. Thanks again, Derek.
https://www.youtube.com/watch?v=gZf-spuU9co
Posted on Dec 18, 2014
Mechaniism jammed.
First of all, you'll have to get the slides out of the projector. You may have to use needle-nosed pliers to remove them. Once removed, cycle the projector 3 or 4 times using the REVERSE button. The jam will be cleared. Good Luck !!! Jim
Jul 11, 2013 | Kodak 4200 Slide Projector
On my kadak 4400 I placed a slide tray with 35mm slides in. After turning the power on I attempted to advance the first slide. Nothing happened with the slide. I turned it off reset the tray and tried. ...
Try turning your projector on without a slide tray. Cycle it 2 or 3 cycles in reverse. Place the tray back on the projector and cycle forward. By cycling it a few times in reverse, it re-sets the cycling mechanism.
May 08, 2012 | Kodak Carousel 4400 Slide Projector
The slides appear to be dropping to far down so when viewed you see the top of slide (cardboard) and top half of picture- thi swas given to me used and I dont have a book - it is 300AF
Try using a full thickness plastic slide mount. Some card slides are so thin that they miss the slide support when being dropped down from the magazine. Some magazines are designed specifically for card mounted slides whilst other are for glass mounted slides. Types shouldn't be mixed for correct and consistent operation.
Feb 14, 2011 | Elmo Projectors Omnigraphic 301 Slide...
My slides will not drop down into the projector.Everything sounds and looks like normal, but it is not functioning.
You didn't tell me which model projector you have, so it is difficult to guess at an exact cause.
Remove the tray and look into the slot the slides go down into for projection (Gate).
Look to see if there is a white or black plastic "T"-shaped pad on the end of a metal lever at the top of the gate. This is the Lift Lever, which raises & lowers slides into the Gate.
With the tray off, cycle the projector a few times. Did the Lift Lever go up & down? If it stayed at the top, chances are that the Slide Change Mechanism is not working.
It could be a timing adjustment. It could be a broken mechanism drive belt. It could be that the Slide Change Mechanism needs to be re-built.
Depending on the age of your projector will determine if parts are available. I recommend you contact a factory-trained dealer to get an estimate and/or a repair.
Dec 16, 2010 | Kodak Office Equipment & Supplies
860H slide projector will not drop a slide or go forward or reverse. It is stuck
The projector most likely needs the "link" that connects the Slide change solenoid and the Slide change mechanism. This "link" is plastic and gets brittle & cracks over time. It is deep inside the mechanism and usually requires an Authorized Service Dealer to make the repair.
Aug 20, 2010 | Kodak Office Equipment & Supplies
Projector light does not shine. (Power is on, bulb
I will assume from your description that the projector is powered on and you can look in the rear vents and see the lamp illuminated, yet the light does not shine on the screen.
The Ektapro 9020 and most of the Ektagraphic line of projectors are equipped with a "dark shutter". What that does is keep the screen dark unless a slide drops into the gate. At that time the sensing circuits trigger and open the shutter, allowing light through the slide & onto the screen.
Dec 16, 2009 | Kodak Ektapro 9020 Slide Projector
Slide drops down to veiw but immediatly pops back up. You see slide for one second. Any solution?
Your projector needs a cycle contact adjustment. It is "continuously cycling". Depending on how comfortable you are with the inside of a projector will determine whether or not you decide to tackle this yourself, or contact a factory-trained dealer.
Unplug the projector, remove the lamp module and turn the projector upside down. Remove the bottom cover (6 - T15 TORX screws), and pull the bottom cover off slowly from the handle edge first. At the center of the slide change mechanism there is a camstack. At the end of the camstack there is a PAD. You will also notice a "J"-shaped wire (clutch contact). When at rest (the projector powered up and "idling", the wire needs to rest just about at the middle of the pad. See my attached illustration. You will need to bend the wire GENTLY and a very little at a time, then plug in the projector (be careful - hazardous voltages!!) and cycle the projector a couple of times. Check the relationship of the wire to the pad again. Unplug and repeat bending process. Check again. It should take (on average) about 5 or 6 GENTLE bends to get the adjustment correct. Good Luckjauburn_5.jpg
Nov 22, 2009 | Kodak Carousel 5600 Slide Projector
The slides won't drop into projector fron tray
the tray may be out of alignment because the indexing lever needs adjustment.
Nov 12, 2009 | Kodak Office Equipment & Supplies
Sometimes stop advancing. sometimes keep advancing 5 to 8 slides.
the mechanism needs cleaning. it is an almost purely mechanical device and needs greasing. the old grease gets hot and dusty and starts to get sticky. when this happens, the moving parts tend not to move. the mechanism needs to come out for a cleaning and regreasing.
Jul 11, 2009 | Kodak Carousel 4600 Slide Projector
Elmo TRV-35H "eating" slides
CAUTION: Mains voltage connections are exposed once the base of the projector is removed. ONLY attempt repairs if you are confident of your skills!
There are several possible causes for this problem:
1. Kodak produce two different types of carousel magazines - one for glass mounts and one for card mounts. You must not mix glass and slide mounts in the magazine - it causes the focus mechanism to 'hunt' and also causes the slides to jam, as described.
2. These projectors are almost antiques ..... lubricants dry out and the mechanisms slow down and stick! Some 'technicians' apply graphited grease over the top of the dried stuff, hoping it will soak in! Clean as much of the old lubricants off with 'electronic component' solvent on cotton buds particulalrly around all of the cams. Pay particular attention to the slide lifter cam follower - grease here can cause the lifter to only lift, or drop, the slide partially though its full travel. I use 'CopperEase' very, very sparingly on the cams (NOT on the face of the slide lifter cam) and haven't experienced any problems.
You should not adjust the cams on their shaft.
3. The slide pressure plate is acuated through one of the cam followers, opening and closing at the right time. There is a very fine pivot bar at the bottom of the plate. The pivot points can be lubricated with a single small drop of fine industrial sewing machine oil. Avoid 3in1 oil at all cost!
Jun 20, 2009 | Elmo Projectors TRV-35H Slide Projector
Kodak Carousel 4600 Slide Projector Logo
304 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
