FixYa.com
Tags:
Hampton Bay Dual Mount Ceiling Fan
Remove exixting fan (by 3 users)
posted by Jerrry on Jan 23, 2008
Need to get the fan off the ceiling so I can connect the wire for a newly added light. Does the piece closest to the ceiling just snap down? Need to get at the wires
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Apr 22, 2008
there seem to be no screws on the top it is firm
Comment by Guest, posted on Feb 23, 2008
Same problem on removal of flange that is closes to ceiling no screws in this part ? only screw on shaft between motor and hanger. there is also a pin with a snap ring, which I think holds motor to shaft. Screw has a nut on it.probable to lock screw into place.I want to paint and need to drop flange.
Best Solution
posted on Jan 27, 2008
Helpful (85)
ranger25
Rank:Wiz Wiz
Rating: 84%, 48 votes
Should have screws close to the ceiling on cover, then if it's a ball and socket you lift up and out through the cutout on the socket bracket, or a flushmount you find the screw that attaches to the bracket and lower down. then just take off wire nuts and install new fixture. Hope this helps.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Electric Fans problems?
Hampton Bay (261025) Dual Mount Ceiling Fan
fan not working
We had a power surge and the... Answer This...
hampton bay model 55295 fan...
The ceiling fan works by remote... Answer This...
No power to fan at all
I have an electrician trying to... Answer This...
remote lights/but fan doesn't...
think its same model but remote... Answer This...
Problem with Light
Have hampton bay E106510... Answer This...
Repair Service
Find Electric Fan Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
