Question about Panasonic PT-50LC13 50" Rear Projection HDTV
Lamp I've got the Lamp Housing here on the table for a PT 50LC14. How do I get to the bulb, to cut the wires and install my replacement bulb? I've removed all screws, and I see to sliders on either side of the handle.... but I can't get them to slide off. Help.
  • 3 Answers
Ok, so you need an extra long drill bit. Put in the hole of the corners of the housing units and drill out the little screws. Then you have the take off the two screws attached to the bulb. Replace Bulb and put it back together the same way. It's best to use a magnetic bit or at least an extension that's magnetic to reach the screws. They are easy to take off, but will be harder to put on.
Posted on Feb 07, 2008
Does my panasonic hdtv 1080i pt-50LC14 have a lamp
Yes it does! Behind the front bezel under the screen. you can buy it here. http://projectorlamps.com/panasonic-dlp-tv-bulbs-pt-50lc14.html PT 50LC14 Panasonic Genuine High Quality Original Projector Lamps now...
Refer to the manual or the instructions that are shipped with the lamp.
Apr 25, 2015 | Panasonic Televison & Video
I have a panasonic PT-50LC14. the tv will turn on, but there is no picture. do i need a new lamp or bulb?
It is possible if over two thousand hours of use or two years, I would suggest at least removal and inspection to see if lamp shattered.
Sep 03, 2012 | Panasonic PT-50LC14 50" Rear Projection...
Where is the lamp housing for the Panasonic
The lamp housing is located behind the front cover panel.When you open the front panel you can access the lamp unit screw.
thanx
Jul 21, 2010 | Panasonic PT-50LC14 50" Rear Projection...
How do i get lamp out off housing
lamp and housing are sold as one unit..remove screws and replace whole assembly.lamp is made of quartz.handling bulb will shorten life of silver halide bulb.bulbs wires are usually connected with screws if replaceable or could be crimped on.too hot to be soldered on
Feb 18, 2010 | Panasonic PT-50LC14 50" Rear Projection...
Tv will not power up Panasonic PT-50LC14
ok guy's i have the same tv and simular problems, first check the lamp light located next to the sd disk input (on the front). if it's not blinking then 2 things 1) more than likely it's the lamp if you haven't replaced it by now your one of the lucky ones, you can find them online for around $100, in which i paid over $300 for two differnt bulbs. the warrent only covers 1 bulb. 2) this happens to me once in a while try unplugging it let it set for a minute or two, replug it back in and try it again. but it depends if the light shines yellow (orange) and blinks twice, then try it again. you kinda have it cycle through and that should work. if not then unplug the unit, then take off the front cover and use a philips screwdriver remover the bulb (located behind the cover in the front) then i highly recomend doing this on a weekend pull out the shop vac and **** out the dust inside the lamp housing, then take off the back housing along with the left side speaker and first clean it out with a rag, then go through it with the shop vac. basically if dust builds up the unit will trap the heat and that it's why it will overheat and shut down.
Mar 10, 2009 | Panasonic PT-50LC14 50" Rear Projection...
Issues after replacing bulb
Turn off the tv and let the lamp cool. Remove the housing and examine if the lamp is crooked in the housing.
If not, you probably has an issue in the optics block (a filter or mirror has shifted). This is a major repair or diassembly the light engine to check the optics.
Aug 22, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Replace pt-50lc14 lamp
No it is NOT easy.. it really is a "Job for the shop" .... GL
Jul 23, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Plastic housing
moz-screenshot-1.jpgTry this link and download the manual. See page 81.
http://www2.panasonic.com/consumer-electronics/support/Televisions/LCD-Projection-TVs/model.PT-50LC14
Nov 16, 2007 | Panasonic PT-50LC14 50" Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
65 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
