USB 2.0 works as USB 1.1
Support CD for m/b installs but doesn't mention USB. Driver from ECS website for USB unpacks correctly and the setup runs but terminates within a second without displaying any messages.
When devices are plugged into any of the USB ports windows displays a message that the device would work better in a USB 2.0 port.
Tried 2 identical motherboards with Win XP pro and Win 2000 pro.
There are 4 USB connectors on back ad a header for the front ports, all act in the same way. ECS PT890T-A v1.0 motherboards.
  • Anonymous Mar 16, 2014
    I strongly dislike plugging a device into the front USB ports, but sometimes, I accidentally hit the reset button. I am trying to find a way on how to disable that particular function without having to open up my case and remove some connection in wires on the motherboard.
    Scholar:
  • 134 Answers
My printer does not appear in my computer
Hi
May you remove or uninstall by mistake that's way is not showing now don't install again to follow the mention below instruction.
1) Plug on you USB cable to PC and power on the printer.
2) Put the Lexmark printer software installation CD in you computer CD-Rom.
3) Open the CD-Rom, and duble click the setup exe.
4) The setup will take few minute to install the driver.
5) After installing the driver reboot your computer. and start to printing
Cheer
Aug 03, 2011 | Lexmark X4650 InkJet Printer
Installation CD & Quick Guide
Follow this link for your manual, driver, and FAQ's http://www.megxon.com/techsupp/download/X3/X3_supp.htm Driver install 1. Download driver file "X3_Driver.exe" and save it to PC hard disk. 2. This driver file is a self-extracting archive, run it and it will extract automatic. 3. Run "X3 Driver.exe" and will show "WinRAR self-extracting archive" dialog. Press "Install" start extracting. 4. After, in hard disk will create a "X3 Driver" folder. 5. Enter "X3 Driver" folder and find "Install" folder. 6. Enter "Install" folder, find "SETUP.EXE" and run it. The installation wizard will guide you through the installation. -------------------------------------------------------------------------------- How to set the USB function to PC Camera or Storage mode (Regarding how to set the USB function to PC Camera or Storage mode, please reference user manual in page 42.) When connect DSC to PC, it will become a storage device or PC camera depend on the setting of USB in the setup mode. 1. Press the "Manu" button (in the back, left-up side of 5 ways switch) into Menu section. 2. Then press right key to "Setup". 3. Press down key to "USB" then press right key. 4. Press up or down key and change it to "PC camera" or "Storage". 5. Press "OK" key to confirm. -------------------------------------------------------------------------------- How to Format internal memory or memory card (Regarding how to format, please reference user manual page 27. ) > Formatting SD Card Prior to its initial usage, format the SD card. To format the SD card, please insert your compatible SD card into SD slot. Then proceed with the following steps: 1. In "Capture" mode, press "MENU" button into the setting mode. 2. You can see "Capture" and "Setup" in the screen. 3. Press right key to "Setup" then press down key to "Format". 4. Press right key to next step. 5. Press down key to "Confirm". 6. Press "OK" button to confirm. The SD card will be formatted. > Formatting the Internal Memory Take out SD card from the slot and format the Internal Memory by following the above mentioned steps . NOTICE 1. Prior to formatting the SD card, deactivate the ¡§Protect SD card¡¨ function. 2. The internal memory cannot be formatted when the SD card is in the camera.
Oct 03, 2007 | Megxon X33 Digital Camera
Drivers usb install correct but when i use any USB device it not reconogzite
Please uninstall the usb drivers. goto run -> devmgmt.msc -> USB controllers- > uninstall the drivers.
Then run the CHIPSET drivers of your motherboard by running the setup from motherboard CD.
If you dont ahve Motherboard CD, goto link below
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=436&DetailName=Feature&MenuID=24&LanID=0
Download the USB drivers for windows xp is :
http://download.ecsusa.com/dlfileecs/driver/mb/usb/via/via244_xp.zip
Install it.
Even the usb devices are not working.. goto BIOS by pressign DEL key or F2 on power on the pc. Check USB Drivers are DISABLED. if disabled, please Enable it.
Use the Back side USB connectors if the front usb are not wokring..
If you satisfy with my solution please rate/vote for me.
Rating/Voting will encourage me to help others
Jul 01, 2011 | EliteGroup P4VMM2 Motherboard
My printer won't print due to the fact that the troubleshoot says I'm not connected to a computer....but I am. How do I download a new driver to make it work. thanx
Hello Sir, Hi, that is common error with printers today, but this error can be fixed, here are some of the thing you need to do, they may help.
for usb interface. 1. If you are using a USB interface, you need to install first the driver software, along the setup, you will be prompted to power on the printer and plug in the USB cable to your computer and the printer. make your connection here. If the connection fails, do this several times. 2. If the 1. fails try using another USB port.
for centronics parallel printer cable. 1. Make the connection of the printer to the computer before installing the driver software. 2. Power on the printer. 3. Power on the computer and install the driver CD.
If you do not have the driver cd and you did not mention what printer you have. do a Google search, type the printer make and model and search for the driver. download the driver, usually from the manufacturer's website.
Oct 17, 2010 | Computers & Internet
I dont know much about pc how do i get my scanner on my pc
THE steps will guide you through a successful scanner to pc interaction
  • 1
    Unpack your new scanner and set it up. Follow package directions and setup instructions to assemble any parts that need assembly.
  • 2
    Plug in your scanner and power it up.
  • 3
    Insert the setup CD in your CD-ROM or DVD drive. It should autotomatically run. If it doesn't, click on "My Computer" and then on the CD or DVD drive to open the CD. Look for a Setup.exe file. Double-click on it to launch the setup disk.
  • 4
    Follow the onscreen prompts to complete the end-user agreement and install the necessary drivers and software to run your new scanner.
  • 5
    When prompted, connect the USB cable to the scanner, then plug the other end into the USB port on your desktop PC.
  • 6
    Windows will recognize that a new device is available on your computer, and find the necessary software and drivers to install it.
  • 7
    Restart your PC if prompted to do so.
    Troubleshooting
  • 1
    Check all cable connections to be sure that they are secure.
  • 2
    Disconnect the USB cable from the desktop and the scanner.
  • 3
    Turn off your computer and let it cool down for 10 minutes.
  • 4
    Turn the computer on, then turn the scanner on. Reconnect the USB cable to the scanner. Try connecting the other end of the USB cable to a different port on your computer.
  • 5
    If none of these suggestions solve your problem, uninstall the scanner and start over.
  • Oct 02, 2010 | Epson Perfection 1670 Flatbed Scanner
    I do have a logitech webcam,but dont have a software to install.where do i get a free software to download?here's my logitech M/N :V-UAM27
    Here is the things you have to do:
    1. Download QuickCam 8.4.8 with driver for WinXP.
    2. Install WinRAR if not already installed yet.
    3. Open the setup installer qc848enu.exe and unpack its contents to a folder.
    Alternatively, right click on qc848enu.exe and select Extract to qc848enuoption.
    4. Insert or plug in the Logitech QuickCam Messenger to a USB port if not already done so.
    5. An Driver Software Installationã icon in systray (notification area) should appear, which will pop up detailed message if click. It should fail, and ã¢ï¿½ï¿½Add Hardware Wizardã¢ï¿½ï¿½ dialog window will appear.
    Choose to install the driver manually by instructing the Wizard to locate and look for the web cam driver inside the Drivers folder under the unpacked folder of the qc848enu.exe setup program. You can use browser button to select the folder.
    6. Windows Vista should grab the XP driver and install it properly.
    7. Download the latest version (10.5.1) of Vista compliant QuickCam software from Logitech to install the software on Vista.
    http://www.logitech.com/index.cfm/435/3779&hub=1&cl=roeu,en?section=downloads&bit=&osid=1
    8. Run the setup (qc1051enu) normally. You may need to skip the detection of webcam near the end of installation process.
    Please rate this solution
    Rnj VinodKumar
    Apr 06, 2010 | Logitech Webcam
    I lost the cd to install the lexmark x1270
    SOLUTION:
    1. Grab the regular printer driver from the Lexmark website and install it.
    2. Next, keep your USB cords plugged in but turn your printer off.
    3. Download the All-In-One Center Software here.
    4. Unpack the archive, open the "Applications" folder, and double-click Setup. This will install the application - it can take a bit.
    5. Once the application is installed, turn the printer on and try a test scan. If it works, you're good and can quit reading.
    6. If you get an error when running a test scan, don't panic. Reinstall the regular printer driver, using the "Update Driver" option that appears.
    7. Restart your computer.
    8. Do a new test scan. This should bring up the All In One Center's loading screen, which will start searching for programs (this can reallllly take a while). When it's done, everything will be working beautifully again!
    Feb 23, 2009 | Lexmark X1270 All-In-One InkJet Printer
    Won't turn fully on
    1. Download recover.rar from here
    2. unpack the libusb-win32-device-bin-20060827.tar.gz to (example) c:libusb
    3 find e200tool.zip and unpack it to (example) c:e200tool
    lots of archives isnt it )))
    DRIVER:
    1. connect using manufacturing mode (hold button on + center button while connecting)
    2. In device manager find unknown device under USB and update the driver. Select driver manually. Navigate to 0781-0720.inf (came with the archive) (c:e200tool)
    3. When windows promt you to install "libusb0.sys" direct it to с:libusblibusb-win32-device-bin-20060827in
    4. Start-> run -> cmd
    5 type:
    cd
    cd e200tool
    e200tool recover BL_SD_boardSupportSD.rom
    6. windows will find another usb device so instead of "0781-0720.inf" choose 0666-E200.inf
    7 disconnect player and restart it
    STEP 3 (recover bootloader)
    1. connect player in manufacruring mode
    2. Start-> run -> cmd
    3 type:
    cd
    cd e200tool
    but before you hit enter press and hold record button (very important)
    Step $ (firmware update)
    1. connect player in recovery mode
    2. copy PP5022.mi4 to 16 mb partition
    3 restart player
    OK and now If you screw it up - it is not my fault ))
    Nov 20, 2008 | SanDisk Sansa e200 MP3 Player
    Comp doesnt boot after installing USB 2 drivers
    Hi rogueonline,
    Disconnect the external drive from the PC. (It's possible windows registry is messed up).
    It sound like your windows system is a bit confused as well. First try resetting the bios. See page 9 in your manual. (Don't forget to set it back to normal). This should allow you to get back into the bios. Go over each setting & adjust as needed.
    Make sure your primary hard disk drive is listed in the boot order. Advanced Setup Page 30, in manual. If your windows operating system seem is a bit off (OS not installed correctly or driver software not installed correctly). The over-all function of the system can & will run slow. If your primary drive seem to also run slow, the FAT or MBR can be slightly corrupt which will also slow the drive down including file transfer & eventually the drive will cease to function. (The drive can be repaired by doing a full format through windows).
    Do a fresh install of windows, including the full format, (Not a Quick format) on the primary drive. Even though ECS does include the USB 2.0 driver so does windows update service. If your windows was all ready updated & you re-installed ECS's (2003) USB driver, that may have been enough to screw up windows. If you have data on your current drive & need to get that data off & if you have access to another system you can pull your drive & slave it into another system & remove the data. There is no quick fix. Play it safe. Start from scratch. After windows has been installed & you install the ECS driver software, update windows until there are no updates left. I'm sure your system will regain its speed.
    Link to ECS web site for P4VMM2 V3.2A .
    http://www.ecs.com.tw/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=272&DetailName=Driver&DetailDesc=P4VMM2%20%20(V3.2A)&CategoryID=1&MenuID=82&LanID=0
    Good luck ogueonline!
    Mike
    Nov 03, 2008 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
    The usb ports and the pci slots do not work
    Yes, this can still be fix, try first to run the setup CD for your ECS motherboard to reinstall the driver for those devices...if still not fix you may need to download the latest driver for your motherboard from ECS web site and update the driver for those devices..
    Oct 14, 2008 | EliteGroup ECS 755-A2 Motherboard
    Computers & Internet Logo
    175 people viewed this question
    Alun Cox
    David Payne
    David Payne
