Question about Dell Dimension 4700 PC Desktop
Can i Install PATA hdd on Dimension 4700
I already have two SATA hard drives, and i want to have one more PATA hard drive installed. Can i use CD/dvd IDE connections ?, Will there be any performance issues ?, Please help
  • nMura Jan 24, 2008
    PC has only 2 sata ports and one IDE port(already have DVD burner) used and on the mother board it has one more IDE. I think that is only for Disk drive. am i correct or can i use the other IDE for PATA drive ?
    Or the IDE connected to DVD drive has one more for slave, can i use that ?
  • nMura Jan 25, 2008
    This is the layout of my pc
    http://support.dell.com/support/edocs/sy...
    For one IDE i have DVD drive and a CD drive, Can I use Floppy drive connector, Is this also IDE ?. Can i connect PATA drive to this ?
  • 77 Answers
I'm sorry, but I couldn't wade through this bunch responses, so I'm going to give you my own.
You have 2 sata drives installed, already, so you cannot add an additional one w/o a bunch of wonky adapters, so use the IDE channel. You say you have an IDE rom drive. Well, there's a reason there are 3 connections on an IDE cable. One side goes into the motherboard, the other 2 into your drives. The motherboard side is the one furthest away from the center connector. I assume you have the primary connector connected to your rom drive. the 2ndary one would be on your hdd. Why people asked you why you're doing this is beyond me. It works, you'll have an extra drive, your preference. Whatever.
Let me know if you have any more inquiries.
To answer your questions from your original post directly, the other 'ide' channel is specifically for a floppy disk You CANNOT connect an IDE cable to it. And yes, you can connect an  hdd to the slave port on the ide cable.
Posted on May 01, 2008
    Scholar:
  • 79 Answers
I own this specific computer and it seems to me that the case has space for two hard drives only. If you have only 1 optical drive i guess you can use an adapter to mount hard drive #3 in the other optical drive slot. If you have 2 Optical drives installed where are you going to put the third hard drive?
Pc make is Dell Dimenstion 4700, It has only one IDE.
Posted on Jan 24, 2008
    New Friend:
  • 101 Answers
Sata pata fata mata all the same sh---t. no u can /t install a pat6a if you don't have ata capabiolities.ide is a different type of connection .an ata drive (pata,sata)has a different type of wire almost like a hmdi cable.gtive me the make and model of mthrbrd and all your drives .then i'll help u.raid can be a ide or a ta (saata ,pata )config. it basicly mean ur using 2 or more hd's in a fasterrr config"(raid 0) or a more redudancy config(raid 1 -5)get back to me i won"t steer u wrong<<<<<a+certified(john jay college)rating please>
  • 5 more comments
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 24, 2008
    by the way you can have 20 slave drives it just dependend on the cables.the first in line is your master evrything afterwards is slaves,chech your jumpers.Why dop you want a raid config 4 wat purpose? gamer? <<
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 25, 2008
    http://en.wikipedia.org/wiki/AT_Attachme...
    ihttp://support.dell.com/support/edocs/sy...
    i hope theses would help you/.I think performance would be an issue.ide is old tech.how fast r your drives(rpm)i think 7200 is the fastest an eide dam drive can go .I have 11000 rpm sata drives in a raid 0 config.If your a gamer or looking for speed raid 0 is the way to go.lose the eide drives
  • chris ZAMBROTTA
    ATA--ADVANCE TECHNOLOGY ATACHMENT
    SATA----SERIAL" " '"""""""" ' '"" " ''" ' '''"
    pata-----parallel""""""""
    they are all same cable
    ide n eide are different cables
    floppy is also different cable
    wat r ur hdd?
    u can put all ur cd ,dvd drive s on 1 ide cable
    in a series config
    the floppy has it own port
  • chris ZAMBROTTA
    u bhave 2 sata ports
    u can put both drive s on 1 port n use the other for dvd
    or u can put a hhd as master and dvd as slave o1 and hdd as master on other
    u only have 1 ide port
    the floppy looks like ide but is smalleer
  • chris ZAMBROTTA
    http://www.directron.com/patasata.html
    try this link maybe help u understand more'
  • chris ZAMBROTTA
    chris ZAMBROTTA Jan 31, 2008
    1more comment did u think about your power supply? add all these devices ,one must also upgrade power supply./\
  • chris ZAMBROTTA
    chris ZAMBROTTA Feb 10, 2008
    by adding second hdd you will be increasing your performance immiencly ,if thats wat you want .you can run a raid 0 configuration,if ur looking for redundancy you run a RAID 1 cofig. trick out is wrong. any more ?'s get bacdk to me i'll showw you how to confogure a raid setup. fixya rating please.
  • 46 Answers
Why use pata. if you have sata on your mb. you must have raid support.
Posted on Jan 23, 2008
  • richard lavoie
    richard lavoie Jan 28, 2008
    your already taking a performance hit by having two harddrives. when you access a program it reads fom one drive then stops and looks on other drive for additional files then back to other drive for more files. if you have one drive for os. and programs thats ok and other drive for storage ex. pictures,music and documents.
  • 589 Answers
Depending on your motherboard, you "should" have an IDE1 and IDE 2 connector on the board.
Just be sure to set the jumper to slave on the new drive.
Yes, you can use the cable with the double connector going to the cd drive, but you may have to tinker with the jumper settings between slave and CS (cable select).
I would just use another ribbon if it has another IDE port on the board.
  • brian c
    brian c Jan 23, 2008
    He may only have 2 SATA ports.
  • brian c
    brian c Jan 24, 2008
    You can use either one.
I cannot connect SATA HDD
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
Oct 08, 2012 | Computers & Internet
My Toshiba mk4058gsx HDD is not detecting
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 20, 2011 | Toshiba (MK4058GSX) 400 GB SATA Hard Drive
How do i hook up lg/gh22 super multi dvd rewriter to my dell dimension 3100 The cords are not the same
The drive you are installing is a SATA drive. The system came with a PARALLEL ATA or PATA optical drive, The motherboard has a SATA controller and the HDD is a SATA drive. So you need a SATA data cable and connect it to the SATA 1 port on the motherboard. There should be a SATA power connection inside the chassis that is not being used, that you can connect to the drive. Then go to system setup (F2 at boot) enable the SATA 1 controller and disable the PATA controller
http://support.dell.com/support/edocs/systems/dim3100/en/sm/parts0.htm#wp1043338
Oct 05, 2009 | Dell Dimension 3100 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Trying to install hard drive on Dell Dimension 8200.
Sounds like the drive from the 4700 is a SATA drive which uses a different connector than the 40-pin IDE. I couldn't confirm it, but the 8200 may not have SATA connectors for this type of drive. Although the 4700 appears to have both SATA and IDE.
Dec 07, 2008 | Dell Dimension 8200 PC Desktop
Recognizing my sata DVD writer in bios mode
How about a work-around?
(Your post is so old now that you probably figured out a solution . . . so this is for other readers)
I have the exact same motherboard, and a SIMILAR problem.
I have a PATA CD/DVD drive . . . so no problem there.
But I have a SATA hard drive, and the BIOS does NOT see it.
So when I boot from the WinXP CD, that is fine,
but then the install process claims I have no hard drive!
So how can I reinstall WinXP to a hard drive that doesn't exist yet?
Solution that didn't work:
So I knew the ASUS SATA driver (embedded in their RAID driver) needed to be loaded,
and TRUE, the WinXP install process gave me the opportunity (via F6 key) to install any
additional driver for a mass storage device. Great! So, with the latest driver on the floppy
from ASUS using their "MakeDisk" utility, I let the Windows install process read in the driver.
Well, it made the hard disk visible to the installation . . . sort of . . . but then it took me
to the Recovery Console (which I didn't want or need) rather than the Repair Install process
(and there was no "R" option available to initiate the Repair). So, gave up on that!
Solution that I think is sure to work:
Go to Ebay, and buy from Hong Kong a PATA to SATA adapter for about $7.50 including shipping. It is a great deal! And customer ratings gave HIGH marks, so the seller is trustworthy.
Make sure not to buy the SATA to PATA (the other direction), and also, I'd suggest buying the
version in which the little adapter card plugs directly (without a cable) into the PATA socket
on the motherboard, and then plug the SATA cable from it to the SATA hard drive (or the
SATA CD/DVD drive in your case). Connect the power jacks as needed. And presto!
You have converted the PATA interface to a SATA interface which needs no SATA driver!
The BIOS will see the SATA drive as a PATA drive (how clever!). After doing the WinXP
install or whatever, switch back to the way things were and save your adapter card for next time.
Sep 06, 2008 | ASUS P4S800D-X Motherboard
Dell dimension 3000 hard dirve what type do i need to install a sata pata or ide
Hi
Dell Dimension 3000 accepts IDE hard drive. Any modern IDE drive should be fine
Check out Dell Dimension 3000 Service Manual for spec and how to remove and install parts.
Mike
Aug 21, 2008 | Dell Dimension 3000® Pentium® 4...
Sony Dual DVD +/- RW
set the hard drive to master and the dvd to slave
Jan 24, 2008 | Computers & Internet
Dell Dimension 4700 PC Desktop Logo
609 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
