No power at all when I turn it on. Was told that it was the ac power supply board. Replaced it I know hear a hum but no power????
Any help would be great
  • 87 Answers
Check to see if all your door interlocks are being made. You may have a power supply issue. I also have people test their outlet to make sure you do have power.
Posted on Jan 24, 2008
Mixing board hum
AC hum comes from poor grounding of components.
Jun 21, 2017 | Music
Immage runner 400 display the message E220
1)If sides of the scanning lamp are blackned replace scanning lamp.
2)ccd pcb might have a fault.
3) Composite power supply may be faulty.
Jul 20, 2011 | Canon imageRUNNER 400S Copier
I cannot start my eMachine ET181003r. Every time I try to start, just hear humming sound for one second and then stop. I am not sure it is the FAN problem or not.
What you are most likely hearing is either one of the fans within the computer case, or a Hard drive. The problem could be many things and would most likely need to be inspected in person. I am sorry I cannot be of more help in this situation. Good luck!
Dec 23, 2010 | eMachines ET181003R PC Desktop
try to change the scanning lamp,if not then change the immage reader board,at last u have to change the power supply
Nov 18, 2010 | Canon imageRUNNER 400S Copier
Can any help me, plz guide me how remove fuser unit and power supply pcb of canon ir 1370, plz help ,thanks in advance
not an easy task. better off to take to a canon service place. why do you need to remove power supply? no power?
Apr 11, 2010 | Canon ImageRUNNER 1670F Copier
Turn on the organ and get a loud hum.......
Chances are you're hearing "60-Hertz" hum that comes from poor filtering in the organ power supply. Electronic circuits need direct current (DC) but our power lines supply alternating current (AC). The power supply converts the AC to the various DC voltages needed. Parts called filter capacitors smooth out the voltage, and if they go bad or lose contact because of bad connections the result can be the hum you're hearing.
There are other possible causes, but the filtering is so common it's a good place to start. You don't give the age of this organ, but if it's one that has been around a while, it's a good bet some of those capacitors are worn out.
If you can post a follow-up with a make and model, I'll check some of the technician groups and see if anybody has service information.
Good luck and thanks for using Fixya!
Feb 11, 2010 | Music
Subwoofer Emits a Buzzing Tone
The 2200 uF capacitor in the power supply has gone bad and the humming is a 60 Hz from the rectification of AC to 18 vDC.  Either get a new power supply or take apart the power supply and replace the bad cap.
Mar 16, 2009 | Altec Lansing AVS 500 Computer Speakers
Canon Copier NP 1020 - error code E0
pretty much the same, the codes are good for several models not just one.
you need to find the other numbers to know exactly which code it is, press the start or stop key to see it display the other #'s.
fuser is on the left side if you replace the parts might as well replace the claws and oil roller.
"E000" Heater lamp, Thermistor, DC controller "E001" Heater lamp, DC power supply / AC Driver circuit board, Thermistor, DC controller. "E010" Main motor clock sensor, DC controller PCB, Main motor, DC power supply / AC Driver circuit board
Sep 16, 2008 | Canon Office Equipment & Supplies
DX-2517 AC HUM
As you posted/described, internal work had been done at the factory then perhaps the source/cause of the AC hum is external.
If the unit is being used as a base with a regulated power supply, then the power supply has to be checked. This would include the big capacitor, the diodes and the regulator transistors. On certain occasions, loose transformer E core can also cause the hum.
There are also instances that other electrical devices can cause the hum, these can include fluorescent lamps, air purifiers, dehumidifiers and others.
In some cases, it can be loose grounding of the antenna mount or the braided/shield wire solder to the PL-250 connectors.
If it were mobile, then the antenna grounding is also a possibility. If the hum is higher than 60Hz and goes with the engine RPM, then the alternator of the vehicle has to be checked.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Galaxy Radios DX-2517 CB Radio
43 people viewed this question
