Question about GE 32GT740 32" TV
GE 32" TV Problem
The basic cable channels I have are channels 2 through 80. When I turned on the TV this week, channels 2 through 50 do not display. Channels 51 through 80 are perfectly clear.
I moved the TV to another room and same problem. I tried a different TV at this location, no problem.
Is the tuner gone bad?
  • Polorb Jan 24, 2008
    Autoprogram deleted the channels but did not correct the problem.
    I found out if I leave the TV on for about 15 -20 minutes, the lower channels will begin displaying on their own again. It appears the tuner has to "warm up" for them to start working properly.
  • 2,336 Answers
I would suggest to do an autoprogram again and see it that helps.
Posted on Jan 23, 2008
Dynex 32" tv cant get regular channels,
How is your TV setup--do you have a cable box, satellite, or basic cable? I would recommend going into the settings and running a channel search.
Press Menu. The on-screen display menu options with Setup highlighted.
Press RIGHT arrow to enter the sub-menu, then press DOWN or UP to highlight AUTO CH SEARCH.
Press ENTER or RIGHT arrow to start the search.
Oct 10, 2013 | Dynex DX-LCD19-09 19 in. LCD TV
Channel display for Sony WEGA KV32FS100 will not turn off
Most all Sony models use the same programming for the remotes. Borrow a Sony remote and push the display to turn it off.
Mar 23, 2009 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Can't program channels past 14
select cable as a source not broadcast its looking for UHF channels instead of cable up to say 100. go to setup select cable not antennea or broadcast. do a scan afterwards and ghave it find your channels
Dec 08, 2008 | GE 32GT740 32" TV
Mitsubishi projection tv display does not turn on
unplug your tv for an hour and let it reset the cable didnot hurt your tv if that doesn't work check the tv's bulbs
Dec 07, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Channel displaying on Samsung 32"LCD TV
Most remote controls have a "display" button. Pressing that is what gets that channel number on the screen. Try pressing it again and the display should turn off. On some brands the display may cycle through various combinations (channel number only, channell and time, etc.) before it goes away, so it may take more than one press of the button.
Dec 03, 2008 | Samsung 32 in. LCD Monitor TV
Programming prob on GE TV model #27GT615
There has to be a signal on one channel at least below 50. connect a DVD player to the TV and try programming. You are supposed to have a signal on cahnel 3 or 4.i hope this helps you. thats all I can think about now.
Nov 03, 2008 | GE 32GT740 32" TV
GE 32GT740 32" TV problem
there are two things that can cause this, 1 there is a muting transistor on the bottom of the PCB that is a surface mount transistor that goes short. this is the channel mute transistor. when you change channels it is designed to mute the static between channel changes. if it shorts then it mutes. 2 the EE-PROM is defective and needs to be replaced. i'de go with the transistor first. if you are unequipped to do this repair have a tech do it.
Mar 02, 2008 | GE 32GT740 32" TV
No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Feb 16, 2008 | Sharp 32R-S50 32" TV
Sony TV KV-32v26
Do you mean basic CABLE channels or Aerial channels? If aerial, what kind of antenna are you using (you must have SOME sort of antenna... rabbit ears, set-top, etc...)?
Sep 20, 2007 | Sony KV-32V26 32" TV
No sound
have you check with other input like a vcr?...good luck
Aug 10, 2006 | RCA F32649 32" TV
GE 32GT740 32" TV Logo
56 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
