On philips 25GR9660/22B Chassis a PTC 96012 (3 pin) is installed.
It must be replaced because was burned, but this not available any more in market place. So a corresponding item is needed. Is there any suggestion?
Comments:
Jan 24, 2008
- PTC 96212, 96202, 96312 are also unavailable. Can 96012 be substituted by a combination of resistances or something else?
we have a philips model 28pw6506/05 and when we turn the tv on it comes up with locked on the screen...
(More)
we have a philips model 28pw6506/05 and when we turn the tv on it comes up with locked on the screen please help??
D/A Raider Ham Tube Linear Amplifier . Everything looks great, but the 4 main sweep tube filaments...
(More)
D/A Raider Ham Tube Linear Amplifier . Everything looks great, but the 4 main sweep tube filaments overheat, glow abnormally bright . I do not use this amp because it will just burn up the 6LQ6 sweep tubes . I havn't made tests, but I suspect a possible short in the transformer . The filament winding, and the high voltage windings are combined in a single large transformer . I don't know how to match a transformer for this OLD unit . I was considering a seperate filament transformer . The power cord has been replaced with a modern grounded type, but that looks fine . All switches, relays, wiring, and hardware are good . The 4 main HV capisitors are new . The cooling fan has beed updated . If anyone is still living who understands tube amps, and has a clue to solve this problem your help may keep this cool antique alive . Thanks, J.
When machine is switched on, instant picture frozen and red light in bottom right corner. Switching...
(More)
When machine is switched on, instant picture frozen and red light in bottom right corner. Switching off at mains cures it. No mention of red light in the handbook I have. Any help appreciated
our TV has suddenly developed a problem - it turns on but immediately turns off again - cannot get...
(More)
our TV has suddenly developed a problem - it turns on but immediately turns off again - cannot get any channels or play dvds through it
