Question about Panasonic PT-50LC13 50" Rear Projection HDTV
No picture I have replaced the bulb and reset meter but still no picture when i hook up my cable. I get a picture when i put in my camra disk. HELP I NEED TV
  • 87 Answers
Check you cable hookup, It has to work if the camera disk works. Call cable company and have them send out a NERD
Posted on Jan 25, 2008
I have a Philips 50 DLP HDTV MICRO DSPL and I figured the lamp was about to go out because after you would watch tv for about an hour and a half the picture would begin to flicker so I replaced the lamp...
A couple of things to check here. When you replace a lamp some TVs require you to reset the lamp hours meter in the settings in the menu (More common in projectors). If you do not do that then it will only run so many hours before shutting off again. If it is that, you should be able to turn it off and have enough time on the screen to reset that. If that is not the case then you should look into replacing your power supply board.
Aug 23, 2014 | Televison & Video
No picture
If you are not using the correct bulb, that is exactly your problem. Get the correct lamp.
Mar 15, 2013 | Mitsubishi 915p020010 Wd-62825g / We-52825...
I have a 7 yr old sony kf50we610 rear projection lcd tv. Two years ago the picture and sound started going off and coming back on. I replaced the bulb and it solved the problem. Now two days ago the...
As it was explained in live chat session, cable box needs reset/ reboot because tv has normal picture in other inputs.
After resetting/ rebooting cable box, problem is solved.
Jan 15, 2011 | Televison & Video
try to rest the tv by unplug from outlet press power hold it them reconnect power cord while you hold the power buttom on tv for 30 seconds them release and do the same with cable box.
Dec 12, 2010 | LG RE44SZ20RD 44" TV
After just recently replacing the bulb I am
Here is proceudre to reset lamp timer in your TV..
While pressing the VOL Down button on the projection display, hold down the PIP or SPLIT button on the remote control at same time for more than 5 seconds.
When reset procedure is complete, the screen message ' lamp time was reset to 0' will appear.
Hope this info will help you.
Nov 18, 2009 | Panasonic TY-LA1000 Projector Lamp for...
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Not to computer saavy so please keep it simple. I have a Sony Vaio VGC RA840G desktop with 5.1 surround sound. Also have a Samsung LN46A850 S1F HDTV. Also a home theater system. This is hooked up to cable...
From the looks of the TV manual you have everything right, so it's very odd you're running into this problem.
Have you tried swapping through the sources? I find with one of the TVs we have on display at work that any time I'm having some troubles with it I will change the source from PC to something else, then back to PC.
If that doesn't work then I'd suggest you try reseting the sound settings back to factory default. The instructions are on page 45 of the TV manual. From the TV menu select "Sound", then "Sound Reset", then either "Reset All" or "Reset Sound Mode". I would suggest reseting all.
Last option would be to try using the headphone jack in the side of the TV, though this is a last resort kind of thing since you would have to unplug it every time you wanted to use the cable box.
Hope this helps :)
Apr 16, 2009 | Sony Computers & Internet
Reseting the lamp meter on tv
1) Press the POWER button to turn your TV on. Make sure you are set to Cable/TV reception. If the "replace lamp. Reset Lamp timer" notice appears, press "EXIT" on your remote.
2) Press and hold the VOLUME DOWN BUTTON on the TV set (not the remote, the actual TV set)
3) Continue to press and hold the VOLUME DOWN button and press and hold the PIP (Picture in Picture) or SPLIT/PLAY button on your REMOTE control (your are pressing and holding BOTH of these buttons at the same time now).
4) After 5 or 10 seconds (be patient), the lamp serice menu will appear and say your lamp counter has been rest to '0' (zero). That's it, you are all done.
Now, I continue to have the power shut off after a few minutes of play. I think it is a problem with the cooling fan. Damn it all anyway.
Dec 21, 2008 | Panasonic PT-43LC14 43" Rear Projection...
No picture from samsung blu-ray to samsung TV
Put the blu ray player into the tv to see if you get a picture,if you do put it back into the amp then assign the hdmi input you have used in the amps set up menu,if you did not get a picture when hooked up to the tv run a cable from the video [yellow] out put to the video in put on the tv and then set the out put of the blu ray player.
Hope this helps.
Nov 16, 2008 | Electronics - Others
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
