Question about Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV
Sony kdf-55wf655 i changed the lamp then rest the lamp timer . now it has system status and path a , path b and all of the tvs info on the screen . can anyone please help me out and tell me how to get it off the screen? ive tryed turning tv off , unpluging power and neither got it off.
  • hmirsky Jan 10, 2009
    I have this same problem on a Sony KDS-50A2000! Can you tell me how you solved the problem?
    Thanks!
    President:
  • 4,402 Answers
I hit the "display" on the remote for the Sony TV
Posted on Jan 28, 2008
Sony kdf46e2000
If the "bar" is black or darker than the rest of the screen it is a damaged optical light engine--caused by the intense heat from the lamp that shines into the engine.
Jun 16, 2012 | Sony Grand WEGA KDF-55WF655 36" Rear...
I have Sony Grand Wega KDF-55E2000. While my 3 year grandchild was visiting she was playing with remote and now I have System Status and Path A Status screen displayed that I can't remove. Please help!!!!
The easiest way is by resetting the tv itself back to the factory setting.Just unplug,replug the tv back like about an hour later.This should remove itself.
Nov 22, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
For a KDF-55WF655 SONY PROJECTOR TV, WHAT REPLACEMENT LAMP DO I NEED
Required lamp for Sony KDF-55WF655tv is as follows:
A1085447A .... LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200
Thanks.
Nov 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
After turning on my sony kdf-55wf655 tv for 3-4 minutes it automatically fades out to a blk screen (also no sound) and the green power light starts to blink. the tv stays in this status for appox 2-3...
The projection lamp,the sign of it life is over.The projection lamp been in the tv about 1 1/2 or 2 years,used the tv on and watches at least 4 or 5 hours a day?It time,to replace it,with a new projection lamp.
Aug 06, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
After I reset kdf60xs955 lamp timer
Typically, turning the set off and back on again should take you out of any of the Service Menus. If not, try turning of the set and unplugging it for 5 minutes or so.
Skyassoc
Dec 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Problem for Sony Grand WEGA KDF-55WF655. Hello,
5 times Red LED blinks means Lamp Driver Error. (KDF-55WF655)
2 possible reasons, either Lamp is gone or Ballast Supply got bad.
Replace lamp first, in most cases it solved the problem.
How old is this TV and did you replaced lamp recently?
Thanks.
Oct 21, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Wega tv alerted us that lamp light is getting low. how many hours of tv viewing do i have left before i have to replace?
Hard to say how much longer the lamp will last. Most lamps have a factory live expectancy of about 3,000 hours. They program the tvs with a timer that lets owners know when its close to that time. Depending on how often the set is used will affect he lamp life, if played for 5hrs a day the lamp may last longer then if its played 10hrs. When the picture gets dim or causes the set to shut down is when its time to change the lamp. If you remove the lamp and the reflector (mirror), the element has white spots or is misshapen is when they should be replaced. There is usually a lamp timer and a way to reset the counter in the menu options. Check the owners manual for instructions.
Sep 17, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Changing the lamp in a Sony Wega KDF46E2000
Click Sony Support to download instruction manual of KDF-46E2000that has lamp replacement info in detail.
Click Sony Support to download instruction manual of KDF-55WF655
that has detailed procedure of lamp replacement.
lamp replacement is very easy and mentioned in related instruction manual of TV. Please buy original Sony lamp from Sony Accessories Store and avoid aftermarket / cheap lamp.
May 02, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
KDF-55WF655 Sony TV red lite flashes6 times
The thermal fuse has opened. Unfortunately, its likely that the ventilation system of the TV has been blocked by dust or other foreign matter. The cyclone fan mounted above the lamp housing is prone to this type of accumulation. Check for evidence of overheating in the lamp, lamp housing, and especcially the red wires going to the lamp socket. If they appear scorched, its a safe bet it got very, very hot.
To bring this TV back to life a new fuse needs to be installed, all the fans need to be cleaned, the lamp ballast board may need to be replaced as well if the wires appear to be damaged. Also, if your lamp is not new, it should be replaced too. Botton line here is cost. If you call a service company out, expect to spend a minimum of $300 and as much as a $1000 or more.
Keep your eye out for class-action lawsuits being filed on these TVs. I've seen a few of these actually melt the plastic lamp cavity to the point where it may catch fire.
Feb 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony kdf55-wf655
Jan 23, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KDF-55WF655 36" Rear Projection HDTV Logo
85 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
