Question about BenQ Joybook 8100 Notebook
Broken power jack joybook 8100
What type of power jack do I need to replace the broken one
  • valdana007 Jan 24, 2008
    thanks,did it and got it from ebay,but....center pin is 1.6mm and from what I understand now it should be 2.5mm.this time I need to be sure i order the right type
    Genius:
  • 1,067 Answers
Type in your model on ebay ok with power jack after they will come right up tons 7 bucks its a fun job too very tricky
Posted on Jan 24, 2008
My daughter's Dell Latitude E5500 won't charge. If I plug her charger into my exactly the same model - works fine. The moment the power lead touches her input port, the light goes off and then the cha
1. Does YOUR charger work on her computer? If yes, you need to replace her charger.
2. If YOUR charger doesn't work on her computer, then the problem is most likely a broken power jack (or a "cold solder joint" on the power jack). The power jack is mounted directly on the motherboard, therefore the entire computer needs to be disassembled to repair it. Here's a link to a YouTube video showing this repair:
https://www.youtube.com/watch?v=OoT9XVn5Y2s
Best of Luck!
Oct 11, 2014 | Dell Latitude E5500 Laptop
Plugged in not charging
There could be several things wrong. You could have a broken DC jack on your motherboard. To prove this, wiggle the DC jack with the adapter plugged in. If the charging light comes on when you wiggle the jack, then your jack is broken. You could also have a defective AC adapter.
Jan 06, 2013 | Toshiba Satellite C655-S5125
SAMSUNG NP R430 POWER JACK
There is something seriously wrong with the power jack for it to get very hot. I doubt replacing the power jack will fix this problem. The laptop needs to be repaired by a specialist.
Jul 28, 2012 | Samsung R430 Notebook
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
Pedal jack not working. can it be repaired or replaced?
First verify that the pedal you are trying to use is the correct sense, either normally open as most or normally closed like Roland types. Jacks if physically broken can be replaced. Unit has to be opened and correct jack replaced or in some cases the jack has just broken loose from the solder on the board.
Dec 28, 2010 | Casio Privia Keyboard Case
Powerjack is loose when plugging in charger.no power,no lights battery can not be charged.
In order to fix this problem, you will have to fully disassemble your laptop to get access to the motherboard & the power jack. If the power jack is not broken but only loose, you can re-solder it to the motherboard. Otherwise, you will need to buy a replacement power jack (usually less than US$ 10), de-solder the broken power jack, & then solder in the new one.
When this is done, re-assemble back your laptop.
Nov 27, 2010 | Acer Aspire One PC Notebook
How to replace dc power jack for toshiba p15
Take apart laptop and see what type of jack is on your system. There are two types. one is soldered on and the other is a module that connects to the motherboard with a wire connector.
If you have a soldered on type the you will need to de-solder it from the board then solder a new one onto the board. most ac jack issue just need to resolder it unless the jack itself is broken.
May 19, 2010 | Toshiba Satellite P15-S420 Notebook
I have an old compaq evn n610c. I had some problems with it for a while where I had to wiggle the power cord a little to get it to power on with the cable. That worked for a while and then one day it...
Hello,If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack((DC jack)) is broken or loose.
If the power jack is broken you can replace it if you know few things about soldering;)
If the power jack is not broken but loose (not making good contact with the motherboard) you can re solder the old jack without replacing it with a new one.
Jan 20, 2010 | Compaq Evo N610C Notebook
My power jack is broken. Need directions on how
You need to take the unit apart down to the system board. Sorry, I do not have the sefrvice manual.
The link below shows how to resolder the connector on the system board.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
Nov 30, 2009 | Lenovo IdeaPad S10-1208U Netbook
Broken DC jack on Acer notebook
There is a site on the internet that gives a step by step on how to remove the covers and locate the broken part. Type in repair Acer. Also there are labs the will repair this most common problem...Is the jack broken or is the adapeter broken...
Apr 23, 2009 | Acer TravelMate 2480 Notebook
BenQ Joybook 8100 Notebook Logo
200 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
