Question about Maytag Neptune MAH5500B Front Load Washer
Service Mode does anyone know how to access the service mode to run tests
  • 770 Answers
System Diagnostics
SERVICE MODE
The service mode provides service personnel the
ability to verify the operation of the washing machine.
The service mode can be entered in the middle of
any wash cycle. While in the service mode, the
servicer can start a variety of special service tests.
Accessing Service Mode:
Pressing down the delicates and heavy soil keys for
3 seconds places the machine in the service mode.
Motor speed will be displayed when started. To exit
Service Mode, press delicates and heavy soil keys
for 3 seconds again.
Troubleshooting
December 2004 4 16025861
©2004 Maytag Services
Stage of
Wash Cycle
Advances To
Presoak End of Presoak
Wash Every 5 Minutes of
Wash Time
Spin/Drain Every Step of The
Spin Profile
Rinse End of Rinse
Speed Range Displayed
a) 0-99 rpm 0-99 (actual)
b) 100-999 rpm Speed / 10
Quick Service Cycle
While in service mode, pressing the delicates key
will start a quick service cycle. This will be a quick
check of all systems.
The following steps will be followed.
1. Energize the cold and bleach water valves. Fill to
Low level, then turn bleach and cold off.
2. Energize the hot and fabric softener water valves. Fill
to high level, then turn all valves off.
3. Lock the door.
4. Tumble using 7/3 tumble pattern for 12 sec.
5. Turn the drain on.
6. Spin to 800 RPM using default rates.
7. End spin and coast down.
8. Unlock the door when the RPM is zero.
9. Display a ‘PA’ (Passed) on continuously for 10 seconds
if no diagnostic codes were logged during this
test.
The up arrow if pressed will advance to the next step.
The right most dot will be turned on as an indication
of failure and stay on until quick service cycle test
has reached the end. Any diagnostic code logged
during this test will result in failure of the test, but will
not necessarily stop the test. While in quick service
cycle, the pressing of the hand wash will suspend
the machine at this step for 30 minutes until the
Hand Wash key is pressed again. All LED’s will
flash on and off while the cycle is suspended, or on
hold.
Motor Drive System
To check the system, check the board for proper
output to the motor control. Performing a board
output test does this. Then perform the Motor
Control Board Output Test.
Motor Control Board Output Test
1. Disconnect power to the washer.
2. Remove the front panel and pull the JP4 Connector
from the motor control board.
The following Quick Spin test steps are as follows:
1) Lock the door.
2) Spin to 350 rpm and hold for 6 seconds.
3) Spin to 550 rpm and hold for 6 seconds.
4) Spin to 600 rpm and hold for 6 seconds.
5) Spin to 650 rpm and hold for 6 seconds.
6) Spin to 800 rpm and hold for 6 seconds.
If the Spin key is pressed again during the Quick Spin
test, the current speed will be held indefinitely. Pressing
the Spin key again will allow the quick test to
proceed as listed above.
When the washer is in the Service Mode, the speed
will be displayed as a two digit number or a letter/
number.
Quick Spin Test
While in service mode, the pressing of spin key shall
start the washer in the quick spin mode.
3. Reconnect the washer power cord to supply
voltage. Make sure the door is closed.
4. Press delicates and heavy soil keys for 3 seconds
to activate Service Mode.
Posted on Jan 23, 2008
Press and hold delicatse and heavy soil buttons for three seconds
Posted on Jan 29, 2008
Trying to find hidden service menu on the Polaroid 48GSR3100FJ model HDTV to downgrade refresh rate from 120hz to 60hz
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Dec 07, 2015 | Polaroid Televison & Video
Tip
Samsung GALAXY phone - Service / Test / Hidden Menu, Secret Codes
How to access hidden functions / diagnostic menu at yours GALAXY.
Popular practices for the software developers is to leave "back-doors" within the code, which essentially allow anyone with knowledge to get into the system at a much deeper level.
This codes are working for Galaxy S2 / S3 / S4 / S5 / Note 2 / Note3.
Very simple and easy tips and tricks. Codes in this video:
IMEI - *#06#
Version - *#1234#
Main Version - *#12580*369#
Battery Status - *#0228#
Service mode - *#0011#
Service / Test / Hidden functions - *#0*#
on Aug 28, 2014 | Samsung Galaxy Cell Phones
Bizhub C20p service password
If you were qualified you would have the service manual...Default passwords could be
12345678
00000000
77777777
92729272
If that's not it, someone has changed them and it will need to be reset through service mode.
Nov 26, 2013 | Konica Minolta bizhub Office Equipment &...
Does anyone know how to access the service mode to run tests on MAH8700AWW Washer
In the upper console area there are tests on the tech sheet.
Nov 01, 2012 | Washing Machines
We have a service agreement on several printers. It's time to get the meter readings.How do you access and print out the print count/statistics log on a Hp LaserJet4Plus?
The following procedure is used to initiate the Service Mode.
1 Hold down the [Menu+] and [Value+] keys while powering ON the printer. Hold the keys down until SERVICE MODE is displayed.
2 The interrupted power-on self test is resumed. If the test completes successfully, the message SERVICE MODE is displayed.
1 Enter the Service Mode as described previously.
2 When SERVICE MODE is displayed, press the [MENU] key to access the Service Menu. Press the [ITEM] key to step through the menu.
3 PAGES=XXXXXX is displayed. XXXXXX represents the page count currently stored in the printer's NVRAM. The underlined character denotes the cursor position.
Jul 29, 2011 | HP LaserJet 4 plus Printer
Drain pump will not come on. There is a way to go into "engineering mode" to force it on to troubleshoot it. Do you know how to go into engineering mode and force on drain pump?
You can go into Service Mode and turn it on with the console key pad.
Brief write up to turn on the drain pump in Service Mode;
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads "00"
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
The Service Manual and Sears Parts Direct for reference. You could have something jamming the impeller of the drain pump. Turn it on in Service Mode and see if you hear it spin up.
The drain pump sits in the right back corner of the machine with no access from the rear or sides you have to remove the front panel to access. I'll post a pick of the wash tub removed so you can see. The drain pump is on the back right side and the Motro Controller is on the left front side as the pic below shows.
Sep 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune tl fav6800aww wont dispense fabric softner
Test mode? Do you mean Service Mode and you turn on the solenoid for the water valve to divert water to the Fabric dispenser reservoir and it is flushed in Service Mode?
See if this solution will help with your trouble shooting.
Let me know if I can help……Rich
Apr 19, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I can not get it into service mode.
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Mar 15, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer stops after filling with water on the first cycle...will not spin Neptune stops after filling. No codes. Lid unlocks. Ideas?
Hello n8mtsn,
I would pull the 120VAC power cord to the washer for 10 seconds then power back up.
See if you can get into service mode. To enter Service Mode press and hold he Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”. If you can’t get into Service Mode I feel you have a Control Board issue/failure.
If you can get into Service Mode then go to page 15 of the SM and we want to try a Quick Service Cycle test. Follow the instructions to enter the Quick Service Cycle test and let us know the results. If the test will run it will take about 10 minutes.
Link to Service Manual for reference. Sears Parts Direct for reference.
Rich
May 30, 2009 | Maytag Neptune FAV6800AW Top Load Washer
All the LED ligths ON
In the back of the display panel. remove the metal cover with the dryer UNPLUGGED.There is a booklet that tells you how to access the service mode by pressing 2 certain buttons at a time certain dryer functions can be accessed. One of the tests were to check the led lights on your control panel, when you run the test all the lights would light up. it's a possibility if you acess the service mode and run the led light check it could possibly reset it and solve your problem. It's a shot but it can't hurt. Getting into the service mode to test certain modes on your dryer is easy enough.Just read the instructions. Good luck.
Dec 23, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MAH5500B Front Load Washer Logo
2,977 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
