Question about O2 Xda Orbit Smartphone
Cannot receive bluetooth stuff
I use WM6 . i have paired with another phone, and ticked the receive incoming beams, and with bluetooth on..... I can send stuff, but other phones cannot send stuff to me. Please help.
    An user who is expert in 3 categories / brands.
  • O2 Master
  • 1,001 Answers
  • This transmitter can connect the device automatically ,you no need do anything ,just need press the on and off button until there is blue and red lights
  • lternating flicker then it is can connect. and don't try to connect your mobile phone ,because this transmitter it is connect the earphone ,speaker .
Amazon com Charm sonic Portable Transmitter Connected to 3 5mm Audio...
Posted on Jan 06, 2017
  • 146 Answers
Upgread your BT driver and this will solve the problem..
all the best
Posted on Feb 01, 2008
Phone wil pair via bluetooth device but will not connect with device
go find for the beam settongs and check the allow all incoming ang out going beams.
Apr 13, 2010 | HTC G1 Smartphone
I cannot receive anything using bluetooth for Samsung innov8
From Today screen - settings - connections and tick of the box "receive all incoming beams"
Jun 08, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
hi thanks for using fixya!
Please follow the instructions below:
1. Tap Start Menu
2. Tap Settings Menu
3. Tap to got to Connections Menu
4. Tap Beam, and tick the "Receive all incoming beams", then close it
5. Go to the Bluetooth, you must add new device, make sure that your bluetooth is turned on and the other device must be turned on and visible for you to search it.
6. And there you go, just follow the next steps from your pda and you will be able to send and receive datas via bluetooth.
If you need further assistance, let me know!
Don't forget to rate me positively! thanks!
May 10, 2009 | i-mate SP3i Smartphone
Bluetooth connection
pls make sure ur bluetooth is turned on and in the settings of bluetooth ur device needs to be discoverable for all other devicec make sure the check box is checked
Secondly when u select the file for sending u long tap it menu will appear then u select Beam File option then ur Device will search for other devices make sure that other devices blutooth is turned On and discoverable from options it is necessary in order to connect ur devices for sending anything
Now the other device will appear in the device list select it and then u will be asked to pair up , pls enter any code to pair up take 0 (Zero) enter it on both devices when asked and then ur file will be send u need to pair up ur device once only all future communication with the same device will be hassle free
if u need to ask anything else let me know i have mastered this device i know each and every tweak of these WM5 ans WM6 devices and softwares for them ,pls feel free to ask anything
One more gift for u
u might be having problem when the files u rcv thru bluetooth are coming directly to ur phone memory which is annoying at times when u r short of mem u can install this software and then u can set bluetooth files rcv folder and then u can route all files to storage card directly , it is hard to find on internet , a small gift .........
pls rate me FIXYA for help !!
Apr 04, 2009 | HTC Touch P3450 Smartphone
Bluetooth problem
hi thanks for using fixya!!
That is weird, I never encountered that problem before. But try this option, go to your Start Menu, Settings, Connections, then tap Bluetooth, make sure that you tick the box "Make this device visible to other devices"
Then, tap Beam, tick the "receive all incoming beams"
If the same problem, better to master clear your device, to restore factory defaults.
But if still happening, perhaps you have a problem with the software, better to bring up your PDA to a service center to check the software itself.
Hope it helps, if you need futher assistance, let me know.
Pls rate me positively! thanks!
Mar 22, 2009 | i-mate Jama 101 Smartphone
Help me in imate jama problem
Please check the Bluetooth Settings, then select Mode, you should tick the "Make this device visible to other devices".
Then, select BEAM, then tick "Receive all incoming beams" to enable you to receive datas via bluetooth.
Then, make sure you have enough spaces to your internal memory and external SD card.
Hope this will help, let me know if you need further assistance.
Don't forget to rate me with my simple solution. Thanks!
Feb 26, 2009 | i-mate JAQ3 Smartphone
Blackberry curve won't pair with my bluetooth headset
Try the following. Hope this helps.
1. Go into "Media" on your BlackBerry and enable incoming files (Menu-->Receive using bluetooth).
2. Find the file on your friend's device that you wish to send, and beam the said file accordingly.
2a. If you have not "paired" (created a friendship between) the two devices before, you will need to do this first...
2b. One of the devices will ask for a PIN code first and on this device you need to create a four-digit, numeric password that can be anything you like.
2c. On the second device, enter the four-digit, numeric password you created and follow the simple, on-screen prompts on both devices to complete the pairing (you can also pair the devices in advance by going into Menu-->Set Up Bluetooth).
2d. Depending on the devices being used and the time taken to complete the pairing, you may need to re-send the file (go back to step 1), otherwise, continue below...
3. When your friend's device tries to send you the file, your BlackBerry should ask you to name the file and where to save it; if you have not set the device as "trusted" in the bluetooth settings (Options-->Bluetooth-->your friend's device), you may need to approve the file transfer first though.
4. The file should now be on your device.
Note: by default, all
* Pictures are saved into /Device Memory/home/user/pictures or /Media Card/BlackBerry/pictures if you have a memory card.
* Sounds (including songs) are saved into /Device Memory/home/user/ringtones/ or /Media Card/BlackBerry/ringtones/ if you have a memory card.
* Videos are saved /Device Memory/home/user/videos or /Media Card/BlackBerry/videos if you have a memory card.
In other words, unless you specify somewhere else in step 3, this is where you will find your file.
Jan 28, 2009 | RIM BlackBerry Curve 8310 Smartphone
Communication problem with the bluetooth
I believe you need to tell your phone to use the headset. You may have paired it, but did you turn it "on" or make it active in your phone?
Oct 15, 2008 | Motorola Mobility H500 Headset
Bluetooth not functioning
Bluetooth will function only when you put it to ON from the settings menu first.
It keeps on searching the devices around it but will not be able to find any till you out ON the bluetooth.
One more thing,
Your laptop will not be able to transfer data to your phone till you put "Receive all incoming beams" to ON in the "beams" menu.
Pleas rate.
Sep 20, 2008 | O2 Xda Atom Exec Smartphone
upgrade the phone to WM6 with A3.5 @ --> apache forums.
that will upgrade the phone's firmware at the same time as upgrading the ROM to WM6
Aug 02, 2007 | Audiovox PPC 6700
O2 Xda Orbit Smartphone Logo
Top O2 Computers & Internet Experts
Computer Repairing
Computer Repairing
Level 1 Expert
Martin Murray
Are you an O2 Computer and Internet Expert? Answer questions, earn points and help others
