Question about HP OfficeJet 9130 All-In-One Thermal Printer
Aligning printer heads
I have a hp officejet 9100 series printer, i recently had to update the firmware and now every time i print out anything it goes right in to aligning print heads how can i fix this
Same problem with my printer, called tech guy charged 100 bucks for nothing. Actually changed the cartridges. All cartridges have to be new and check the date on the cartridges, if installing 2006 cartridges, just use all of the same date , if using 2007 just use that date. It should work fine after that.
Posted on Feb 01, 2008
6ya staff
SOURCE:
How to up date hp Officejet 6700 Primium all-in-one code auf8437ojde38
  1. Switch on the HP Officejet 6700 series printer and wait until the printer is READY. [The Power light should be on]
  2. Double click on OJ6700_R1435A.exe to launch the HP Printer Update utility. A list of OfficeJet 6700 Premium series printers detected will be displayed on the screen.
    Note: If the Wired network printer you wish to upgrade is not displayed in the detected printer list, click on the Refresh button to scan for printers connected via the wired network.
  3. Click on the checkboxes on the left to select single or multiple OfficeJet 6700 series printers you wish to upgrade.
  4. Click on the Update button to start the firmware flashing process.
  5. Message showing "The selected printer has been updated successfully" will be displayed. Firmware flashing will begin.
    CAUTION! Do not interrupt the printer during the upgrade process. Printer may be damaged if power is interrupted during the firmware upgrade process.
  6. When the printer has successfully completed the flashing process, it will automatically print out a Self Test Diagnostic Page, that will show the new firmware version.
  7. Click on the Done button to close the HP Printer Update utility.
HP Officejet 6700 Premium All in One Firmware
Nov 14, 2014 | HP OfficeJet 6700 Premium All-in-One...
HP Officejet Pro L7780 all-in-one, Windows Vista, set up as a wireless network printer, prints multiple copies of test page and also other documents, when only one is selected both at the computer and...
this is a simple problem, the technology that printer aligns its print head automatically by the reading the align page, if your printer head are not in good health/clogged align print wont come properly result align pending..When printer gets power on its prints align page till align completes. Go to tool box in system all programme, perform clean print head, check the quality of printer outs then ask to printer to align.. if its not completing replace print heads..
Sep 10, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
6110 officejet, power light blinks. display says "warming up" continuously?
Pls run the attached file to resolve the issue.
Description:
These all-in-one product firmware updates will resolve issues with receiving faxes, warming-up, certain printing issues and memory full messages with the HP OfficeJet 6100 series products.
Warming-up - Under certain circumstances when the all-in-one will display "warming up" indefinitely after pressing one of the "Copy" or "Scan" buttons
After downloading and installing this firmware update, the software will determine if the hp all-in-one would benefit from this firmware update and inform you of the results.
Installation Instructions :
Download the file "HpAiOFWUpdate2_2.exe" via http://www.printer-drivers.com/drivers/246/246484.htm to a local hard drive. Make note where (in which folder) the file gets copied.
The hp all-in-one software for the OfficeJet 6100 series must be installed on your PC before installing this firmware update. The OfficeJet 6100 series must also be connected to your PC and turned on before proceeding.
Locate the file "HpAiOFWUpdate2_2.exe" on your hard drive and double-click the file to install the firmware update.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 15, 2009 | HP Office Equipment & Supplies
We have put new color cartridges but the color is not good... & we can see the lines of the printer head (?) It just started doing this recently. It printed beautiful pictures before! It is a hp...
Many printers need the heads aligned once you install them. Some printers will do a high level alignment however to properly allign them you should use the tools section for your printer and click the align cartridge/heads selection. If you don't see the maintenance/tools tab when you open your printer from control panel, you may be using the generic Microsoft driver and need to install the drivers from the manufacture.
Sep 02, 2009 | HP OfficeJet 7110 All-In-One Thermal...
HP 6110 swaping colors
this should be problem with u r Printer Firmware ..u need to update it .plsase use below link for Software & drivers of 6110 printer
frist u select correct OS witch used for u r Pc
then in frimware option download "Firmware update for the hp OfficeJet 6100 series" if u want any update for u r printer get it form this link.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=79477&lang=en&
if this information is useful for u Please Rate me......
Jun 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
K550 printer not printing Black
hi there is a simple solution to your problem take out the print head place just the jets( where the ink comes out) in warm water for a few seconds while it is in the water use a syringe over each breathe hole at the top of the print head (one at a time) and lightly push air into the head. this process clears any ink clog and frees up the print head and allows it to print propely
Jan 25, 2008 | HP OfficeJet Pro k550 Printer
HP OfficeJet 6110 Prints very slow then aborts about 1/3rd way through print
I identified this issue with my Officejet 6110xi All-in-One as firmware corruption. Attempting to install the supplied firmware update gave the error that "no hp device connected to the computer would benefit from it at this time." Attempted to power down the printer using #9 keystroke and got "FULL RESET" message, but problem of extremely slow printing and erratic behavior of the print heads persisted. I solved the problem by putting the printer outside in cold weather for two (2) days. This frequently resets firmwares with software corruption back to their embedded EEPROM state. Hooked the printer back up and worked fine. If cold weather is not available you could try other creative methods of cooling the device, just use a plastic bag and with ideally some drying packets thrown in to prevent excessive moisture buildup in the cold environment. The colder it is the faster the firmware resets.
-Paul Ronco, Computer Technician
www.paulronco.com
Oct 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 9130 All-In-One Thermal Printer Logo
213 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
