Question about Fostex MR16HD/CD Digital Recorder
FostexD160 my D160 shows 'no drive!' as a warning when powered up- i've swapped caddies but no good, what can i do? is it curtains for the machine?
  • 178 Answers
If it is under warrenty I would send it back. You have a bad connector
Posted on Feb 11, 2008
Have a scottsmanc1448 ice machine shows codes 1 an an 2 longharvest cleaned all water sensors descaled machine works threw all cycles water flows over both curtain coils ...
ok, what you have not told me was the temp of the ice plate. If you have an inferred thermometer now is a good time to use it. what is the Temp of the plates or ice collection try. Ice will never collect if it is not below zero C. 32F my guess is it must be below 28F. you need some kind to thermometer.
Dec 09, 2014 | Kitchen Appliances - Others
My machine is doing stretch stitch on straight stitch position
sounds like a gear has worn or gotten damaged, a trip to the repair
shop would be a good idea
Aug 19, 2012 | New Home Sewing Machines
I have a 2008 buell 1125r motorbike...i've got power to the tailights but that's it. the battery has tested fine, i've swapped relays and replaced fuses but nothing changes, wussup?
Turn the key switch in the opposite direction. The key setting you have it in is so you can leave the bike parked on the side of the road with the tail light on as a warning light so no one hits your bike.
Mar 27, 2012 | Buell Motorcycles
How to hanging curtain hardware
The most important thing with fitting hardware is to find the studs in the wall for brick veneer or in the case of solid brick, you must ensure the wall plug goes deeper than the wall plaster. The wall plug needs a hole drilled for a good fit- not loose or the plug will rotate as you tighten the screw.
Side openning - you can adjust the curtain postion after installation by lifting the cord from its clip on the carriage and moving the carrier along to the correct position.
On one of the carrier slides there needs to be an overlap for the little carry bar for the curtain hooks so you do not get a gap when the curtain is shut.
When designing curtains there should be at least 2.5 drops ( window cobverage) for a good looking curtain.
To prevent heat loss thermo syphoning up the window, you should close in the pelmet on the top. Just 3 ply will do this fine.
For one side pull, you need to screw the cord pulley end to the floor or skirtin via the spring provided and set the length of cord by shortening at one of the carriage slides.
I may be rambling here, but a simple stud finder is really handy to find the studs (vertical timbers) It also shows power cables but they will not be as wide. Any photos of your house under construction is good to show where the timbers and power cables are.
It is a good idea not to hit the power cables - tends to burn things - like houses.
Anyway if you describe waht sort of fittings you have you may get more useful info.
Dec 28, 2011 | Cameras
Lacie 250 gig HD will not show light on front when switched on, also no sound comes from it, it seems completly DEAD, this happened overnight, at end of night all was OK, in the morning it would not even...
the power regulator inside the external enclosure is probably dead the drive itself may still be intact,you can remove the dribe from the enclosure and run it as an internal drive if you have any free ports or you can buy a new enclosure for it and it should run fine.
Jul 01, 2011 | LaCie (301074) 80 GB Hard Drive
Need HD Caddy for Emachine M5312. Not System board, Not HD but on
Hi again
I have found a US site for you, if its an empty caddie you need they at the bottom of the page:
http://www.thefind.com/computers/info-hdd-caddy
Good luck and thanks for using Fixya!!!
Feb 18, 2009 | E-Machines M5312 Notebook
Swapping hardrives between 2 compaqs
it is possible but i would have it done by a proffesional or you risk screwing it up...no offence i had a friend who completly wrecked his comp trying to do this he had to buy a whole new one
Jan 06, 2009 | Computers & Internet
Hard drive
If you can find another working 6L300RO, you can try swapping the logic board from the working drive onto the dead one. Try this if all you want is to recover the data from the dead drive.
Jan 15, 2008 | Maxtor / DiamondMax 10 / 80GB / 7200 / 8MB...
Power on after HD replacement.
If you changed nothing apart from the hard drive I would remove it and then try restarting the laptop. If you get an OS not found message then check the pins on the hard drive (and caddy if there is one).
Sep 06, 2007 | Sony VAIO Z1RA Notebook
Open Questions:
See all Fostex MR16HD/CD Digital Recorder Questions
Fostex MR16HD/CD Digital Recorder Logo
88 people viewed this question
Top Fostex Televison & Video Experts
Michael Galve
Michael Galve
pawnpower
Tom Chichester
Are you a Fostex Televison and Video Expert? Answer questions, earn points and help others
