Question about NetGear WGXB102 Wireless Range Extender Kit
Cannot configure WGXB102 with router
Hi, I can't alter the WGXB102 wireless setting so that it matches the router..I tried connecting http://192.168.0.101 in my Browser but never can get the web page ,why???? I need to alter the setting , please show/tell me how!!!
    Problem Solver:
  • 5 Answers
Pl. try the following
1. do hard rest of your router i.e at the back of your router u'll see a tiny reset hole in that whole put in a ball pt. pen and press the hole hard for 10 sec. and some lights on the router should start to flash then take out the power cable for 30 secs and then again plug in the power cable and try opening the router page and do'nt add www to the address.
Posted on Mar 13, 2008
  • 854 Answers
2. Reset WGX102 device.
a. Please push the reset button in the WGXB102 using paper clip and release after 30 seconds.
b. Unplug the WGXB102 for 10 seconds and then plug it back in.
3. Set Static IP address on the wireless laptop
a. Please click on Start, select Settings and then Control Panel.
b. Double click on the Network Connections icon.
c. Right click on Wireless Network Connection and click on Properties.
d. Scroll down to Internet Protocol TCP/IP and click on Properties.
e. Change the option Obtain an IP address automatically to Use the following IP address and enter the following:
IP: 192.168.0.5
Subnet Mask: 255.255.255.0
f. Click on Ok button and close Local Area Connection properties.
4. Connect wireless laptop to the WGXB102.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select NETGEAR and click on Connect
f. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select NETGEAR and click on Connect.
5. Access WGXB102 Web-based utility.
a. Please open any web browser like Internet Explorer or Mozilla Firefox.
b. Connect to the router by typing http://192.168.0.101 in the address field and click Enter or Return key.
c. For security reasons, the WGXB102 has its own user name and password. When prompted, enter admin for the user name and password for the password, both in lower case letters.
6. Change WGXB102 Mode
a. Click on AP/router mode under setup.
b. Select the option Router (access point + NAT router) under operating mode then click Apply.
7. Configure wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name. Make sure that Broadcast name is Enabled.
c. Mode set it to G and B and Channel should be 6.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter 10 digit numbers.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. You may want to use WPA personal for the wireless security.
g. Click Apply button to save the changes.
8. Set the wireless laptop back to dynamic IP address.
e. Check the option Obtain an IP address automatically and Obtain DNS address automatically.
9. Connect wireless computer to the router.
Connect wireless using Windows XP Service Pack 1.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
Connect wireless using Windows XP Service Pack 2.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
From the above configuration please check if you are now able to go online wireless using the WGXB102.
Posted on Apr 10, 2009
    Problem Solver:
  • 14 Answers
Well aster the ip to get into your router 192.168.1.1 that should get you in so you can make changes
Posted on Feb 01, 2008
I cannot connect to our office wi-fi connections. It says authentication failed. how can i able to connect. pls help me.
Hi,Please try these steps:-
Wireless router side
  • 1. Set wireless mode to B-G Mixed
  • 2. Standard Channel = 8
  • 3. Encryption - TKIP
Phone side
  • 1. Delete the configured wireless connection/s if you already have one.
  • 2. Enable wi-fi but do not perform search at the moment
  • 3. Now open the browser and select settings then browser profiles press search for wi-fi.
  • 4. Select the connection that you want to connect to then type the details and match the settings on the router.
  • 5. Auth type = WPA, encryption = TKIP, network key = router pre-shared key, protocol = HTTP, Home URL = address of modem (you can change it later if everything is already working), leave proxy blank, linger = default, adhoc = off, no need to do advance settings.
  • 6. Save the settings and do not connect yet.
  • 7. Exit the browser and go to Wi-Fi and select the connection that you have just configured and select details.
  • 8. Check all the settings if ok. if the channel is different with the router, adjust it on the router to match the one used by the phone. IP address = not connected (it will automatically connect once you browse the internet).
  • 9. Now, try to browse the internet but you must set first the connection you've just configured as default connection.
hope rhis will be helpfull to you. Please rates me. goodluck.............
Feb 03, 2011 | Samsung Star GT-S5233 Cell Phone
How to connect Wi-Fi on SAMSUNG 5560
Please try these instructions:
Phone side
That's it. I hope that this helps. This applies only to personal wireless network.
Oct 31, 2010 | Computers & Internet
How do I switch on WEP encryption to prevent my
please follow steps to fix issue
1.connect WGXB102 to computer with CAT5 cable
open setting page of device
2.open internet explore type there:192.168.0.101
user name "admin" password is "password"
3.under setup click on wireless setting now you can click on WEP then type security
reagrds
prakash
Jan 23, 2010 | NetGear WGXB102 (wgxb102na) Ethernet...
WIFI not working with Linksys wireless-g broadband router/Comcast
Unplugging the wireless router and connecting it again should not have altered the wireless connection/configuration. You have connected the cables correctly because the Internet works when you connect a LAN cable to the router.
The Linksys wireless configuration or the wireless card configuration in the computer was changed it to lose the wireless connection. The wireless card configuration needs to be changed to match the wireless router's settings or change the Linksys with new configuration settings and configure the wireless card accordingly.
To secure your router with a login password and wireless security, please follow my instructions - click on this link :-
http://www.fixya.com/support/r3559128-wireless_router_security
Should you need further assistance, please leave me a comment.
Dec 25, 2009 | Linksys Wireless-G Broadband Router
Cannot set up security on wireless router "wireless card nt found
Are you trying to configure the router wirelessly. Connect your computer to the router with a lan cable and then access the router and change its wireless settings. since you cannot change the wireless settings wirelessly as you will get disconnected.
Sep 03, 2009 | SMC Barricade g SMC2804WBR Wireless Router
Connecting new linksys n to our brother mfc685cw wireless printer. Printer will not read new linksys n router
For isolation purposes, you may want to test the printer through the Linksys router via Ethernet cable and see if you can print if it is wired to the router. From there, configure the wireless printer to match the settings on your Linksys router. Once done, try printing again wirelessly.
Tips:
1. Make sure that they are on the same LAN segment. By default the IP address of the Linksys router is 192.168.1.1. so you may want to configure your printer using 192.168.1.2 for them to communicate.
2. Make sure that the wireless settings on the Linksys router match the wireless settings on your wireless printer. Check the SSID/Wireless Network Name and Wireless Security. All wireless settings should be the same for them to communicate wirelessly.
Jul 12, 2009 | Linksys WRT160N Wireless Router
I can not remember the IP address for WGX102 Range Extender
run ipconfig/all on a PC connected to the router. The default gateway usually is the router's IP.
Jul 09, 2009 | NetGear WGXB102 Wireless Range Extender...
Need to protect my wireless network!
you must logon to the NetGear wireless router and setup wireless security. choose a security type usually WEP, type a key phrase or passphrase and voila, you will have to re-connect on your clients by entering the password when you get prompted for it.
Jun 03, 2009 | NetGear WGXB102 Wireless Range Extender...
Can't connect to Belkin N1 Wireless Router
when you reset the router to factory defaults everything goes back. so try to connect with cat5 cable and in IE link bar type 192.168.2.1 and you will get the set screen of the router admin and password sholud get you in the you can look at the settings wep, etc. then change you pc to match
Mar 28, 2008 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Netgear WG602 wireless router,
Hi, Assuming that the WG602 is fully operational, when you did a hard reset, the router reverted to its original factory setting as you posted. The default pre-configuration: act as a DHCP client; if the WG602 does not find a DHCP server on the Ethernet LAN, it defaults to this IP configuration: DHCP Client - Enable IP Address ? 192.168.0.227 IP Subnet Mask ? 255.255.255.0 Gateway ? 0.0.0.0 Your PC need to be connected via a LAN cable to one of the Ethernet ports of the AP/Router to be able to configure it again to your desired network settings. Further it is necessary likewise to manually configure the connected PC's networking configuration to match the router. Manually configure your PC's IP Address to 192.168.0.228, Subnet Mask ? 255.255.255.0, Gateway - 192.168.0.227. You can now try configuring the router through its web interface (192.168.0.227). This is better explained in the user's manual available at the Netgear site ( Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Oct 03, 2007 | NetGear WG602 802.11g/b Wireless Access...
Computers & Internet Logo
1,328 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
