Question about Hunter Installer's Choice 21222 Ceiling Fan
Remote connection not working
Hi, I think we either dropped our remote one too many times or it's finally just died out. Unfortunately there is no wall switch to our ceiling fan that's suspended about 20 ft in the air by a suspension pole. I took the whole thing apart this weekend, but before doing so, I changed the codes on the remote and fan, figuring maybe something was hit when changing the battery. After several failed attempts, I decided to take the fan apart. The remote has a digitial display which appears as if the fan/light are working, but they don't come on when you hit the buttons. The remote used to beep when it made a connection with the fan - it no longer does. I also replaced the battery in the remote just for kicks. After shutting the electricity off, cutting the wires a tad, then putting it back together, turns out the light goes on and the fan moves a little when the electricity is turned back on, but then shuts off. It seems the remote's the problem. Unfortunately, I have to take the fan apart again to get the guts of the old remote out and put a new one in. We bought a new compatible remote, but my question is, there's 2 white wires and 2 black wires with the new remote - I can't seem to find the manual for the fan - is there any way you can find me a manual to model #25826 so I can have a wiring diagram? Sorry for lengthy question, but I didn't want to confuse you. Any help would be appreciated. Thanks!! Michelle
  • Anonymous Jan 29, 2008
    Re Hunter 25826 wiring. I have the same problem and found no help as yet at Hunters web site. I am going to pull it apart ,abandon the the remote and wire direct. What did you figure out?
  • Anonymous Mar 26, 2008
    i have installed a ceiling fan also a transmitter to it the i have got a wireless remote to controll the fan and the light i have got the light working just not the fan
  • 72 Answers
What brand. Model alone doesn't help.
Posted on Jan 27, 2008
  • Andrew Boulware
    Andrew Boulware Jan 27, 2008
    Sorry about that, didn't see it was a Hunter one at the top. Haven't been able to find a manual for that one online.
Replaced CR2032 battery in my pacificas keyless remote but it still wont work. I did not drop nor did water hit the remote. Was working fine one minute then died
First thing to do is check with your local Dodge dealer and see if the keyless remote is still under warranty. I had this same problem with a Dodge Durango Keyless remote. Problem was the + and - neg. connecters from battery to circuit board broke the solder connection going to the small circuit panel in the keyless remote, if this is the problem with yours, go the Radio Shack and buy a small 15watt soldering iron and solder for PC circuit boards and resolder it and it should fix the problem. If this did not fix it, the only thing to do is buy a new remote at your local Dodge dealer
Sep 20, 2011 | Chrysler Pacifica Cars & Trucks
My Toshiba vc-625 vcr remote just stopped working. Batteries are good. I can't seem to figure out how to open it up to check for a loose connection. Any ideas?
Ironic, mine doesn't work as of last night too. I tested and swapped batteries. I did notice in the past, the remote control wasn't responsive and needed to be tapped on my hands. I assume it finally died. :(
Dec 27, 2010 | Toshiba Vc625 Remote Control
My remote controlled air conditioner would not turn off because I had dropped the remote on the floor. I tried many time to turn the air conditioner off, through the remote control, but it did not work. ...
There was no danger and you were in no danger....the batteries just got juggled around in such a way that they were shorted out and discharging very rapidly...
Replace the batteries with new ones and install them correctly and everything will be fine...
Nov 25, 2010 | Heating & Cooling
My remote finally died can't get a universal to work on it do you know what i can do to remedy this
Finally found a universal remote that worked thank you anyway.
Cheers Rappa.
Nov 18, 2009 | Televison & Video
Remote start installation problem
If you have the Manual There May Be A "TIMER Setting for RUN time . I have Installed Some that Do Have this Feature
Aug 04, 2009 | Vehicle Parts & Accessories
What is the lifespan of the Wii remote? Having problems is it the remote or docking station. Have had it for two years is it time to replace?
Normally, the Wii remote will work properly unless dropped on the floor or banged against any hard surface. The Sensor connected to your Wii can sometimes end up dying because of normal use. This can be purchased for a mear 10 dollars at any Wal-Mart. If the sensor is not the problem, make sur that you are at the same level as your sensor when playing games. If you happen to be higher or lower, your Wii remote may end up moving unvolantarily around for no reason. The Wii remote is sturdy and has never broken up for me for the past 2 ½ years. Does the problem arise only when you use the docking station battery? If so, the battery would be the problem. I have stopped using this battery because of problems like these. I would recommend recharable Ni-hM batteries instead.
Hope this helps,
Jul 25, 2009 | Intec Charge Station w/ Rechargeable...
Ps3 dvd remote control will not work with system
Add me to the list. When it gets to the screen thats says press and hold down both enter and start it just sits there.
Anyone find a solution
Dec 15, 2007 | Sony Playstation 3 (PS3) Console
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Hunter Installer's Choice 21222 Ceiling Fan Logo
244 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
